Propane tank refill
Started by Jim_Rogers, March 03, 2016, 12:09:09 PM
Jim_Rogers
I have been using my portable propane heater at the weekend workshops we've been having.
Early this past Saturday the flame went out. I lifted the tank and could tell it was empty.
I took it down to the local hardware store near the site to get it refilled. They had a good price for my area of $13 and change.
He asked me if I knew the date of the tank, and or if it had expired.
I told him I didn't know about any tank dates.
We walked outside to view my tank. And sure enough it had expired back in July of 14. So he wouldn't fill my tank. It seems that tank dates are only good for 12 years.
He had new tanks there for $34 and change. I didn't ask if that included gas or not. I assumed not. And I didn't have the cash for a new tank and gas.
I asked him if he knew of another place nearby that had one of the "exchange" programs. He sent me to the local gas station. This area is some 40 miles from my sawmill yard.
At the local gas station I asked about the exchange program. And they said it was $24 and change. I asked him if they cared about the date of my tank. They said no.
So, I got a new tank. I figured I was getting a tank of gas and a new tank for $10 more.
I took it back to the job site and hooked it up and started it up.
It ran about three hours or less and the flame stopped again. I restarted it but it didn't run for very long. When I picked it up it felt very light. And I assumed it was out of gas. But I wasn't sure.
I know it ran out of gas as I took it yesterday to be refilled and he said that normally they put in between 4 and 4 1/2 gallons of gas. Mine took 4 gallons, so in his opinion my tank was empty.
The exchange program is ok but they don't give you much gas.
I had never heard of tanks expiring, until this happened to me.
Jim Rogers
47sawdust
Jim,
Here in Vermont that has been the policy for close to 15 years.They used to just change the valve but not anymore,you have to buy a new tank.It's just something to get used to,at first it's a surprise, but anything to keep the place from going BOOM is worth the expense.
Mick
easymoney
i have heard of welding gas companies questioning the age of the tanks. here they always exchange welding gas tanks so the age does not seem to matter. the people i deal with always puts a gauge on the tank and checks if it is full before they give it to you. i have gotten tanks with very little gas in them before they started checking them.
a few years ago i had a 100 pound propane tank tank filled at a local supplier. i had hauled it in a van. he said i cant let you carry it away in that van it has to be standing up secured  in a pickup. i waited until he went inside the building. i loaded up my tank and left. i felt like i was stealing my own tank.so much for the rules.
dustyhat
Some tractor supply co. offer exchanges on propane and welding gases . might check it out . my welding and cutting bottles are cheaper there. as for the bottle age its the law in most places . better safe than sorry.
Jim, it sounds like you got someone's "empty".  Normally those exchange tanks are full.
Gary_C
Quote from: Magicman on March 03, 2016, 01:25:36 PM
There is a growing problem with those exchange tanks being under filled. There is no good way for a consumer to tell if it's full short of carrying your own scale.
If you suspect the exchange tank is light, look for the empty weight stamped on the tank and add the weight for the size of the tank, normally 20 lbs for the small tanks. You can ask for the tank to be weighed but you may or may get what you ask for. If they refuse, just walk away. If you walk away with the tank and then come back and complain, it's too late.
At today's prices, there is less than $4.00 worth of propane in those 20 lb tanks. Anything you pay over that is profit.
And yes, the DOT says those tanks have to be transported upright and secured in the vehicle when transporting.
Currently here, you can get an empty tank filled at the Amish store for $8.00. They are the only place that weighs the tank first, and only charges you for the gas they put in, not by the tank. I can go there with a tank that is not completely empty and get a fair charge to have it topped off.  Never had any question about a date. Not sure if that is law here or not.
breederman
The date is stamped on the handle , they can be re certified , I have one here that has been re certified and so it has 2 dates stamped on it . I have to show some of the fillers the newest date as it is not as obvious as the older one .
Together we got this !
Jim_Rogers
The one I have now has two dates.
Jim Rogers
gspren
   A few years ago Rhino and some other exchange tanks started putting 15Lbs in 20Lb bottles and in small print on the paper label it states 15lb so it's legal. This winter I also had a place not fill one because it was out of date so I just took it to another place that doesn't look.
chet
NFPA standards as I understand them:
Cylinders are subject to recertification (also known as requalification) twelve years from their date of manufacture and every five years after that. For example, a cylinder manufactured in January of 2000 will have to be recertified in January of 2012 meaning if you take your bottle to the propane company in April of 2012 to be refilled, it will have to be recertified  by authorized personnel before it can be filled. That's why Jim's last tank had two dates, the original date stamp and the recertification date.
This is the national standard, State standards may vary.
chet
One of our local suppliers recently payed a fine in Wisconsin for under filling exchange tanks.
Ljohnsaw
I had some old tanks a while ago that had the old valves.  The place I refill (only pay for what goes in the tank - rates vary drastically through the year) did a swap on the valves at that time.  I pick up free tanks all the time off of CragsList all the time - now I have 9 - the last two were nearly full 8)  Most are old.  My place does not do exchange so I take them to HD for a swap and talk with the guy so I can get a "fresh" tank that has quite a few years left on it.  The tanks are light. :-\  I had a great looking tank that I took to a place far from my home that runs a special on Fridays - 99 cents a gallon.  Turns out the tank was expired.  I could have exchanged the tank for something like $17 or 18 but decided to re-cert (a sticker) for $8 and fill for $4.50.  The "5 gallon" tanks will vent at a max of 4.7 gallons (so I was told) because of the new valves.
