Spot welding copper?
Started by Gilman, January 17, 2005, 06:56:58 AM
Gilman
A bit off topic, but I need an answer  :D
Anyone know if you can spot weld copper?  If so, do you need a dissimilar metal for your welding tips?
WM LT70, WM 40 Super, WM  '89 40HD
Cat throwing champion 1996, 1997, 1999. (retired)
footer
etat
I've never heard of arc welding copper. I do know it's really easy to soldier or braze.  Soldering with a hot iron will keep the heat lower and produce the least amount of distortion.  Copper likes to move when it gets hot.  A high lead type soldier will require the least amount of heat.  For a stronger bond silver soldier can be used.  Silver soldier would probably require the use of a torch rather than a iron because it takes more heat to melt the silver soldier.. When soldiering I like to use solid soldier wire and apply the flux by hand.  Acid or rosin core soldier will also work.  For a even stronger bond you could try brazing.  This would definately require a gas oxygen torch rather than a propane torch and would require more heat.
Either getting the heat right is just a little bit tricky.  Not to cold, and not too hot.  A bit of practice and you can get it just right.
The more you work copper, or brass  the harder it gets.  Also when joining it it has to be clean.  Absolutely clean. Over work it and it gets brittle.  To soften it back up requires annealing by heating the copper and immediately cooling it with water.
What are you trying to weld or join?
J_T
I know we got some ac repair men on here. Most time I use brand name I think is silfose  it is 15% silver and is in thin sticks last I got was 22 bucks a lb .Ad this in with Ck's and all three of us will be in the dark :D :D What you trying to do more info ??? Most time silver solder is used for dismler metals as in copper to steel joint have used it on lines up to 750psi.good luck
Jim Holloway
Gilman
I build copper top tables for the electronic test industry.  They need a table  5' x 20' with grounding flanges on three sides.  Thus, 30' of bonded copper flange to the copper table. I don't want to apply heat to the edges due to the warping problem that would ensue.
J_T
Could you use a metal break and break the sides and have it all in one peice ???
Jim Holloway
Larry
"Electronic test industry - grounding flanges - bonded" are terms that pop up a red flag.  Caldweld on ground wires prime example.  Can you check with the buyer first and see if there are any special electrial requirements for the welding?
neslrite
What gauge is the copper?
How high is the flange above the table?
Kevin
rule#1 nobody ever puts just one nail in a tree  LogRite Tools  www.logrite.com
Hey, y'all don't stop now!  I'm learning here.  I have a little project of my own that I'm thinking about.  I want to make a "once and for all!" pair of jumper cables. I bought 4 pairs of small vice-grip type pliers, and some copper lugs. My question is about brazing the lugs to the pliers. Should I braze them with brass, or is the melting temp of the brass higher than the copper? Once the lugs are bonded to the pliers, I can solder the cables into them.
I'm a rank rookie with a torch, just got my first one last month, but I did try brazing onto the vice-grips with a piece of copper wire. It seemed to bond really well and easily. Haven't tried it with the brass, yet.
Any input is appreciated. :)
I super glued a penny to the floor one time. ;D
I thought about that, Tom, but how would I get the floor up to the vehicle to jump it off? ??? :P
Always willing to listen to new ideas. :D
Dean Hylton
Dan, just an idea. Use a piece of thin wall steel tubing or pipe. A lot easier to weld it to the pliers. Then solder the cable in.
Thanks Dean. I did sorta look around for something in steel, but didn't spot anything real handy in the places I usually go. I'm gonna play around a bit with the copper lugs and see if'n I kin get'em to stick. If not, I'll look for something else.
The thought line is still open if anybody else has suggestions.  BTW, I posted this here to bring Gilman's thread back to the top. His project is interesting and could stand some more discussion. :)
MemphisLogger
I'm bringing this thread back up 'cause I was hoping it would lead to me knowing how the re-solder/braze the top on my radiator.
See, I've got this hissing leak all along the top where the core is crimped to the stamped top.
I assumed that I could just clean it up and resolder it with silver/tin solder and heat from a propane torch, but I haven't been able to find anything on the net to support this.
Does anybody know about this?
Scott Banbury, Urban logger since 2002--Custom Woodworker since 1990. Running a Woodmizer LT-30, a flock of Huskies and a herd of Toy 4x4s Midtown Logging and Lumber Company at www.scottbanbury.com
You can do it with acid core solder, but it's one of them things that seem's ta take practice.  I've fixed'em before with JB Weld.  That was on a plastic tank, though.
MemphisLogger
That's what I thought, DanG.
My soldering experience is limited to stained glass work but in doing so I've had to solder dissimilars--steel, zinc, lead and copper in the same piece sometimes and it seems that acid silver/lead does a decent job on those.
