Hey everyone. Another issue with my 518 cat skidder. Had a problem with some bad fuel awhile back, now having a horrible time trying to start this thing. Changed fuel filters out 3 different times hoping that I eliminated the problem. It will crank over forever but will not fire and won't build fuel pressure. Does have any resistance on the manual primer pump either. If I pour the starting fluid to it, it finally starts and fuel pressure then registers where it's supposed to be. Runs great after its started. Shut it off for 5 or 6 hours and same issues. Ideas???
Sounds like you are getting air in the fuel line...make sure that there's no pinholes in the fuel lines on the motor... might not be big enough to leak fuel but let's the fuel drain back while sitting...
I had wondered that as well, but it seems like a big coincidence that this started after I got a bad batch of fuel. Just wondering if there is some type of valve maybe stuck open allowing fuel to drain back.
I only know bosch systems well and standadynes somewhat, not cat. But it very well may have a valve to keep the low pressure galley charged with fuel.
On a bosch this would be called the overflow valve or ofv and its just a ball bearing and a spring located in the banjo bolt on the outlet side of the line back to tank. When you hand prime a bosch pumped truck or tractor youll actually hear the fuel spurting back to tank out that valve line which tells you the galley is charged up and ready to fire.
Keep close tabs on your oil level ..make sure it isnt rising because bad seals in the pump will probably drain back to the crankcase if its lubed by engine oil.
Thanks for your expertise Mike, I will check it out and see. This engine is direct injection if this helps with diagnosis. Is there always some fuel pressure or after sitting does it release only to build up again when the engine cranks? The longer it sits, the harder it is to get pressure and start.
Again im flying blind on cat pumps but that sounds like a drainback issue to me if its not leaking any fuel externally.
If it had a continual inlet air issue on the fuel suction side of whatever lift pump they use, you'd hear it farting in the exhaust note to some degree or other. Kinda like a burbly sound.. Like a gasser with a bad plug wire. Purging once then running great is a loss of prime in the low pressure supply, then a sufficient reprime.
What Mike said. I recently went thru a similar problem on my Timbco, started at the injector lines and worked backwards.
On our 3204 in a track skidder they have some in line screen filters that can plug up, memory says one is on the pump and the other is in a hard line union fitting.
Definitely should find and clean your rock catchers and put some paint on the locatios while yer in there.. But a clogged rock catcher will usually start and idle then quit under power. I think its gonna be a check valve with junk in the seat or a broke spring behind it. Or maybe an o-ring issue if they are poppet style.
Does it use a lift pump? A weak one will do this. My C cummings got like this, draining back and starting hard and the hand prime didn't sound right. Drained the filters and filled them with sea foam and that trick fixed it.
In 6BT cummins the cam shoves the lift pump pushrod into a spring and while checkvalving mechanically that spring squishes the fuel so its like a mechanical syringe.. Thats why a 12v will have pulsing fuel lines.
2x i have had the spring be snapped and sitting coiled inside itself. Still ran but weak.
Lift pump is certainly a path back to tank and among the usual suspects here.
Mike,
When you say "lift pump", are you referring to the fuel transfer pump? I was suspecting maybe there is a leak with it as it takes forever to build fuel pressure while cranking but is smoking terribly. Also when it does fire up, it takes about 10 seconds or so for all injectors to fire correctly.
Yes sir, lift pump and transfer pump are interchangeable terms for any type of pump that brings fuel from the tank to the high pressure injection pump.
Looks like oring may be a failure mode for your cat. In a perfect world, once primed your injection pump should wake up with the same supply pressure it went to bed with. Should be pretty easy to check with a tee and a gauge.
https://nyheavytractor.com/products/3304-3306-fuel-transfer-pump-kit-replacement-caterpillar-1w1669-8n2641-1w-1669?variant=31568400613428¤cy=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&utm_campaign=gs-2019-12-12&utm_source=google&utm_medium=smart_campaign
Thanks again Mike. I am betting on something within the transfer pump as well. For the price of a kit, it is well worth trying anyway. I don't have to put a gauge on to see the pressure loss. The qauge on the machine while running is in the green and after 4 hours of shut down it is in the red.
Thanks for your help. I will post the results once a get a kit.
Make sure the return line is not leaking also. You would not think a return matters, but it does. I had a similar problem on my 4B Cummins. I removed the return line to change the filter. When I re-attached the return line, I forgot to tighten the clamp. If it sat overnight, would fire up, die instantly, then need to crank and crank and crank. Once started, if I shut if off for an hour or so, it would fire up no problem.
Mountain.
