Author Topic: Power outage well pump solution  (Read 4681 times)
Offline DMcCoy
« on: November 21, 2014, 08:25:42 AM »
i was at the saw shop yesterday and saw a flier on these hand pumps.  Connects into house water system.
Clever!
http://www.simplepump.com/
Offline sawguy21
Re: Power outage well pump solution
« Reply #1 on: November 21, 2014, 09:47:26 AM »
 ;D
Offline JJ
  • Gotta figure this out
« Reply #2 on: November 21, 2014, 11:36:04 AM »
the full installation is $1600
Pump list price: HAND-OPERATED SIMPLE PUMP   $1,510
I will stick with my $400 6KW generator.
         JJ
Offline hoardac
« Reply #3 on: November 21, 2014, 10:18:05 PM »
These are a little cheaper and made in the USA also.
http://bisonpumps.com/standard-casing-hand-pump-use-electric-submersible/
Offline ljohnsaw
« Reply #4 on: November 21, 2014, 10:26:53 PM »
I bought a Simple Pump and installed it last summer.  Right now, I have the hand lever on it.  Four strokes and the water is coming out.  Fifteen strokes to the gallon :D  Filling a 5 gallon can take a bit (was doing cement work).  I will be off-grid so my plan is to buy their 24v DC powerhead and run from solar to fill a holding tank (cistern) in my basement when I finish my cabin.
The only issue I've had is the top gland was leaking as you pumped.  Probably a teaspoon of water with each stroke.  They sent me a replacement part and seals.  Apparently the top part was a smidge too big and didn't compress the seals around the shaft quite enough.  Now it just weeps a little (didn't swap the seals but probably will when I go solar).  Overall a well made product.
Offline luvmexfood
« Reply #5 on: November 22, 2014, 05:37:38 PM »
My sister and BIL used to live right beside me in a mobile home. They moved and are now about 700 ft away from me and uphill some. Maybe 60 ft in elevation. Anyway, they drilled a well and came up with pure muddy water.
So we had a large enough pump that we could boost the pressure on and pump to them. Ran a one inch line and put a pressure reducer to my house. Don't know how much water that line stores but if we loose power I have yet to run out of water. Six days has been the longest and I try and be extremly thrifty with it. Pee in the yard as much as possible. Can't shower because no hot water.
Long story short you might want to look into a similiar arangement if you have a hill behind your house. Bury a line to enough elevation gain and you could just bury a roll of black plastic pipe. The larger the size the more storage and pressure you get. The line going up to it does not have to be that big.
Offline John Mc
« Reply #6 on: November 22, 2014, 07:21:26 PM »
Great! If the power goes out, I can pump water half way up out of my well.
Offline Al_Smith
« Reply #7 on: November 23, 2014, 08:56:32 PM »
         JJ
That would be my prefered option also . ;D
Offline ljohnsaw
« Reply #8 on: November 24, 2014, 12:10:18 AM »
         JJ
But if you don't have a pump installed at all - what does an A/C submersiable pump cost these days?  Last one I bought came with my new drilled well (330') 25 years ago and that ran me $5,000 ::)
Offline Al_Smith
« Reply #9 on: November 24, 2014, 04:52:57 AM »
As far as a pump most likely a 1/2 HP Goulds around $400 give or take retail .Of course I haven't bought retail for decades unless I have to . ;)
A well 17-20 bucks a foot .Not terrible.The water around here is 100-120 feet
Then again if it were the high plateus in Nebraska or Colorado it might be half way to China .
Offline enigmaT120
« Reply #10 on: November 26, 2014, 12:32:04 PM »
At least you would keep warm!  I have a spring-fed cistern, so when my power goes out and I want water, I fill up buckets or jugs from the cistern's overflow.  I'll haul water in buckets up from the creek to flush the toilets or even bathe.  So far the longest I've been without electricity has been about 1 1/2 weeks, I think.  I don't think I would bother installing either of those pumps.
Ed Miller
Falls City, Or
Offline shinnlinger
« Reply #11 on: December 09, 2014, 07:56:09 AM »
I helped a neighbor install the Bison hand pump a few years ago.   It works very well and he is well pleased as they say.
Shinnlinger
Offline den
Homelite SuperXL, 360, Super2, Stihl MS251CB-E, Sotz M-20 20lb. Monster Maul, Wallenstein BXM-42
Offline DDDfarmer
  • did you know 4/3 people don' know their fractions
« Reply #13 on: February 02, 2015, 07:09:53 PM »
Just got a quote on a drilled well.
$44 per foot 6" case 100' min
$1500 testing/grouting
$100 6" cap
$300 for the drill bit.
Travel included ( I'm within their ok travel range)
sand screen and fracturing extra
Treefarmer C5C with cancar 20 (gearmatic 119) winch, Husky 562xp 576xp chainsaws
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #14 on: February 18, 2016, 07:28:33 PM »
Just a lift pump... Just a small part of my collection.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline r.man
« Reply #15 on: February 18, 2016, 08:52:21 PM »
Kbeitz any double piston pumps in there?
Life is too short or my list is too long, not sure which. Dec 2014
Offline Kbeitz
    • My Hobbies
« Reply #16 on: February 19, 2016, 05:59:49 AM »
I think I got 3 double pumps...
Offline Paul_H
« Reply #17 on: January 30, 2021, 05:53:45 PM »
We installed a Bison deep well pump today and it went pretty good with Carla helping. Start to finish was 2 hours to install six 8' lengths of pipe and sucker rods. The well casing was oblong on top so I had to make some mods with a hammer and a bit of work with a pocket knife to make the top seal fit the still somewhat oblong opening.
Our well is 90' and static level is around 15'. It's really well built and is 7 pumps to the gallon. We have a wood cookstove for heat and cooking and adequate food but water has been a concern when there are power failures and although we have a good backup generator that takes a couple minutes to setup,we've gone days without power and people, animals and gardens need water. In 2003 we were cutoff a week from the rest of the world by a flood and remained comfortable with six of us as well as an extra neighbour and ice storms have left us without electricity innumerable times.
Fitting the pump to the first section of pipe
A cool tool to hold the pipe while connecting the sucker rods then the pipe
The pump head hooked up and the safety rope tied to the cap then the sealing rubber under the cap is lowered into the casing then tightened down.
Easy to pump and can be connected to the pressure tank and feed the house if needed
eg  tregar  meste  p  Tulla, for  ho  var  krulla  i  ulla.
Offline Walnut Beast
« Reply #18 on: January 30, 2021, 06:13:54 PM »
Interesting. Thanks for sharing. I take it that works in plastic casing also
Offline Paul_H
« Reply #19 on: January 30, 2021, 06:18:33 PM »
I believe they have many options for different casings and sizes.
Hand Water Pump, Well Hand Water Pump By Bison Pumps
Power outage
Started by Ohiowood on Firewood and Wood Heating
Last post February 02, 2012, 11:01:13 AM
by wayno12
Power outage?
Last post August 15, 2003, 10:02:15 AM
by johnjbc
Higher power bill after outage?
Started by coalsmok on General Board
Last post September 02, 2016, 10:09:22 AM
by Ox
power outage with gasification boiler
Started by bsting on Firewood and Wood Heating
Last post December 10, 2019, 05:11:06 AM
by E Yoder
