Author Topic: Wood Moisture Meter  (Read 1136 times)
Offline jmur1
  • Wood is King
Wood Moisture Meter
« on: May 06, 2021, 04:59:38 PM »
Curious if any folks on here have bothered with a wood moisture meter.  I am curious to try one out but would be more than happy to hear comments on good or bad or preferred brand or any other feedback.  There are getting quite cheap $20 for the lower models and up to $500 for the higher end.  I imagine you get what you pay for to a point.
I am pretty good with the old weight/color/crack method  but recently Ive been splitting alot of unusual woods (for me) so a meter may help out.
Let me know.
jmur1
Easy does it
Offline Rick Alger
Re: Wood Moisture Meter
« Reply #1 on: May 07, 2021, 05:35:22 AM »
Now that I'm too old to climb up on the roof to clean the chimney, I've become a believer in moisture meters. Last year I "metered" the  wood I burned to 17% moisture or less. I didn't have to clean he chimney once.
The complication is that you have to split the wood again to get a realistic reading. To test, I split about one piece in ten. The bottom of the stacks tended to be wetter as did some species like rock maple. I restacked the moist stuff and will use it next year.
My meter was a cheapie from Harbor Freight.
Offline Nathan4104
« Reply #2 on: May 07, 2021, 08:53:15 PM »
I got a moisture meter for Christmas.  Its an unknown brand from Amazon. Has a mode selector to select a species...
Ive found a range when checking a piece of wood, as the little probes dont go very deep into the wood and its hard to push them far into dry wood.  Easy to get 15% on the outside, then split it and check what was the middle and see it in the 20s.
To really show some folk at a party that you know dry wood, smear some dish soap on one end of a dry looking piece, blow on the other and make bubbles.  People will be amazed.
Offline tomalophicon
  • Firewood hoarder
« Reply #3 on: May 09, 2021, 10:54:29 PM »
Yes I use a cheap one.
Once I started using it, I was amazed that wood I previously thought was dry based on appearance and 'knocking' sound wasn't as dry as I would have hoped.
Tom.
Offline 62oliver
« Reply #4 on: June 22, 2021, 03:50:33 PM »
I've thought of getting one, but my wood is stored in an old barn and usually sits for at least 3 years so I haven't bothered.
Husqvarna 266, Case 90xt, JD310C, TJ240E, 02 Duramax
Offline Wood Shed
  • Retired antique tractor guy enjoying my Tree Farm
« Reply #5 on: June 30, 2021, 08:53:18 PM »
I got one of those from Amazon to check the dryness of standing dead ash, just a neat easy way to gather some info. I was surprised to see how dry some of the EAB killed ash really is straight from the woods.
A society grows great when old men plant trees whose shade they know they shall never sit in. -Greek Proverb
Offline jmur1
  • Wood is King
« Reply #6 on: July 02, 2021, 02:27:37 PM »
I got the super cheap version from Walmart.  actually does seem to work ok.  You can definitely see the difference from a freshly split middle check and the end of a stacked chunk.  its about 5-10% diffence.  Ill have to check the Ash Im bringing home.  I have seen that some of them that have been dead for a while are starting to rot in place.  Time is not on our side!
jmur1
Easy does it
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #7 on: July 02, 2021, 05:25:36 PM »
I use one, came with the new furnace. Don't check through the bark, but in actual xylem wood. I never get much in the flu, but I brush it every month. My flu is straight up from the elbow, no climbing roofs involved. 42 feet up. :)
Napoleon Wood Moisture Meter
No amount of belief makes something a fact. James Randi
Offline Upton44
« Reply #8 on: July 17, 2021, 12:28:23 PM »
Same unit I have.works well
The moisture meter reads 8.3% on air dried wood
Started by WoodenHead on Drying and Processing
Last post September 09, 2012, 10:10:47 AM
by Knute
Which Moisture Meter?
Started by WoodHacker on Sawmills and Milling
Last post October 29, 2010, 09:22:40 AM
by paul case
Moisture Meter
Started by Bill Gaiche on Drying and Processing
Last post July 07, 2014, 11:00:04 PM
by YellowHammer
Moisture Meter
Started by Doghouse on Sawmills and Milling
Last post June 06, 2003, 07:28:57 AM
by Ron Wenrich
