Author Topic: power outage with gasification boiler  (Read 376 times)
Offline bsting
« on: December 09, 2019, 05:11:33 AM »
Just invested in a Crown Royal 7300E gasification boiler. The area we live in is prone to multiple day power outages in the colder months. Next season will be set up for standby power but until then if the lights go out..... Is there any procedures to follow with the boiler or anyone else had to deal with this situation? Thank you in advanced.
Offline jerry sundberg
  • not new here more seasonal
Re: power outage with gasification boiler
« Reply #1 on: December 09, 2019, 05:30:08 AM »
What I have done is I got a propane powered 3500 watt generator as a stand by. made up a couple of 12 gauge cords with male plugs on both ends. Just make sure to throw main breaker so you don't back feed on the line. Run only the nessesary  items.
Farmall  man
Offline E Yoder
  • Heating with a HeatMaster G7000
« Reply #2 on: December 09, 2019, 06:25:15 AM »
If the power goes out it'll shut down. Might boil a little if it was in the middle of a high burn. But not enough to hurt anything.
A small portable generator is what I use.
HeatMaster dealer in VA.
G7000
Offline bsting
« Reply #3 on: December 10, 2019, 05:06:08 AM »
Thank you for the input guys. My concern is quote from the manual "The Crown Royal Stove shall have provisions for preventing, of adequate water capacity within the boiler to prevent damage from loss of circulation due to electrical power failure."  If the water is not circulating then are they saying possible boil over? Thanks again.
Offline E Yoder
« Reply #4 on: December 10, 2019, 05:11:06 AM »
Confusing language to me- but yes, it appears like they are concerned about it boiling with no flow.
I've seen it happen, but not enough to hurt anything.
G7000
inside wood gasification boiler
Started by GAV64 on General Board
Last post November 10, 2004, 09:39:39 AM
by EdK
Power outage
Started by Ohiowood on Firewood and Wood Heating
Last post February 02, 2012, 11:01:13 AM
by wayno12
Power outage?
Last post August 15, 2003, 10:02:15 AM
by johnjbc
Higher power bill after outage?
Started by coalsmok on General Board
Last post September 02, 2016, 10:09:22 AM
by Ox
