Author Topic: Log stand  (Read 16281 times)
Online trapper
Log stand
« on: July 25, 2017, 04:56:08 PM »
How close should the log stand be mounted to the collar where the hook is attached on a cant hook?
Offline Tam-i-am
  • Board Moderator
  • Gender: Female
    • Logrite
Re: Log stand
« Reply #1 on: July 26, 2017, 06:33:17 AM »
Trapper
You want to move away from the collar and place it close to the tip.  Here is a link with pics
https://logrite.com/store/Item/Universal-Log-Stand
Tammy
Offline mredden
Re: Log stand
« Reply #2 on: January 30, 2019, 01:38:14 PM »
How much weight will the Log Stand support?
I deal mostly with 30-36 inch pecan and live oak that weighs a lot (when I can roll it). I do love my LogRite cant hook.
Offline Tam-i-am
  • Board Moderator
  • Gender: Female
    • Logrite
Re: Log stand
« Reply #3 on: February 08, 2019, 09:36:34 AM »
The log stand is very robust as it will hold 1000 lbs.  It would be able to handle those large logs but
you will find it difficult to pull a 36" log up and onto the log stand no matter what leverage you have.  The preferred method for cutting large logs is to cut halfway and then roll the log with a cant hook/peavey then cut the rest of the way through - no log stand needed.
The log stand should be used with small diameter logs that when cutting through would cause the saw to hit the ground.
Offline mredden
Re: Log stand
« Reply #4 on: February 10, 2019, 05:05:34 PM »
Ah well. It will help buck limbs for firewood. Ordered!
at a stand still
Started by jmouton on Sawmills and Milling
Last post February 19, 2016, 10:50:35 AM
by outpost22
what does this stand for
Started by js2743 on Sawmills and Milling
Last post September 22, 2008, 06:13:40 PM
by WDH
150 year old stand
Started by Left_Coast_Rich on Forestry and Logging
Last post October 18, 2004, 12:42:58 PM
by Frank_Pender
Log Stand Demo
Started by Tam-i-am on LogRite Tools and Rite Leg Co
Last post July 26, 2011, 11:04:25 PM
by CT Trapper
