SPACE AVAILABLE
SPACE AVAILABLE
Author Topic: Bug damage in EWP  (Read 912 times)
Offline dirtymartini
Bug damage in EWP
« on: August 25, 2019, 12:11:00 PM »
Is this too damaged by whatever bug got in there before I could saw it? I was going to use it for an 8x8 beam.
Offline Mike W
  • Location: Boundary Washington - Right on the edge of the Northern Boarder
Re: Bug damage in EWP
« Reply #1 on: August 25, 2019, 05:37:40 PM »
if that's pretty much the bulk of the damage in your photo, i wouldn't worry about it personally.  albeit not knowing what your intention is for use beyond being a beam hard to make that call unequivocally.  suppose if you were really concerned, one could always epoxy the damage with a slow cure 2 part epoxy :-\
Offline Don P
    • Calculator Index
« Reply #2 on: August 25, 2019, 07:19:06 PM »
That drops it below any structural grade.
We've been talking about them in another thread;
http://forestryforum.com/board/index.php?topic=107384.msg1674896#msg1674896
Offline SawyerTed
« Reply #3 on: August 25, 2019, 07:57:39 PM »
For decorative purposes it might be ok.  Looks like some other deterioration/softness in the upper right area of your photo?  Usually insect damage like that goes along with other issues.
I'd be concerned about a heavy load or long span.
Offline Southside
    • White Oak Meadows
« Reply #4 on: August 25, 2019, 08:30:02 PM »
The other concern is what else is growing up in the wood?  Maybe it would eat more, or maybe it would decide to come out and have a family reunion / feast on the rest of your new building.  Kinda look like they may be bee holes.
Offline thecfarm
« Reply #5 on: August 25, 2019, 09:42:00 PM »
I doubt bee holes. The link that Don P posted is my bet.
Now if I needed a 2x6 and that was a 2X10 I might use it. But I would not use it for a 2x6. Eastern white pine is not strong too begin with. But I plan on using some for building. Most of my hemlock is gone. It will be thick stuff.
« Reply #6 on: August 31, 2019, 05:52:49 PM »
Thanks for all the replies, I wasn't getting notifications.  I meant to take a pic of the worm today...fat white and about 1"long. Looks like some kind of larvae.
Offline 69bronco
« Reply #7 on: September 01, 2019, 01:05:19 PM »
Pine borer, once you remove the bark and saw they're done for. I wouldn't use the one pictured for anything structural.
Offline moodnacreek
  • Sawin by the notches
« Reply #8 on: September 01, 2019, 11:08:31 PM »
Fresh cut logs normally will not have these worm holes. When the pine lay around in spring or summer this [and blue stain] is what happens.
SPACE AVAILABLE
