Planting During Drought
Started by DonW, April 02, 2021, 10:17:51 AM
DonW
in May I will plant 120 conifers, spruce and pine, which will be a first for me at such a scale so I would appreciate any advise on initially setting the trees are in the ground, particularly because the conditions will not be ideal since it is in the midst of a multi year drought with poor outlook for the coming year.
The spot is on a north oriented slope where I've noticed other pines or spruce getting a foothold among a predominance of Juniper.
Hjartum yxa, nothing less than breitbeil/bandhacke combo.
BradMarks
Best thing you can do is remove competing vegetation from your individual planting spot(s).  Bare soil holds more moisture. A grass or forb cover will suck the moisture from the soil. Polymer additives in the planting hole, which retain moisture, is another technique, but not too much to cause heaving. For me, I stick to good scalping of the veg.
Southside
Respectfully I am going to disagree with you on that. Bare soil gets hotter, dries out more, and invites weeds.
On the other hand soil covered with a mulch product, chips, dead grass, etc will keep the soil cooler, hold more moisture, reduce erosion, and capture and hold any rain that does fall.
DonW
Quote from: Southside on April 02, 2021, 01:14:37 PM
My impression is that this is a consensus view. On the other hand the consensus seems to be geographically and demographically centered and I am located far from the fringes in the mountain/dessert so it was interesting to get this other view, a view I can see some justification in. Where water is scarce, competition can better be minimized.
Another pointed question I have, is it silly to ask if these seedlings require a watering at planting?
BradMarks
Of course we can disagree ;D  My reference was only the comparison to bare ground versus that with vegetation. Scalping a small area just enough to plant the tree will not get it done. It should/must be large enough to eliminate competition. Mulching is a great idea, using mats, or chips as mentioned can work, just more costly and time consuming. I would shy away from sawdust, wood shavings, as they deplete soil nitrogen as it decomposes. We own "drought" property, full on east slope pumice soil that loses moisture in a hurry. Whatever snow melt we get to replenish the moisture is it. Our seedling survival has been pretty good. Might add I was a reforestation contractor for 20 years in a prior life.
DonW
Quote from: BradMarks on April 02, 2021, 01:51:23 PM
A bit similar, soil, orientation, water and so on and so on. In particular encouraging to read of pretty good survival. To be honest I'd be pleased with fifty percent up to a decent age.
Southside
The drier you are the more critical it becomes. Look at what happens to over grazed dry ranch land in the high desert, it becomes sage.
clearcut
University of California has recently released ( Press Release )
Quote"Reforestation Practices for Conifers in California", a practical manual for landowners and managers that explains the why, where, who, when, what, and how of getting sustainable forests back into California's diverse landscape. It is available now for immediate viewing and downloading for free on the Forest Vegetation Management Conference's website: www.fvmc.org.
May have some useful ideas.
Carbon sequestered upon request.
DonW
Quote from: clearcut on April 02, 2021, 04:22:53 PM
I think so, like getting ahold of a hoedad.
Thank you for the reference.
BaldBob
If at all possible plant your trees immediately (as in less than a week) after the snow is off and the ground is no longer frozen. If there are stumps or down logs, plant on their N or E side so the actual planting site is exposed to less direct sun. On doughty sites, grasses and shrubs are far more efficient in taking moisture out of the soil than is direct solar radiation - especially on N slopes. So reducing  competitive vegetation is critical. Given that the area is a fairly dry, even in a non drought period, it is super critical that your planting stock comes from the same seed zone and elevation as the planting site. Watering that many trees after planting is impractical, but it is imperative that the roots be kept moist right up to actual planting. If they are allowed to dry out, you are essentially  planting dead seedlings so avoid planting in hot windy conditions - especially if planting bare root stock.
Good luck.
