Author Topic: Sawdust packed in cut  (Read 1087 times)
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Sawdust packed in cut
« Reply #20 on: August 05, 2021, 07:43:27 AM »
   Ain't that the formula for curin' concrete where the V= voltage and the R = Readymix? ::) No wonder my foundations keep cracking.:D
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #21 on: August 05, 2021, 08:33:51 AM »
In a circular toroidal section, the volume, V is:
V=2*3.14^2*r^2*R
The math speaks for itself.
Yep, saw it right off. Didnt put enough dirt down.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #22 on: August 08, 2021, 08:46:17 AM »
Kenmac,
what are the new blades set at?
how wide and what is the material you're sawing?
packed sawdust is often a result of too little set,
D
Offline KenMac
  • I'm new, but don't feel so new!
« Reply #23 on: August 08, 2021, 03:38:34 PM »
New blades are set at about .020 to .022. If they are near .018 or so I don't set them the first time. My resharpened blades cut good generally.
Cook's AC3667t, Cat Claw sharpener, Dual tooth setter, and Band Roller, Kubota B26 TLB
Packed sawdust in the cut and hard to push.
Started by losttheplot on Sawmills and Milling
Last post July 28, 2011, 06:19:27 AM
by ladylake
Norwood ML26 - Roller packed with sawdust/oil
Started by Woodsrover on Sawmills and Milling
Last post June 20, 2012, 09:00:58 PM
by Woodsrover
Packed to go, well, hope so...
Started by Woodwalker on The Outdoor Board
Last post October 16, 2011, 12:15:21 PM
by Chris Burchfield
packed up and moved out
Started by Engineer on General Board
Last post January 26, 2008, 11:18:04 AM
by Engineer
