440B battery disconnect
Started by rockwall, February 01, 2024, 05:19:37 AM
rockwall
I would like to install a battery disconnect on my '73 JD 440B skidder. Any recommendations would be appreciated. Thanks
Any auto parts store should have one. I am thinking of one that have a lever on it that goes up and down. It just slides in between two pieces of metal when it's on. Simple.
doc henderson
chrome metal caterpillar heavy duty switch for all weather conditions.
Grandpa
I put one on my 440b a few years ago. I put it in the left rear corner of the middle section of the floor. It is on the ground side of the batteries. I had to custom make cables. It was kind of a slow process because of limited room. The cables have to be exactly the right length and the terminals in the right orientation so they don't rub.
