Where to get plans?
Started by Jrpitdog, September 19, 2024, 09:49:58 AM
Jrpitdog
I'm planning to build a fairly ambitious two story home and I'm having a bit of difficulty in getting plans drawn up or even purchasing pre-drawn ones.
Can someone point me in the right direction of maybe a forum member who can draw up plans or even a commercial company. Obviously I'm willing to pay. As of now I'm wanting a two story, with a loft, simple rectangle 3-3.5k sq ft. Timbers will most likely be Eastern white pine
This will be in Kentucky. I won't need an engineering stamp, just the frame erection and shop drawings for the timbers.
Jim_Rogers
Look in the services section of this forum for more information.
Jim Rogers
Jrpitdog
Thank you Jim. I figured there was something like that available
doc henderson
Jim, is that something you can do?  @Jim_Rogers
logman
I use Don Whippie at DW Timber Frame Design.  Great guy to work with.
LT40HD, 12' ext, 5105 JD tractor, Genie GTH5519 telehandler
M&K Timber Works