If it has one of those hand primer pumps that you unscrew and the pump leaks fuel out when you pump then that is an air leak. Below that pump is are some check valve that can make the fuel leak off. On my 525b every time it has set for more than a day it requires pumping. Granted the 3126 has a different fuel system but I imagine that primer pump is the same.
Thanks Kiko
I have noticed that the hand primer pump is not working properly too. It does pump fuel to the filter, but when you stop pumping you can here air escaping. I will be changing that as well seeing that the machine was born in 1975.
Hand primers are built sorta like bottle jack pumps.. Orings will leak over time. Good chance that is a big part of your issue.
On a Cat 963 track loader with the 3304 engine, the fuel priming and primary filter has a check valve on the inside of the priming pump body outlet. You have to remove the fuel priming and primary filter assembly and disassemble it to get access to remove the check valve. This is more than likely the problem. The Cat track loader check valve part number is 7E5346, yours will of course be different.
(https://forestryforum.com/gallery/albums/userpics/25160/KIMG1082.JPG?easyrotate_cache=1605546021)
(https://forestryforum.com/gallery/albums/userpics/25160/KIMG1083.JPG?easyrotate_cache=1605546089)
My primer pump is different, probably due to engine arrangement however it serves the same purpose.
I know when you see brass filings when trying to prime the system, "Time to replace".
(https://forestryforum.com/gallery/albums/userpics/44942/20201119_083554~4.jpg?easyrotate_cache=1605800713)
(https://forestryforum.com/gallery/albums/userpics/44942/20201119_083611~2.jpg?easyrotate_cache=1605800617)
Replaced hand primer pump yesterday as I knew it was not operating properly. Hard starting issues still remain. The only plus side is that I can now prime the fuel system to help with starting, but has not fixed the problem. What next, transfer pump??
How is your fuel supply coming to the pump? Does it gravity feed from the tank? Being you had bad fuel, I would suspect a supply line restriction. That wouldn't cause it to lose pressure while sitting, but I'd still start there and make sure the supply pump is getting plenty of fuel to begin with.
I blew out all lines so I know that there is no fuel restriction. Also, when I do get the skidder started, it runs fine with no hesitations or loss of power.
Hmm..
Well, it does sound like a low pressure dude bleed off of some sort, if you have good supply. I had an old 5.9 Cummins with a rotary pump, it would bleed pressure off and I would have to hand prime it to get it to start. If your hand primer won't build pressure, and there is fuel to getting to it, then it would have to be a faulty primer or something else on that low pressure side like the return lines and other items these guys have mentioned.
I've also had times where I blew air back to the tank, but the debris would close the line right back off. Are you sure fuel is physically getting to the pump? I had a machine where a piece of rubber came loose inside a line, and would eventually choke off the supply. That was fun to track down. Ponsse used to use regular hydraulic hose for fuel lines and they would fail this way.
Quote from: barbender on December 22, 2020, 12:36:20 PM
Eventually most any old machine will do this. In my current case There is 'dried peanut butter crumbs' in all my diesel tanks. That's from years of using waste vegetable [blended] for fuel. When you cut open an old fuel oil tank you get quite an education. Worst case may be putting a stand pipe in the tank for the suction line.
No matter how much starting grief it gives, if its got full power all day once you get it running, then we are dealing with a priming and air purging scenario from losing prime one way or the other. Any fuel starvation is gonna come with a power starvation.
Let me back up a stage. How long have you been working this machine? Is it your first cold season with it?
Advanced injection pump timing will always be hard to start, nearly impossible in the cold and would act similar to a lost prime malfunction. In my experience pulled pumps rarely go back where theyre supposed to and a very small percent of the industrial population truly understands injection timing at all.
So if its a new to you machine i am rethinking things on this issue.
Well everyone here is an update. I bought a $10.00 check valve and installed it as close to the transfer pump that I could. Between installing the valve and fixing 2 glow wires that were broke, problem solved. Now she fires up in -30 Celsius without being plugged in. Thanks for all your input.
Simple machines and simple solutions.
On my D3 cat about 1975 model, with3304 there is no lift pump but has the hand primer bolted to the side of the injector pump and the inlet fuel line is mounted to the underside of the primer/pump with a banjo fitting that has a screen in it (smaller than a pencil) that easily plugs as mine did, Seems that especially if you run fuel low. I now often use one of those cheap Ebay 12vor 24v electric fuel pumps as primer/lift /transfer pump when I have problems priming after working on the fuel systems, that seems to work for me to get fuel up to the cracked injector line, My 3304 in he D3 has done the banjo screen clogging twice, both time the engine died completely after a loss of power then running rough,
