Band mill Router Plane
Started by Kbeitz, January 25, 2018, 01:09:09 PM
Kbeitz
It's a puzzle with the blades I have been finding. They come sharp and work great for a while. I don't sharpen them right like other people do but what I have been doing works for me. I still use a dremel and a hand set tool without ever taking the blade off the mill. Once I put a blade on the mill it does not ever come off until it snaps in two. I've sawed a lot of lumber like this and i know it saved me a ton of money.
Love machine shop work
and Wood work shop work
And now a saw mill work
Peter Drouin
starmac
I understand what you are talking about, but I would be tempted to buy a band and resaw a slab or two and see if it doesn't save you a bunch ow time with your planer.
I know different species of wood saws different and I have only any experience with our spruce, but it cuts nice and flat, every now and then I will hit a knot that must be harder than others and cause the blade to rise a little, but mostly they are dead on from one end to the other.
you guys have a lot of nice hardwood to work with, so it may be all together different.
Kbeitz
Thanks. I have a box of new 4 degree blades that I use and I just finished up a box of 7 degree blades. Now I got around 40 junkies to play with . I have lots of time to do this and it's all just a hobby for me.
21incher
Great job, looks like it works good. Infinity makes a 2 inch dado planer bit that is supposed to leave a very smooth finish when used on slabs. It has carbide on both the face and edge. I think it should be turning about 18000 rpm for the best cut. One thing I find on small slabs with my cnc router is the dryer the slab is the less fuzz you see from the cut. Thanks for sharing this journey. :)
Bruno of NH
Kbeitz
Well it's working great. The only problem I had so far is the one clamp I had a rubber foot glued on the end of it using contact cement. It would not hold.  It would just slide off. I fixed it with JB-weld. Now it's holding. I just wish it was a little faster. The slabs I'm working needs about 1/2" taken off each side to flatten them out. To take that much off takes around 10 minutes each side.
Ljohnsaw
Well, can you take less of a bite and move faster (more than twice the speed)?  Can you alter the pulley setup and boost your RPM?  Do both?
Crusarius
looks like you need a 6" cutter. That would speed it up alot. Course those are really expensive
Kbeitz
I did my fist hard wood today. I had some spalted Maple. It worked so much better than I hoped for. I was thinking that the hard wood would be so much harder to cut. I think it cut better than the White Pine.
Crusarius
any tearout on the edges? looks great.
Quote from: Kbeitz on March 17, 2018, 07:44:53 PMI just wish it was a little faster.  To take that much off takes around 10 minutes each side.
Considering what you are doing, I would think that 10 minutes per side is very acceptable.
Kbeitz
Quote from: Crusarius on March 18, 2018, 02:25:53 PM
Very little where the wood was kinda rotten. Nothing where the wood was good.  I really want to buy a good index cutter for this machine.
  One thing that really surprised me is how quite this is. If I only cut 1/4" off the slab you cant here it. The motor is real quite. The spindle makes no sound and the cutting of the wood males no noise. The only thing I here is my cable rubbing the side of the pulley that moves my carriage. When I start cutting 1/2" or more then it makes some noise.
Crusarius
That is sweet. that came out really nice. it makes me want to build one. I should probably finish the mill first.
Is it wrong I already started design V2 before finishing V1?
Kbeitz
Quote from: Crusarius on March 19, 2018, 07:35:48 AMIs it wrong I already started design V2 before finishing V1?
It will never end. You will keep thinking of changes to make. Especially if you hang around here and get more ideas.
Crusarius
catalina
Quote from: Kbeitz on March 14, 2018, 12:22:42 PM
You'r not that far away. Stop in...
only about 240 miles, lol. Next time Im up that way Ill give you a shout! Gene
Kbeitz
Quote from: catalina on March 19, 2018, 01:50:15 PM
Please do that....
Quote from: Kbeitz on March 18, 2018, 08:20:25 PMI really want to buy a good index cutter for this machine.
I was looking at pictures of that cutter.  I think you could cut the insert seats on your Bridgeport with a dividing head.  Probably do it on a rotary table, just more setup time.
Toolstoday had some smaller (and cheaper) index cutters.
Kbeitz
Quote from: Larry on March 19, 2018, 09:27:22 PM
I see they have a nice one for $252.68
Kwill
Quote from: Kbeitz on February 06, 2018, 10:09:21 AM
Putting the acme rods on today.
Hey kev is this 3/4 6 acme rod?  What holds the brass nut when you lower it? Where did you find the brass nuts?
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
Kbeitz
Kwill
Kbeitz
Quote from: Kwill on March 29, 2018, 07:15:10 PM
Ok I need some 3/4
Lots of 3/4" on E-bay. Just make sure you get the same cut nut. Comes in 1-2 or 3 cut.
Slow medium or fast.
Kwill
Quote from: Kbeitz on March 30, 2018, 10:14:17 AM
Ok I need some 3/4
I looked on there and couldn't find any brass 3\4 6 acme nuts