DonW
Thank you for your detailed instruction B.B. very helpful to read it indeed. I'm not sure what it indicates entirely but since a few have pointed to a need for clearing vegetation I thought to make the condition more clear. Though the slopes, fairly steep in fact, are well wooded with Rocky Mountain Juniper, (Juniperus scopulorum) stands on what I'd call rocky ground, there really is little vegetation besides a few sagebrush, a bit of moss now and then a cactus or two. I don't know if this raises any particular points that need consideration in addition to what's been brought up. I will say that the sparce pine and spruce growth that's there between the Juniper looks like it struggles, though in comparison with other sections more exposed it's a surprise noticing the shear number of non-juniper conifers growing in that particular place.
BaldBob
Your further description tells me it's an even more droughty than I suspected. Juniper can over time almost totally dominate sites like you describe. That species is very efficient at sucking up the available moisture.  If you want to be reasonably successful establishing much PP & DF, you will need to kill some of the Juniper.
DonW
So it would be a misconception to regard the juniper as pioneer that would give way as pines grew to shade them out?
BradMarks
DonW:  You would be better to fell a juniper and plant a tree in amongst the branches/bole of the juniper (as long as it is stabilized).  You have then eliminated the moisture drain(juniper), provided some shade for the seedling, and have made it difficult for any deer to get at the seedling. I have been involved in scenarios like that. A lot of work, yes.  You mentioned steep, how steep?  To me, less than 40% is not that steep.
BradMarks
Forgot to say that seedlings we have planted on our pumice ground were bare roots with 12" length. I think the root length actually helped as it required a deep hole. We shovel planted. Often times available container stock will be only an 8" plug or shorter.  Advantage with container stock is better root/top ratio, with roots ready to grow. Disadvantage is not planting deep enough to stay in the moisture zone.
DonW
Thank you Brad, that gives me a concrete plan of action. Very helpful, novice that I'm in these things. Because my first choice of bare root stock was not available I chose for what's called Large Tube, (I can only imagine it) and am counting on this form providing added protection from foragers in a way this bole will do.
I anticipate planting with a hoe- like implement to loosen somewhat and get in amongst  rocks, and shovel for what I guess is a fairly long root.
After spending some time with my boots on that ground, as they say it, yesterday evening I took a longer perspective and can make a guess that the slope is in the 40 - 45 degree range. I think it accounts for the lack of vegitation since as the ground flattens it is blanketed with new growth. It's coming into a real pleasant time here now through June.
BaldBob
40-45 degree range or 40-45% range? Big difference. 45 degrees is 100%  and extremely difficult to walk on. 40-45% is considered fairly steep and is not ground most people would consider using ground based equipment on.
Juniper does not fall in the category of a pioneer species  even though it isn't especially shade tolerant. On dry sites where it is present it is extremely rare for other species to establish within an individual juniper's area of influence and end up overtopping the juniper.  In other words if juniper is the first tree species to occupy a site it will continue to dominate the area it occupies until something (fire, man's activities) kills it.
Brad Marks advice is dead on.
DonW
This is all very educational for me. Remember I am used to a completely different environment coming from Holland where almost the opposite conditions occur. Rather than lack of water it is an over abundance and something like the grade of the land is an irrelevance since much of the land is reclaimed sea bottom. I lived on a mound built up by medieval monks to keep their feet dry  , so thanks for setting me straight on things.
My determination for the grade came by imagining a horizontal line at the base of the hollow, then a point at the top of the ridge with a line from creek to ridge representing the angle of the rise. I can tell you this, no machine would be operating on this terrain.
 Well I can always use a good excuse for chopping trees, it looks like I've got it with the added benefit that it'll give me some fencing and even potential building material, if not firewood for next year. Only problem is with no horse, getting the wood out.
BradMarks
Is it labor of love or love of labor ;D
BrandonTN
Control the competing grasses, forbes, etc. Plant in partially covered microclimates such as on northside of debris. Get in the ground as soon as soil temps are 40ish degrees. Avoid j-rooting.
Juniper is growing on same site as spruce?? I would think juniper was at lower elevation. What species of pine?
Forester, Nantahala National Forest
