YOU ARE DRAFTED!
Started by Jeff, November 17, 2024, 09:01:06 AM
Well, your posting can be. I just discovered that this version of the forum software includes the ability to enable message drafts. I thought about just letting ya'll find it, but those of you that post in brail, might not notice that the extra button says draft and not post.   ffsmiley
There is a setting I can enable, but concerned how it might effect the posting experience, and that is an auto save on the drafts, by setting a number of seconds for a post to auto save what you have so far to the draft.
I'd like to draft you guys to test this, then, give me an idea on the time we need to choose for auto save and to see if when it saves, it does not actually interrupt your posting, but then, if it does, it it worth it to know your work so far is saved.
So... ya'll are drafted.
Texas Ranger
Well, I'm here, so let basic training begin.  Nope, no draft button, free at last, etc.
Old Greenhorn
I enabled the autosave in my 'look and layout' screen. But no where can I find a "draft' button or option on the posting page. I have run out of things to click on. Where is this little bugger hiding?
I suppose that I was expecting to see that a "DRAFT" button had been added to the PREVIEW & POST buttons.  ??  Are you asking first or did I just not find it?
I occasionally will copy and paste a longer post/reply to my "word processor" to avoid it being somehow lost before I finish.  I will verify that it actually posted before I delete it in the word processor.
Old Greenhorn
I did something I never do, I went to the SMF help screen. Seems this is a permission that has to be enabled, but I am not sure if it is by user, board, or topic. At any rate. I can't find the little bugger so I'll wait for more info. Obviously I am missing something.
Okay...  I'm still not as smart as I thought I was a few moments please.
Ron Wenrich
Its a "SAVE DRAFT" button btwn the "ADD FILES" and "PREVIEW" buttons.  That's in the QUICK REPLY.
The shortcut is SHIFT+ALT+D to save draft.
I have the Admin's version, but that should be what it looks like if its working.
If you reply to a post without the QUICK REPLY, the "ADD FILES" button is dropped.  The shortcut is still the same.
WV Sawmiller
Jeff,
  I thought I have clearly told you and others in the past that my mental hard drive is full and for me to learn something new I will first have to dump some memory from somewhere else and it could be something like my wife's birthday that will get me in big trouble. :uhoh: ffcheesy
    Thanks but I don't know that I would use the draft button that much.
    Right now I type and post and when I re-read if I see I mis-spelled something or if I decide to add something I just click on the modify button at the bottom of the post and correct or add. Does that cause any problems? I suspect if I used a draft mode I'd still end up doing the same thing only maybe a little less often.
    On rare occasions if I am doing a long post I will type it up in Word or such then copy and paste it into the text on the post. Other than sometimes having to tweak it slightly such as indents or such that seems to work. Does that cause any problems to the system.
  Thanks again for the offer but unless the current way I am posting is causing problems or gets changed I will continue as now.
Okay, how about now?
Howard, you make some lengthy posts, and I gotta think at your age you could use a rest in the middle,at times. ffcheesy
The button says "save draft"
Old Greenhorn
OK, it's there now, and I tried it on this post.
Regarding the autosave question Jeff, if the autosave does the same thing as 'save draft' (i.e. going through a save cycle then popping up the message) then I would set that autosave out a bit say 5 minutes or so. Most posts that get 'lost' are the ones that take a long time to write (or so I have heard  :wink_2: ). Sometimes I will go have dinner before I finish a post. Those are the ones that would benefit most, I think. For quick posts, with a long delay, it won't even be used or become and issue. Just my thoughts on it.
Lets try that then. 300 seconds. Let me know if we get any unintended consequences.  Drafts will be saved a maximum 7 days.
I hope to start reincorporating some of our old lost functions this winter.
SawyerTed
I see the Save Draft button.
I clicked it.
It saved my draft.
It works...
I like it!
Now an auto paragraph button might help some Forumites.
Let me drop it to 30, and see if it gives issues. I usually loose the shortstuff.
Old Greenhorn
Very funny Ted. :wacky: But to be fair if you got look at my recent posts you will see that I have worked very hard and fairly consistently to put in the "Howard Spaces" and sometimes even section breaks. Geez, some guys don't even recognize when somebody is making an effort. taz-smiley
 I don't know how you can tell if the autosave is working. I am taking my time typing this (so Howard can read it) and I don't see anything indicating I have a draft saved. Maybe you have to manually save the draft first before autosave kicks in?  Lemme try that.
 OK, I clicked the save draft and got the alert and saved messages. Typing a little more here to kill time. Nope, not seeing any evidence of it being saved again.
SawyerTed
ffcheesy ffcheesy Tom, couldn't resist.  Just in fun, friend.
I guess I dont understand how the auto save works now either.
Texas Ranger
What do we have now? It looks like it needed to be enabled by theme. If it works I will enable for the premium subscription theme as well.
Okay, im going to test this.
It works! Found it in my drafts in my profile.
Worked on this end.  I saved a draft and found the new button in my profile.
You now should not have to save to have it save, if you dont hit post. Every 30 seconds it will save. Try making a post, wait 30 seconds and dont save. Maybe even go to a couple different pages, then suddenly remember you didnt post. Now go check drafts.
This feature could have prevented me from having "heartburn" a couple of times when I have done something wrong or maybe did not do something right and lost a reply causing me to have to go back and and try to reconstruct it.  It never comes out right the second time because that initial burst of memory is gone.
:thumbsup: :thumbsup:
This is our 25th year. Im looking to implement old guy mods and benefits. ffcheesy
