Bandsaw mill plans?
Started by irishcountry, August 02, 2013, 12:55:26 PM
fishpharmer
Valley Ranch, welcome to FF.  There are several ways to accomplish castor and camber adjustment.  I used a "dual plane" hinged contraption on my moveable side.  The drive shaft side has pillow block bearings bolted to slotted bases. It took some shimming and sliding to get it adjusted correctly.
I am guessing your building to the Rake plans?
Look forward to the pics...
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
valley ranch
It comes up: Error there is no album where you are allowed to post a picture.
valley ranch
valley ranch
Darn ! It's a two post mill with pulleys. I'll have to have wifey help with pictures.
valley ranch
OK, I built this a while back, I just found I had this, Kholer 18, up on the hill. What I did here was from a picture on Diybandmill. I liked this type over the 4 posters.
Richard
valley ranch
I've looked around the forum but have seen no clear photos of an install of band wheels. Maybe I just don't know how to navigate the site yet. When people ask a question there are lots of answers but few pictures. Like I've said, I'll look around more.  I started the engine yesterday, sounds good. Thanks
Richard
Quote from: valley ranch on October 14, 2013, 01:40:26 PM
Well, looks like ya did good on the pics. Glad to see that.  8)
Knew ya could..  :)
WmFritz
I'll try to get some photos of my band wheel axle mounts tomorrow.
~Bill
2012 Homebuilt Bandmill
WmFritz
Will these help?
The first two pictures show an adjusting bolt on each pillow block on the drive wheel.
Here is the inside view of the drive pulley.
This pic shows the idler wheel. I only used one adjuster on this side.
After I got the wheels running true with the band, I haven't had to touch any of the adjustments.
~Bill
valley ranch
Thanks, I'll study these and see if I can visualize how to apply it to my tower. I installed one side, fixed side, pillow blocks and shaft. but I'm not happy with it, don't think it will be easy to adjust.
Did  you make you mill? Does the square tubing go all the way across the mill tower to the other side, to where the other wheel is attached? Thanks again.
Richard
WmFritz
Richard, I made my mill. The wheel assemblies are set on two 2" tubes. On the idler side, there are two 2 1/2 tubes that slide on the end for the band tensioner. There are two pillow blocks on each end.  I should've taken more pictures while I was assembling but I was rushing a bit.  :-\
I'll try to load the few I have that may show better detail.
~Bill
WmFritz
Here's my carriage in primer. The two tubes painted orange are for the wheel assembly.
Just under the c-channel you can make out the tensioner bolt.
Idler wheel
Drive wheel
Idler wheel
~Bill
valley ranch
Thanks, having these pictures will help. I'm stalled right now, I'll look over the pictures and such available to me and see if I can get things and myself together. Are those pulleys or bandwheel?
Thankyou Richard
fishpharmer
Here's a few more pics of a different design...drive side below
idler side pre paint, later modified.
Super high tech tensioning system...
improved castor/camber pictures
Hope that gives you some other ideas, shoot me a pm if you need some more pics.
WmFritz
 link=topic=68170.msg1045039#msg1045039 date=1381939771]
[/quote]
http://linnlumber.com/page17.html
I used the 19" bandwheels and 14" pulley.
~Bill
valley ranch
For the band wheel attachment I had planned to use, no photo just now, a single 3"X 3" tube with plate welded on the drive side with pillow blocks, on the adjustable side a single 3"X 3" X 1/4" tubing with 2 1/2" square inside, with a plate welded vertically on which the pillow blocks would be bolted. I figured on the first adjustment shimming and tilting the pillow blocks would do the trick.  I have this material ready to use.  I'm now thinking over if this would require me to adjust each time I change the blade. Hope you can picture this from my description.
Now I'm wondering if I should use two, 2" square tubes as many have done. Have you seen mills with a single ram on the adjustable side?
Richard
