Author Topic: pump  (Read 829 times)
Offline dnsnook
pump
« on: February 16, 2012, 08:45:37 AM »
was wondering if a hydraulic pump on a skidder is the same on a fishing boat . if they are not the same and they pump the same gmp , what is the difference . i was also trying to find out if you put a little bigger pump on will it do damage to anything . thanks .
Offline snowstorm
Re: pump
« Reply #1 on: February 16, 2012, 04:24:40 PM »
pump on the pot hauler? could be. some used to use vane pumps on the haulers. adding gpm can speed things up and can also cause too much heat if going too big
Diesel Primary pump from tank to injector pump
Started by Ironwood on General Board
Last post January 25, 2005, 08:12:11 PM
by Ironwood
064 oil pump
Started by stan064 on Chainsaws
Last post July 19, 2020, 06:49:44 AM
by thecfarm
Enough pump??
Started by overclocking on Firewood and Wood Heating
Last post February 16, 2016, 10:19:02 AM
by overclocking
bad Pump?
Started by stumper on Firewood and Wood Heating
Last post November 24, 2018, 07:26:48 PM
by doctorb
