Chain sharpener?
Started by Ranger8006x6, July 28, 2021, 01:28:55 PM
Ranger8006x6
Hi folks. I have a Stihl 026 and I just purchased a MS 261 C-M saw and I'm looking for a chain sharpener. What are your thoughts. I pay $60 or more to have my chains sharpened and would like to do it myself. Thanks
that sounds like a lot.  I think I paid 10 or 12 bucks.  I bought a Stihl sharpener about 8 years ago, so I have been doing my own.  it is expensive however.  I think I paid 600$ then.  some get by with a harbor freight one.  I am sure prices have gone up.  I am sure 30% of what I paid was for the orange paint.  I got the rivet press and spinner, but have never used them.  My favorite dealer (Amish) is a 20 minute drive one way, so the time cost was the issue if I dropped off and picked up.  I prob. have over 30 usable chains.  I have a few special chains like the skip chain for my 880 and the 5 foot bar, so I can sharpen at home.  as an aside, when my parents passed, Each of us 3 boys got a decedents IRA passed down.  It grew for a few years, and then as part of the rules, we had to take out a dividend.  the check comes at the end of each year, so I buy something as a Christmas gift from my parents.  that was part of how I justified paying the Stihl price.  It works well, but I am sure there are middle of the road ones that work well, and cost somewhere in the middle. :)
sawguy21
How many chains get done at a time for $60? A decent bench sharpener such as Oregon is not going to be cheap and you will be disappointed in the results until you get the hang of it, practice, practice, practice. And be patient, if the cutter turns blue it is overheating. There are manual bar mounts that take a file but again practice makes perfect.
axeman2021
I am guessing that I don't sharpen as many chains as you do, so I have a Stihl 2 in 1 hand chain sharper and it works for me.
421Altered
Welcome!  Several years ago I bought a Oregon grinder and learned to use it.  Like sawguy says, it takes practice to learn to use it and get good results.  I also bought the CBN wheels, not cheap, but worth every penny.  They keep from over heating the cutters, and sharpen much faster, although the finish is rougher.  However the rough finish does not affect it's cutting ability.  If you will do a search on here, there is lots more info on sharpening chains.
everyone is correct.  when I got mine, boy I wanted grind that chain and make it perfect and sharp.  then I was throwing sparks (good), seeing the metal turn red and be blue when it cooled (bad).  it looses temper and hardness.  the Stihl guys said it is better to "bump/bounce" the grinder for an instant, and hit it several times as need, take of the bare min. to get a fresh face on the cuter and most important the very leading edge be sharp.  if the chain is overused and dull, it may take several rounds with adjustment of how far forward the cutters are relative to the wheel.  it is good to have a sharpener so you can sharpen them often without feeling like it has to go to the shop and cost money. (the tendency to use until nearly ruined).
lxskllr
You weren't really clear on what you meant by a "sharpener". If you mean a grinder, getting something decent will set you back pretty good money. Depending on how much work you do, it might not be worth it. The 2 in 1 was mentioned above. It's reputed(I haven't used one) to be easy to use, and give good results for about $40.
I agree I think a file system is a good and affordable place to start.
Upton44
My stihl dealer charges 8 to sharpen.
yes, and it depends on the length at mine.
Greenhighlander
Congrats on the new saw .
Since getting it I have become a huge fan of Granbergs precision grinder .  Once you get the hang of it , it does a really good job and is fast.  The grinder wheels last longer then I expected before needing to be changed too. Using the coolgrind sharpening lube helps with that.
Old saw fixer
Doc, did you get the Stihl USG sharpener?
Stihl FG 2, 036 Pro, 017, HT 132, MS 261 C-M, MSA 140 C-B, MS 462 C-M, MS 201 T C-M
Echo CS-2511T, CS-3510
Logrite Cant Hook (with log stand), and Hookaroon
JJinAK
All good advice on here so far.  I think I will add that learning to hand sharpen helps you to "understand" the chain a bit more.  I recently bought the Oregon 520-120 grinder and I like it.  There is definitely a learning curve, but I found it helps to apply some of what I learned when filing by hand.  What to look for on the tooth, stuff like that.  I have handed down a saw to my oldest son, and I'm teaching him to start with filing by hand.  He's getting pretty good at it, and he's learning about top plate length, gullet depth, and such.  I haven't yet tried the CBN wheels, but it's on my list.  I also agree with the others that $60 to sharpen chains is steep, unless you're getting a dozen of them done at a time.
JaJ
MS461
MS362
YellowHammer
I've seen very skilled people hand sharpen a chain by eye and its be as good as anything I've done with a machine, or by hand.  I've also seen people sharpen by hand and ruin a chain, and I've seen people sharpen with a grinder, a Dremel, all kinds of gadgets and either do a good job or ruin a chain, take your pick.
My personal preference is hand file or use the Stihl 2 in 1 for quick field sharpening, and then, after a few touchups, (or a bad rocking), I reset and normalize all the angles, lengths, rakers, etc with a "real" grinder, (not HF, I've had one, and threw it out).  I use a Stihl USG grinder for that, such as used and ordered by my local dealer, and have sharpened many, many chains and it still operates as good as new.
So I prefer using both techniques.
Here's a good video, it's for a Stihl grinder, but the technique works, would apply to any decent grinder.
Stihl USG on damaged chain - YouTube
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Tacotodd
Yeah, I'll take my hand sharpening over machine. The cost, time involved, and taking off the bar, putting back on, and other stuff that I haven't thought of yet.
It's also a good time for personal assessments like: hydration, hunger, what have I REALLY got left to do, stuff like that.