John Sawicky
WV Sawmiller
   I knew from my scuba classes an eternity ago that all pressurized cylinders had to be inspected I think every 5 years by DOT regs. I did not know/remember there was a limit but it makes sense because of metal fatigue.
   I need to get my boat out and see what high water left us. Two years ago I was out salvaging treated lumber from upstream floods and my son came with me. He got 2 - 80 lb and one 40 lb propane tank. One of the 80's was brand new with a Lowes price tag of $79.95 on it and was full. He is still using it on his BBQ. I forget how much gas was in the others. I had seen them in earlier rounds but ignored them not realizing what they were or their value.
AfraidChocker
Swap out propane tanks are kind of a rip off. Here they fill a 20 pound tank with 15 pounds, but you can fill the tanks at a local supplier and get much better bang for your buck. The problem is they get all the odd-ball tanks that are out of date and someone has to pay for all those costs.
All tanks are certified so while you can save money by buying even your big tanks, that may not be worth it. I use a 500 gallon provided by my propane supplier for heat for my house for this reason. Re-certifying tanks of that capacity is a pain.
As a sheep farmer, I have no intentions of arriving at the pearly gates in a well preserved body, rather I am going to slide into heaven sideways with my Kubota tractor, kick the manure out of my muck boots, and loudly proclaim, "Whoo Hoo, another Sheppard has just arrived!"
bill m
A class action lawsuit was filed against Blue Rhino for under filling propane tanks and not stating that fact on the label or in their advertising. The courts approved a 25 million dollar settlement in 2012. All their advertising now say "exchange" (not refill which implies the tank was refilled to capacity).
martyinmi
I refill my own tanks. 8)
The farmer across the section has a couple 500 gallon tanks for his dryer setup, and he has tapped into one of them with a hose and the proper fitting to fill 20 lb. tanks.
I have two 20 lb. tanks for my pickup camper, two for the grills, and two 30 lb.(I think they are 30 anyway?) for our old Corsair bumper camper. The tanks for my pickup camper are horizontal, from the 70's, very expensive to replace, and no one will fill them for me anymore .
Whenever I have 2 or 3 that need filling, I take them to work and head across the section at lunch break. I leave him a 30 pack of Busch Lite and he's happy. Having him around saves me a few headaches every year.
I take it a step farther and fill my own hand held propane tanks from the 20 pounders. I bought the adapter from Harbor Freight.
I can only get those about 2/3rds full, but I'm ok with that. I usually keep 3 or 4 of them floating around.
My Lehr weed wacker runs on propane, so I go through a half dozen or so every year.
In case anyone is wondering, Lehr propane weed wackers are gutless! smiley_thumbsdown
No God, No Peace
Know God, Know Peace!
Ljohnsaw
Quote from: bill m on March 03, 2016, 07:30:20 PM
:(  I didn't see any of that 25 mil...
John Sawicky
21incher
I had a tank like that a couple years ago that BJ's would not fill. I did a Blue Rhino exchange  and the tank I got was 10 years older then the one I traded in and it was not recertified ( That was the newest tank of the batch ) I emailed Blue Rhino to see if they knew the law and was told don't worry about it, it was safe and just keep using Blue Rhino for exchanges. I guess they do that to keep you coming back. :)
WH_Conley
martyinmi, get the hose from sporting goods that has the small tank on each end. One Male one Female. When filling the small tank drop it in a bucket of water and just crack the valve. Fill it slowly. I used to fill our portable Oxygen tanks for the Ambulance from large tanks. Fill it fast and pressure drops when it cools down. Slow and cool will get them fuller.
Bill
jmouton
  i go through alot of tanks of various gases in a year ,  i know propane is 5 years from date on tank, the other tanks i own ,  i am on an exchange program with my local welding shop and i always get up to date tanks,  but its every 10 years  on any welding tanks,  oxy act , etc ,   thats here in michigan ,   and if you haul more than a 1000 pounds of tanks ,you have to have a cdl with a hazmat endorsement , in mich ,  probably nation wide,
        jim
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
justallan1
Although things may have changed, the last I new you didn't have to have anything bigger than a 40 lb bottle hydrotested because they called them permanent tanks. I've had a 100 lb bottle for my 5th wheel for 15 years and have never been asked about a date.
I use to fill all of my own little camp size tanks and Co2 tanks and I found the best way was to throw the empties in the freezer to cool them off first, put the tanks that you are filling out of in a warm place, after awhile hook them up and turn the tank you are filling out of upside down so you are filling your bottle with liquid rather than gas. If you try to fill a tank that is warm you turn your liquid into gas and won't get a good fill without a pump.
Kbeitz
My weld tanks get a date stamped on them with a moon or a five-point star after the date.
I was told the star is good for 5 years and the moon 10 years.
Love machine shop work
and Wood work shop work
And now a saw mill work
DelawhereJoe
I used to work for the local company that filled blue rhino tanks here in Delaware. They can only be filled to 80% capacity anyway due to expansion of the gas to keep them "safe". They would fill around 1000 cans an hour when everything was running smoothly. They would also fill papco 20 lb tanks and ship them out on 18 wheelers, was told that some of the filled tanks make there way up to Canada. I have a 500 gal tank in the ground at my house and they will only fill to 80% so it only holds 400 gal when full.
DelawhereJoe
Also the old brass valves would be scrapped out for about $1000 per 55gal drum, old tanks would be sold off for scrap to a place in PA. I want to say a 53' trailer full of cans would bring around $2000, so even the bosses trash was making him money.
