Author Topic: Nyle L200 operation  (Read 399 times)
Offline Jmike
Nyle L200 operation
« on: February 08, 2022, 03:48:53 PM »
Hello,
I am new on this forum and I was hoping I might get some help with the Nyle L200
My question is when you turn on the controller should the fan on the top of the compressor unit start up immediately? If so does this mean the compressor is on too? The temp in the kiln is only 40F.
The other issue is on startup it shows the humidifier ON, we don't have the humidifier.
Thank you
Offline K-Guy
    • http://www.nyle.com/
Re: Nyle L200 operation
« Reply #1 on: February 09, 2022, 08:15:12 AM »
Welcome
When you start the unit the fan will start but the heat and compressor only come on when parameters are satisfied.
Nyle Service Dept.
- D. Adams
Offline Jmike
« Reply #2 on: February 09, 2022, 03:22:50 PM »
K Guy,
Thank you very much.. The controller shows the heat on but not the compressor which makes sense ( the temp in the kiln is about 35F.)
I am still wondering why the Humindification is on?
Our controller shows - 0 - 0 on startup?
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: February 09, 2022, 03:41:12 PM »
Is not really on.  That just means that if you had it, conditions are such that it would be on.
Offline K-Guy
« Reply #4 on: February 09, 2022, 03:51:05 PM »
The way the system works is that the DB(dry bulb) won't let the compressor turn on till it is above 80F, then it turns control over to the WB(wet bulb) and the WB won't let it start till the WB actual temp is 2 over the setpoint. The WB also controls the humidification, it will be on as long as the WB actual is more than 2 below the setpoint.
Nyle Service Dept.
- D. Adams
Offline Jmike
« Reply #5 on: February 10, 2022, 05:45:19 AM »
WDH & K-Guy,
Thank you both for clearing this up for us.
Nyle L200
Started by ahlkey on Drying and Processing
Last post December 24, 2009, 06:39:50 PM
by DR_Buck
Nyle L200
Started by Jmike on Drying and Processing
Last post February 23, 2022, 09:46:20 AM
by K-Guy
Used Nyle L200 - To Buy or Not to Buy
Started by Willski55811 on Drying and Processing
Last post August 15, 2021, 08:19:27 AM
by cabindoc
nyle L200
Started by pineywoods on Drying and Processing
Last post July 19, 2018, 05:15:59 PM
by YellowHammer
