Get the point
Started by Bruno of NH, February 13, 2021, 02:35:16 PM
Bruno of NH
Built my own stake pointer.
I have about $200 into it.
I landed some contracts for grade stakes.
It works good.
The i-beam horse is a strong base , no movement at all.
Should have used better materials,  but can always do it latter.
Southside
Looks great. Thought about a cover to drop over the cutter head?
White Oak Meadows
Bruno of NH
Southside,
Yes I'm going to look for a piece of expanded metal to bend around it.
stavebuyer
I'd think maybe just cover the top? I assume that throws some serious chips a full guard might plug up quick.
I like it as I am much handier at woodworking than metal working,
Bruno of NH
Stavebuyer,
I was thinking the same thing.
I have a couple of ideas.
It will chip up fast I would think.
Southside
Upside down 5 gallon pail with a slot in it for the shaft. The opening will be bigger than the bench so the chips will fall right out and you can pop it off to clean out a broken point.
White Oak Meadows
barbender
btulloh
I like it, Bruno. All you had to buy was the cutter I'm guessing.
HM126
Bruno of NH
I bought the cutter , cutter to shaft connecter , cord for the motor and paddle style safety switch.
A friend gave me the motor.
I ordered some lexan to make a shield for the cutter.
Bruno of NH
I'm going to make a lathe style chuck shield for the cutter head.
samandothers
Don't get your scarf or neck tie in it!
trimguy
Looks good. Is there money in cutting stuff for stakes or is this to use up " scrap " ? Just curious, it's been awhile since I bought any stakes but I remember them being pretty inexpensive. Well, everything's gone up.
mike_belben
You can bend lexan with a torch or heat gun if i recall correctly looks good bruno
Praise The Lord
Bruno of NH
Mike,
I'm going to try and bend it with a heat gun over a form.
Trimguy,
I can't sell red oak for some reason. I turn that and low grade ash logs into stakes.
tamarackman
Quote from: Bruno of NH on February 13, 2021, 05:47:25 PM
If you don't mind me asking, where did you get the cutter to shaft adapter?
Cheers
Bruno of NH
Quote from: SPDM on February 14, 2021, 07:17:26 AM
Cheers
Lumberjack tools website
Bruno of NH
My stand doesn't move a bit.
A company in NY makes them and the stand rocks and rolls  :D
tamarackman
Bruno of NH
I have been running the pointer all morning.
It's working great.
I'm glad I built it and saved some money.
Crossroads
Way to go! Point made 🤓
Bruno of NH
I'm very surprised at how well it works.
The base doesn't move one bit.
I watch a u tube of one made by a company out of NY state,  the base of that thing looks like it will fall apart.
I slide 5' oak 1.25x1.25 in like butter .
No clamps or anything.
Polish Hammer1
Same thing I did works just fine goes fast!
Southside
Tis the season.  Had 450 go out yesterday. I will get a picture of my set up.
White Oak Meadows
Bruno of NH
Can't wait
Would very much like to see other setups.
When I build my safety cover it will get hooked up to a chip collector.
Southside
This is my Shop Smith, I don't think this was an OEM attachment.
White Oak Meadows
