CSI Buck Saw parts
Started by Hogdaddy, January 22, 2024, 02:37:48 PM
Hogdaddy
 Where do you guys usually order parts from for a CSI buck saw? I never have had one apart, but believe I have one that needs bearings. Are they much trouble to change?
If you gonna be a bear, be a Grizzly!
doc henderson
we have two industrial supply houses and I usually get them from there.  take the bearing and they can cross reference them and you often get a better bearing than original.  assuming it is less than 30 years old. I am not specifically familiar with the CSI saw.
if you need more than bearings, I found this,
https://www.cuttingsys.com/parts.php
