Author Topic: 064 oil pump  (Read 404 times)
Offline stan064
064 oil pump
« on: June 06, 2020, 04:48:40 PM »
i need to put new oil pump and nylon gear  on my 064,how do you get the oil line off and new 1 on ,super stiff,been pulling on the line with pliers ,dont want to force it,anything else to look out for,thanks
Offline sablatnic
Re: 064 oil pump
« Reply #1 on: June 07, 2020, 03:14:47 AM »
I normally cut it off, buy a new one, which I heat before I put it on. The nipple in the outlet end I heat too, while pressing it into the line. I use a soldering iron for pressing, which I switch on when I start pressing.
They could easily have made it a bit smarter!!
Offline jrent
  • Member*
Re: 064 oil pump
« Reply #2 on: July 18, 2020, 12:46:45 PM »
Use a heat gun, but don't get the line to hot as it will collapse.  You can pull it out while limber.  Best to leave in and when you get a oil pump (rare) just reattach.
Offline thecfarm
Re: 064 oil pump
« Reply #3 on: July 19, 2020, 06:49:44 AM »
jrent, welcome to the forum. Whatcha got for a saw? or saws  ;D
Diesel Primary pump from tank to injector pump
Started by Ironwood on General Board
Last post January 25, 2005, 08:12:11 PM
by Ironwood
How big should my pump be?
Started by CX3 on Forestry and Logging
Last post September 25, 2010, 08:28:53 PM
by madmari
question
pump
Started by dnsnook on Forestry and Logging
Last post February 16, 2012, 04:24:40 PM
by snowstorm
Well Pump
Started by Raider Bill on General Board
Last post August 02, 2007, 07:56:15 PM
by Slabs
