Lt 40 blade guides
Started by stihltoomany, February 29, 2020, 04:42:56 PM
stihltoomany
The drive side blade guide keeps working loose were you make the vertical adjustments going to try loctite is anybody else have a good suggestion on how to keep this from working loose Other than going to the new high performance guides
Way too many saws, mostly STIHL
Bobcat S650, Bobcat 331 excavator Bobcat A770
and other dirt toys
Looking for hyd bandsaw mill, Timberking used maybe? NOT anymore!
WoodMizer LT40 super
Working loose indicated that there is something keeping something from getting tight.  Take everything apart and give it a good wire brushing and cleaning.  Is there anything rusted away?  No need for Loctite.  Properly tightened will not loosen.
donbj
Are both locknuts on? Top and bottom?
I may be skinny but I'm a Husky guy
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100CD, Husky 185CD
stihltoomany
This has been a problem since the beginning. Have replaced entire guide roller mounting assembly. My blade seems to have flutter in it but saws fine. Replacing B57s to see if that helps. All bearing seem fine. Thanks for suggestions.
and other dirt toys
By "flutter" are you describing blade oscillation before it enters the log?  If so blade tension can/will affect this oscillation.
Earlier you were questioning the guide working loose?  Is this still a problem?
stihltoomany
and other dirt toys
