There's a reason it's for sale.
If its the one at Lutkes for 75k you can get one with a whole lot less hours for the same money. I think Kip at Pat's Heavy Equipment has a couple with Rolly IIs for around that prices with a whole lot less hours.From experience there is no such things as a "cheap" processor. There's expensive low hour sit and produce equipment and "cheap" wrench on it and pray you can produce equipment.
I understand. But some of you guys say “how many years will your body handle hand cutting” then you say “don’t buy a cheap processor” so what’s left, rob a bank i don’t have rich people to help me or anything
Quote from: chevytaHOE5674 on July 24, 2021, 06:32:01 PMIf its the one at Lutkes for 75k you can get one with a whole lot less hours for the same money. I think Kip at Pat's Heavy Equipment has a couple with Rolly IIs for around that prices with a whole lot less hours.From experience there is no such things as a "cheap" processor. There's expensive low hour sit and produce equipment and "cheap" wrench on it and pray you can produce equipment. So that ‘07 with 8100 hours would be safer? The way I look at that is it must have sat around a lot if those hours are accurate and if it is accurate than it most likely has all original components. So in the next 2-4,000 hours I may put a lot of major parts into. Already needs under carriage. And I bet if it was looked at in person it’s got problems. I don’t know what the answer is but I do know I’ve seen low hour headaches. Past 10,000 hours there all the same. And “bad infrastructure” well my equipment should fold right up then 😂 Thanks guys prolly keep looking and saving.
Started by lblack79 on Forestry and Logging
Started by Firewoodjoe on Forestry and Logging
Started by TimberJoe on Forestry and Logging
Started by timberjack 450 on Forestry and Logging
