another table
Started by tule peak timber, September 15, 2016, 07:46:13 PM
tule peak timber
The start of another big table; a CA white oak crotch harvested from a freeway bypass in Willits, CA. these 4 sequential  slabs will be bookmatched, end matched into a large dining table. This seems to be the year of large dining room tables. Here's what I am starting with; the four slabs with about 2-1/2" of twist after months in the kiln. My motto: tame that beast!
The finish on this is spec'd high sheen so the joinery needs to be  dead flat. I hope I can pull it off.
This photo was taken from one of my forklifts from about 15' in the air. No drones around here. Cheers Rob
Looks like a real challenge.
Let the building begin!!!
 smiley_clapping smiley_blue_bounce smiley_bounce smiley_bouncing_pinky
Den Socling
That's pretty big all right but when we were installing a kiln for Pacific Rim Tonewoods, we met Bob Taylor who owns Taylor Guitar. They were drying a slab for Bob's new dining table. That slab was 34' long. But yours will be more work.
21incher
Can't wait to see how you flatten them. Thanks for sharing. :)
69bronco
lowpolyjoe
Looking forward to following your progress  :)
Bill Gaiche
May have to park the fork lift on them for a few months. I bet you have a good plan though. bg
tule peak timber
Yes, that is literally what we do with this Cat forklift. I started flattening slabs by this method a year ago in response to market demand. In this pic the Cat is getting new brakes this morning. A little unorthodox but it works every time.  Rob
Ljohnsaw
Den Socling
Here's a picture of Bob's table. A lot less work than Rob's although it did take two fork trucks to lift it. I wonder if they ever got it in his house?
That's Bob in the "middle".
tule peak timber
After the individual slabs get sat on by the big cat, we pin them to a true table and begin filling the cracks one by one with a combination of different viscosity epoxies. This is not a fast operation and takes many days if you do it continuously. Building a single table at a time, you would go broke, so you have to have a continuous production line of tables going all the time. This method of flattening a slab is a lot like a Dr. realigning a bad break in an athlete's bone.
A quick view of one of the true tables with continuous in process table tops. There are tableslabs backed up in the kiln, tabletops tilted up against the walls, tabletops stacked up in the interior shop and we recently added 2 more flat working table areas outdoors to keep things moving.
After the reasonably flat slabs are set up, they are hand planed by a skilled person or me. At this point, we have removed very minimal material and bring the slabs to where we want them within sanding range.
If the slabs are small enough to fit through a planer or a wide belt sander, they can be positioned on a sled that will give you one flat reference surface on the slab. Again, removing minimal amount of material. These pics are of a quick and dirty sled I built today lofting off of one of my truly flat tables. Notice in the last photo the little bit of overhang on the top piece of MDF. This is where you can shoot screws through to secure the slab. If the slabs are too big to fit through machinery, we go to belt sanding, then a monstrous orbital sander. Rob
azmtnman
I am not any type of real finish woodworker......yet.
So I am asking to learn here--would a floor sander work for big slabs like that?
1983 LT 30, 1990 Kubota L3750DT, 2006 Polaris 500 EFI, '03 Dodge D2500 Cummins powered 4X4 long-bed crew cab, 1961 Ford backhoe, Stihl MS250, MS311 and MS661--I cut trees for my boss who was a Jewish carpenter!
tule peak timber
Never tried one, but I don't see why not. Rent before you buy ! Also the floor sander does not give you any reference as it is meant to go on an already  flat floor. Rob
plowboyswr
Just an ole farm boy takin one day at a time.
Steve
Oh Wow Rob, you are a Table Whisperer Extraordinaire' !!!
Ljohnsaw
Rob,
I don't quite get the MDF/foam sled in the last few pictures.  How do you use that in your flattening operation?
tule peak timber
I will take pics this next week of the sled in action.  Rob
Looks like you have done that a few times.  ;)    ;D
lowpolyjoe
21incher
Rob it seems like I learn something new from everyone of your posts. Thanks for the education. 8)
tule peak timber
Talk about education,,,I'd like to have Lynn (Magicman) visit here and teach my milling crew how to cut wood, that's no joke !  Rob  ;)
red
Mr Magicman is a Legend . . . and he gets paid by the Mile
Magicman.  Have Sawmill Will Travel.
Remember Paladin?  :D   https://en.wikipedia.org/wiki/Have_Gun_%E2%80%93_Will_Travel
Unlike Paladin, he just Saws Em and Leaves Em.