It took me a year of trying quite frequently (2x week) to become good at it but I'm happy that I did. And that's just normal old round filing (I've yet to try my hand at square, that's completely different).
Trying harder everyday.
   I am a big fan of the 12V handheld sharpener using little stones like the one listed here. It has an angle guide to cut the tooth angle you need.
Amazon.com : Oregon 575214 Sure Sharp 12V Handheld Chainsaw Chain Sharpener/Grinder, red : Garden & Outdoor
   I have tried Oregon and Sthil and both make good 12V sharpeners but I find the Oregon sharpeners have a better design because the switch is on the box for one-handed use while Sthil puts their switch on the cord and it takes 2 hands to turn on and off. Also the Shtil models use only Sthil stones that are threaded. The Oregon sharpener uses either the Sthil stones or unthreaded stones from any provider. I keep my sharpener in an old ammo can with my other tools and sharpen my chains on the saw in the woods any time they get dull or I nick a rock which is real common in WV.
HemlockKing
I use what's called a North Carolina chain sharpening machine. Basically
My arm. A bare round file, and little effort and sometimes
Cussing. It works good. Sometimes
Pouring coffee down the intake helps
A1
snobdds
At one point in my life, I thought I needed the proper tool for sharpening a chain.  This only lead me down a path of owning every single chain sharpening tool known to man.  Even after all this investment, my chains were still not as sharp as I thought they should be.  It was so bad that there was a point I would just buy new chain instead of sharpening it.  I must have a couple thousands of dollars in stihl chain, enough for my lifetime and my kids life time.  Then,  I saw some famous woodcutter on Youtube about hand filling.  I tried it...now at first I was not very good.  But I'm stubborn.  I kept at it and after about the 6th time doing it, I started to see nothing but big chips, no dust.
My cabin has a lot of rock, even when I try not to hit rocks, I do.  It gave me lots of practice to fix rocked chains.  I can now sharpen a chain in about 5 minutes and I enjoy the rhythmic motion.  I look forward to getting up early at the cabin, getting some coffee and going down to my little shop to sharpen chain for the day.  It's a great way to start the day.
I'm with YH, proper technique is key whether hand filing, machine grinding or something in between. Except that HF "thing"- I don't think any technique can make it sharpen a chain correctly😬
lxskllr
Just for the sake of discussion; what does the HF grinder do poorly? What I'm wondering, is could it be supplemented with more "premium" parts to make it acceptable?
It is made with clunky stamped parts.  so if you try to adjust it, the angle marks on the gauge are fuzzy and the wing nut locks will sag and not stay where adjusted.  there are HF tools I would not be without, or if an only used once specialty tool might get by.  or something you cannot afford but need for a project.  they are better than nothing.  may be under powered and paraphrased copies of other units.  not as precise.  I doubt that the quality increase of Stihl per penny is all that great either since they are so expensive.  get the best you can afford, and relative to the number of chains you will sharpening.  I have over 10 saws and 40 chains or more of all sizes.  it is a round trip cost of 1.5 hours to pick up and drop off, and 5 chains would cost 40 bucks.  I plan to use it and my saw the next 20 years and if it breaks, I can get parts.  so the cost made sense.  I got it with money left to me from my parents so I did not want to honor them buying junk.  it is a personal decision.  a cheap one can be replaced and a good one has parts available.  at some point we all buy something and use it.  good luck.  my friend the cardiologist has 2 saws and a HF sharpener and is happy with it.  cheers
lxskllr
I was curious. I'm not at all interested in a grinder. I like hand sharpening. You could give me the best grinder in the world, and I'd say "Cool. Thanks!", and it would never leave the box, though I might fire up a fully robotic grinder just to see it work.
as you say for the sake of discussion, how about a file adapted to a Sawzall or jig saw so the motion is powered and the grind is by round file.  seems most files cut front to back, as the small 12 v grinder rotates a stone.  I have used them all and they work.  (not the saws all yet to be designed version).
YellowHammer
I think that the most accurate system I have used is the Timberline, which is a carbide mill cutter that is guided by a precision machined jig.  The carbide is turned by a hand crank, is very accurate, and make the teeth more than razor sharp.  However, it's slow as Christmas, and is a hand cramper. I eventually mounted the carbide cutter in a battery operated drill and that sped things up.
One of the biggest issues I personally have had with hand sharpening with a bare file is keeping the teeth at the same angle (not too hard) and keeping them all at the same length (more difficult), especially if the chain has been hand sharpened a half a dozen times.  It's also important, more so than I used to think, to keep the rakers at a constant and correct length.  I used to free hand hand file them, but I really like the Stihl 2 in 1 system because it will dress them to the correct length.
If the left and right side teeth aren't symmetric, the bar will wear unevenly, and over a period of time, the bar will cut slight curves, and power is robbed as the chain links bear on the side of the kerf when cutting big logs.  I do use a bar dresser, but I have found that for me, after a few good handsharps, I'll run the chain through the grinder to clean everything up, and life is good.
I have used several grinders, but the main reason I like the Stihl, besides that fact that its main joint is as tight as it was the first day I bought it, is that it puts in the little double compound angles that Stihl chains use, and I have found that it makes a difference I can feel when I'm bucking log after log on the mill yard, vs just the 30° or so cutter angle.
YellowHammerisms:
HemlockKing
Quote from: doc henderson on July 31, 2021, 01:28:32 AM
Would be hard because you’d be ruining your new sharp edge every time the saw comes back, you’d only want it touching on the forward stroke. Even though it doesn’t cut on the back stroke I’d think it would still ruin the edge possibly
A1
