SPACE AVAILABLE
SPACE AVAILABLE
Author Topic: Did I Damage My Bar?  (Read 2796 times)
Offline lxskllr
  • dummy with saw
« on: December 18, 2018, 06:57:39 PM »
I had one last task for my Poulan Pro, but it fell flat. I have an ~20" limb that's half planted in the ground, so I need to buck a bunch of dirt too. Don't tell anyone, but Poulan Pro may have had some flight training after it quit, and wouldn't start  :^P  :^D
After that quit, I pulled out my 362cm. It had a chain that was pretty much done, so I thought I could get through it with that. Not much luck. Lots of sparks from the kerf, and a couple half-assed sharpening attempts later, I have ~2 cuts left. The old chain started off correctly tensioned, but was hanging at least .5" off the bar when I was done, and the second attempt at filing found the tooth remains hardened. The clutch cover was packed with burnt oily dust. The bar's missing more paint, but doesn't seem /too/ bad. The nose sprocket might be a little more gritty, but probably ok.
Did I do any damage I can't see? Too late now, but I'm a little sorry I used my good saw for that task. To finish up, I'll put my poulan bar on my echo. I have two spent chains I think I'll be able to finish with. Hopefully...
Offline sablatnic
Re: Did I Damage My Bar?
« Reply #1 on: December 18, 2018, 07:11:01 PM »
You most likely didn't hurt the bar too much, but you should do your best to get the dirt out of the nose bearing.
A couple of years ago I had to install 300 meters of perimeter wire for my robotic mower, and used a chainsaw to dig the trench. The chain was shot, almost as bad as some chains people bring to get sharpened, but to my surprise the bar survived.
Offline lxskllr
  • dummy with saw
« Reply #2 on: December 18, 2018, 07:35:21 PM »
Yea, cleaning the nose sounds like a good idea. I can replace the tip, but I'd rather not if I don't have to. Maybe give it a good soak with penetrating fluid, then soak it in oil. It was dark when I was finishing up, so I didn't do a thorough cleaning job. Scraped the groove out, and cleaned the clutch cover with a toothbrush. I'll have to check it over when it's light out.
Offline mike_belben
  • Pulp Friction
« Reply #3 on: December 19, 2018, 08:50:39 AM »
Scrape out the kerf with the back side of a razor blade or a snip of pallet banding clamped in vice grips for a handle.  put on some glasses and blast out the spocket area with a can of cheap ether then grease or gear oil the bearing.
Dirt will wear out a bar groove really fast.
Tip for next time.  Axes and shovels always start.
Revelation 13:11-18
Offline lxskllr
  • dummy with saw
« Reply #4 on: December 19, 2018, 10:39:31 AM »
Seems obvious when you say it now  :^D
Sometimes my brain gets locked into a course of action, and doesn't want to deviate from the original plan.
Offline Inaotherlife
« Reply #5 on: December 19, 2018, 03:16:57 PM »
I got a four wheeled edger, a stick edger, and a cutter mattock that I've used to bury extension cords and dig small trenches.
Might have to get a cheap saw from the pawn shop as a dedicated trencher. Looks really effective for a little more depth.
As far as sawing roots into the dirt. I try to rake/shovel as much dirt out of the way as I can first.
Hope your bars are ok.
Offline sablatnic
« Reply #6 on: December 19, 2018, 04:53:26 PM »
The bar is about as bad as it was before, almost ready for the bin, but usable.
An angle grinder might have worked better as trencher, but this was what i had.
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #7 on: December 19, 2018, 05:20:54 PM »
I had a stump to cut out one day, I was cutting about 6" above the ground, the saw would make it 2-3" into the wood before it stopped putting out chips and dust. After I sharpened the chain 10x before making it to the middle of the stump I just gave up and finished with a stump grinder.
Offline lxskllr
  • dummy with saw
« Reply #8 on: December 19, 2018, 06:06:46 PM »
It still surprises me how fast a chain can dull, and how useless it is when it does. I always figure it'll still cut /something/ dull, but it doesn't really work like that. Might as well have a bead chain from a toy saw on it  :^D
I bought a loop of semi chisel chain for my 362. I'm anxious to try it out. The chain I killed yesterday was the full chisel that came on the saw. Worked great when I was mainly cutting clean wood, but the edge wouldn't last with dirty stuff. I'm hoping the semi chisel holds up a little better. I *don't* expect it to hold up to the nonsense I put it through yesterday. I won't be doing that again with my good stuff.
« Reply #9 on: December 19, 2018, 06:21:45 PM »
I was running stihl semi-chisel on my 362 c-m but in .325 not 3/8, 3/8 full chisel lasted about the same distance in the cut too.
