I had one last task for my Poulan Pro, but it fell flat. I have an ~20" limb that's half planted in the ground, so I need to buck a bunch of dirt too. Don't tell anyone, but Poulan Pro may have had some flight training after it quit, and wouldn't start :^P :^DAfter that quit, I pulled out my 362cm. It had a chain that was pretty much done, so I thought I could get through it with that. Not much luck. Lots of sparks from the kerf, and a couple half-assed sharpening attempts later, I have ~2 cuts left. The old chain started off correctly tensioned, but was hanging at least .5" off the bar when I was done, and the second attempt at filing found the tooth remains hardened. The clutch cover was packed with burnt oily dust. The bar's missing more paint, but doesn't seem /too/ bad. The nose sprocket might be a little more gritty, but probably ok.Did I do any damage I can't see? Too late now, but I'm a little sorry I used my good saw for that task. To finish up, I'll put my poulan bar on my echo. I have two spent chains I think I'll be able to finish with. Hopefully...
Got the wood out...(Image hidden from quote, click to view.)If I tried rocking it back, it wouldn't really cut.
Stihl makes a flat tool kinda screw driver (standard) on one end, and a hook on the other, helps to clean out your bar, and I blow the tip sprocket till it wines like a jet engine. file flat then remove the side bur, then if it still does'nt work, then maybe you ruined your bar. good luck.
Started by sgtbowe on Timber Framing/Log construction
Started by jimmac71 on Forestry and Logging
Started by Roxie on Ask The Forester
Started by dirtymartini on Sawmills and Milling
