Air drying some walnut slabs
Started by busenitzcww, June 03, 2019, 10:31:41 PM
busenitzcww
Nothing like that feeling of getting your wood stacked and under a roof.
Do you guys spray walnut with bora care? I've got a bunch of ash coming up that I want to treat but wondering if I should have done my walnut too? Other species? I have some bur oak, locust, coffee bean, mulberry,and hedge. Can you spray it good enough after it's stickered if you see bug action? Should have thought this out before I moved all these 3' x10' slabs  :)
very nice.  dark, but very nice!!!
YellowHammer
I don't spray my walnut, bug don't seem to like it much.  I once had termites build a mud tunnel over some walnut to get to some oak.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
I don't spray walnut either.  PPB's will get in walnut sapwood though.  I have had that happen more than once.
scsmith42
Ditto Danny and Robert's advice.  If you spray it, don't use Bora-care on green lumber.  Use Timber instead (cheaper).  Bora-care is best for dry lumber.
If you do spray it, typically you only need to spray the bark and sapwood.
Tom's 3638D Baker band mill
firefighter ontheside
Interesting info here.  I've been spraying everything , but maybe I will not spray walnut, at least not the heartwood.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
just picked up 1.5 pounds of tim bor today from the pest guys.  plan to make a gallon in a sprayer.  any other tips.
Use hot water to help it dissolve.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
GeneWengert-WoodDoc
It will be important to cut and then fit together almost right away, as it is not uncommon to have the logs warp and twist as they dry and then the t&g will not align.
123maxbars
Sawyer/Woodworker/Timber Harvester
Woodmizer LT70 Super Wide, Nyle L53 and 200 kiln, too many other machines to list.
outofthewoods
Youtube page
Out of the
Marshall7199
Good looking slabs. not to be too nosey but what is the white material under the concrete blocks?
Rookie learning from the masters.
DWyatt
Looks like limestone screenings/sand to me.
K-Guy
@Marshall7199
It is that beautiful Kansas oceanfront beach sand. :D ;D
Nyle Service Dept.
- D. Adams
YellowHammer
Looks like a spilled bag of grits.
YellowHammerisms:
busenitzcww
Quote from: Marshall7199 on July 22, 2019, 10:24:38 PM
Thanks! It's just limestone screenings from the local quarry. I'm kinda wishing I'd had just poured concrete and then I wouldn't of had to level all by bases, or at least been really close. I started putting cinder blocks down and then shimming a 2x6 on top of that for my pallets.