Offline Al_Smith
« Reply #10 on: December 19, 2018, 06:24:39 PM »
You could probably use a pressure washer on the bar then oil it .Pressure wash the chain too ,you're not going to hurt it .File the teeth then toss it in a bucket full of oil for a bit and hang it up and let it drip .You didn't kill it you just wounded it .
« Reply #11 on: December 19, 2018, 06:27:16 PM »
The problem I had was inclusions inside the tree, hidden pockets of highly compressed dirt and bark where the multiple roots had grown together into one large root.
Offline lxskllr
  • dummy with saw
« Reply #12 on: December 19, 2018, 06:37:28 PM »
That chain was already done when I used it. That was the deciding factor in using my good saw. The teeth were back to the witness marks. I figured I'd have one more session in good wood, sharpen it one last time, and save it as a stump chain. The teeth are too hard to sharpen now that they got heated up. Not worth the effort for one last cut.
I figure I'll put the bar in water to get it cleaned out good. I have the remains of some gear oil I'll douse the nose in, then use the bottle to hold bar oil. The echo is a real pita to fill with fuel and oil using my big bottles/epa fuel can, so the gear oil bottle will work good to fill it. I have a 1L Nalgene fuel bottle I used to fill the poulan. I'll fill that, then transfer it to the echo. The epa can works great with the Stihl. I can get the whole spout in the tank, and  it doesn't slop at all. The echo holes are too small, and I end up slopping fuel everywhere. It glugs out of the spout, and won't pour smoothly.
edit:
on the subject of old chains/files... Anyone have any clever uses for them? I'm getting a nice collection of files, and I'll soon have a small cache of spent chains. They almost seem too good to get rid of, but they aren't good for their original purpose anymore.
Offline Grandpa
« Reply #13 on: December 19, 2018, 09:27:12 PM »
Somewhere I saw a picture of a chainsaw chain made into a damascus style knife. Seem like it may have been here on the forum and the poster may have been Loggah. The guy with the Lombard log haulers.
Offline lil171
« Reply #14 on: December 19, 2018, 10:24:24 PM »
As a newbie here, I have to ask. You made mention the the teeth are too hard to sharpen as they heated up ( I did see that you also mention the teeth were back to the witness marks, but lets pretend they were not please). Were you reffering to hand sharpen with a file? If so, I understand. Then in that case, would a bench mounted chain grinder still be able to sharpen them, or would the chain still be toast? Thanks.
Offline lxskllr
  • dummy with saw
« Reply #15 on: December 19, 2018, 10:32:03 PM »
I'm pretty new myself, but I imagine you could do it with a grinder. With enough teeth left to be worth the effort, a file should work too, but take longer. I would guess harder teeth would be more prone to chipping, especially in hardwood/dirty conditions, as well as being difficult to sharpen in the field, but in good clean wood, they should hold their edge longer.
edit:
You can also overheat the teeth using a grinder if you get carried away with it. I don't use a grinder, but you want to go slow, and don't take too much off at one time. Dunno if you can use fluid to cool while you grind. I haven't read of anyone doing that.
Offline mike_belben
  • Pulp Friction
« Reply #16 on: December 20, 2018, 05:19:24 AM »
if your cutting dirt and rock dont even take them off the bar.  Just use up your junk chains and touch em with a 4" angle grinder right on the saw.  The angles wont matter since theyll be worn down in seconds anyway.  Again, your bars take a beating in the dirt.  Liberal garden hosing probably would help flow the trash out of the saws way.  Its how they drill wells.
Revelation 13:11-18
Offline mredden
« Reply #17 on: December 23, 2018, 08:20:37 AM »
Air compressors are wonderful for blowing the dirt off stumps, roots, bar channels and nose tip sprockets. Heck, add the chain sprocket to the list.
I live in sandy soil region and bark anywhere near the ground it's full of sand. I take the air compressor everywhere - dadgum generator too.
Offline Saw Finding
  • Member*
    • Find your best saw
« Reply #18 on: December 23, 2018, 10:03:14 AM »
what he is doing with his saw!!!!!!bull [I have typed a profane word that is automatically changed by the forum censored words program I should know better] man!
Offline sablatnic
« Reply #19 on: December 25, 2018, 06:39:41 AM »
I simply had a job to do, and I could hire somebody to do it, I could rent a machine with which to do it or I could use what I had at home.
By far the fastest and cheapest option was to use an old chainsaw with a worn out chain and bar.
The chain was this one with two more sharpenings on it!
SPACE AVAILABLE
