Weight per bdft of tulip poplar green
Started by Jim_Rogers, November 19, 2024, 09:43:01 AM
Jim_Rogers
Guys:
I was looking for the weight of tulip poplar per boardfoot when the timbers are green.
The red tool box doesn't show this species.
I did a google search and got 2.58 lbs but it doesn't say if this is dry or green.
Can anyone help me to understand the green weight?
Jim Rogers
Jim, how accurate do you need to be? In general, any weight estimate of green lumber is just that. If the tree grew up across the road down by the creek is vastly different than the tree growing on the ridge behind the house.
doc henderson
I agree, and since the majority of the weight of poplar is water (% MC can be over 100%) that means even more variability based on growth conditions/time cut down.
are you looking at shipping costs?
Quote from Furby in text message:
QuoteTulip poplar is in the toolbox, its 46 pounds cubic foot green weight. It's under log weight.
That is an approximate of 3.83lbs per bf.
Here Tulip Poplar is referred to as Yellow Poplar and is listed in the Red Toolbox @ 3.2 lbs per bf.
Jim_Rogers
Quote from: doc henderson on November 19, 2024, 10:59:23 AMI agree, and since the majority of the weight of poplar is water (% MC can be over 100%) that means even more variability based on growth conditions/time cut down.
No just green weight of timbers in a frame.
the tool box says yellow poplar is 3.2 lbs per bdft.
But is yellow poplar and tulip poplar the same species?
Jim Rogers
LINK
If you Google search Yellow Poplar it will take you to this same site.
That is what I always beleived, but that isnt scholastic info, just acquired.  Also called tulip tree,  although there is also an ornamental tulip tree that is definitely not a tulip poplar. ffsmiley
Ron Wenrich
My Wood Technology book has green yellow poplar at 46 lbs/cu ft.  That comes out to 3.83 lbs/bf.  12% MC is 30 lbs/cu ft. or 2.5 lbs/bf.  Yellow poplar and tulip poplar are the same species.
Rhodemont
  Liriodendron tulipifera—known as the tulip tree,[color=var(--color-progressive,#36c)][a][/url][/font][/size][/color] American tulip treetulipwoodtuliptreetulip poplarwhitewoodfiddletreelynn-treehickory-poplar, and yellow-poplar—is the [color=var(--color-progressive,#36c)]North American[/color] representative of the two-[color=var(--color-progressive,#36c)]species[/color] [color=var(--color-progressive,#36c)]genus[/color] [color=var(--color-progressive--active,#233566)]Liriodendron[/url][/font][/size][/color] (the other member is [color=var(--color-progressive,#36c)]Liriodendron chinense[/url][/font][/size][/color]). It is native to eastern North America from [color=var(--color-progressive,#36c)]Southern Ontario[/color] and possibly southern Quebec to west to [color=var(--color-progressive,#36c)]Illinois[/color], and east to southwestern [color=var(--color-progressive,#36c)]Massachusetts[/color], then south to central [color=var(--color-progressive,#36c)]Florida[/color] and [color=var(--color-progressive,#36c)]Louisiana[/color].
The [color=var(--color-progressive,#36c)]bark[/color] is brown, furrowed, aromatic and bitter. The branchlets are smooth, and lustrous, initially reddish, maturing to dark gray, and finally brown. The wood is light yellow to brown, and the sapwood creamy white; light, soft, brittle, close, straight-grained. Specific gravity: 0.4230; density kiln dried: 422 g/dm3 (26.36 lb/cu ft).  Green as sawed 45.87 lb/cu ft
My rafters are Tulip Poplar (as I call it, my forester calls it yellow poplar).  Tell you this first hand....it is way lighter than the red oak post and beams!!
Woodmizer LT35HD, EG 100 Edger, JD4720 with Norse350 winch
Stihl 362, 039, Echo CS-2511T,  CS-361P, MSA 300 C-O
Jim_Rogers
Thanks Ron and Rhodemont for your information.
My engineer said to use 2.25 lbs but I don't believe he is right. As all of you have said 3.83 lbs per bdft green.
I've used that in my design program so that it will automatically calculate the weight of the timbers.
Jim Rogers