I was thinking I'd need to use a higher silver content on the radiator due to temps and pressure.
I guess I'll go ahead and take a shot at it--can't hurt since I  really don't want to pay the $175 NAPA wants for it.
WH_Conley
UrbanLogger, if this is a brass radiator that is not a crimp, it is a solder joint. I will give you my suggestion.
Take radiator out and put it in position where the old solder will run out when melted, wire brush it good first.
Gently apply heat to effected area and tap GENTLY with a small piece of wood, you will be suprised when a whole strip runs out.
Clean as good as you can with wire brush.
Find some tinning compound, sweating new solder requires too huch heat, apply tinning compound and heat it just enough to melt, it turns to a solder coat, very shiny apply new solder, doesn't need a lot of solder, again just enough heat to get a bond.
Should be done.
The downside, where new and old solder meet you will almost always have a pin hole, add a tablespoonful of fine ground black pepper to the radiator. (Honest it works)
This should hold for a while, best cure would find an old man at a radiator shop that has the jitters from snoffing too much lead and let him take the tank completely off and re-install it.
JB weld works for a band aid, and sometimes for a long time but if you ever plan on taking it to a radiator shop later on don't put it on, they will probably run you off.
Bill
Gilman
The tables:
1 to 1 1/2" flange.
0.093" thick
Can't solder due to the manufacturing process.
Pre bending flanges are not feasible due to standard copper sheet sizes and the manufacturing process.  I'd end up with a lot of waste and have extra seams in the top.
As far as brazing, Clean, Clean and clean once more.  Emery paper, flap sanders, SS wire brush.  Then use Non electrical solder with brush on flux.  Also, don't apply the flame directly to the area being soldered.  If you do apply the flame there, the copper or brass with oxidize and you just lost your clean surface.  The flux does help remove this oxide layer though.  PRACTICE first, you'd be amazed.  Let us know how it goes.
Murf
Maybe I missed something, maybe I'm just dumb, but why can't you just weld the flanges onto the table?
It's thin material, but if you keep the current low on thin wire it will work fine.
MSU_Keith
Regarding spot welding copper:
- It is done but requires special considerations.
- The higher the purity of the copper, the higher the electrical conductivity(which is what your looking for in this design I'm guessing), and the worse the electode pickup.
- Having water cooled electrodes is a good idea.
- Most industrial operations use tungsten or moly tips ($$$  :o).
- Might be able to get away with sandwiching the weld in between thin pieces of conductive sheet stock or tinning coating to prevent electode pickup but this might make for some ugly looking welds.
- You might want to consider ordering the RWMA manual on resistance welding of copper:
https://secure.proaccess.net/rwma/order/
- Another possibility is to consider brazing with copper-phos (AWS official designation BCuP) filler metal - this does not require flux and is alot less dependent on surface prep.
Be carefully using soldering and brazing interchangably; they are not the same and the filler metals are very different.  Brazing filler metals have a melting point of >840F, soldering uses filler metals that have a much lower melting point and result in joints that are not as strong.
For a crimped joint a quick and easy way to repair is to use foil braze.  Just peel back the joint under some heat, clean it out, then line the crimp with some foil braze, crimp back together and heat to the recommended temp under some clamp pressure - it will look like a pro did it.  Unfortunately foil braze is not available at Home Depot and the minimum order from a manufacturer is probably enough for 1000 radiators :(
Boy, we got off track on this one, didn't we. Guess that was my fault. :-[  I really just wanted to bring the thread to the top to troll for more answers.
Look's like we found someone with the right knowledge to help Gilman out, though. Welcome aboard, Keith! 8)  Could ya sorta draw a line between the test bench answers and the radiator soldering info?  Wouldn't want these guys, including myself to get confused.  In the phone business, we used a lot of copper busses for transmitting power to the switching equipment. All of the connections in that stuff were either clamped or bolted together using a conductive paste between to prevent corrosion. But, that was in a low voltage/high current environment(48-52vdc, 1000+amps).  I'm sure the conductivity requirements for Gilman's project are higher than our's was.  Keith, I hope you'll come back with more specific info.  My interest is piqued, as, I'm sure, Gilman's. :)
Fla._Deadheader
  DanG, try Silver Solder on the Pliers. Scratch 'em up a little. Use the torch and the copper will get red hot. Solder will melt before the Copper, AND, be a very strong connection.
  That Radiator soldering can be tricky. Shops dip 'em in an acid bath and clean 'em real good before soldering. I believe they use soft solder. It comes in a roll. CLEAN is the key word in Radiators. Uaually, I tear out the rubber seal and take the pressure off the cooling system. I lkow, I lkow, the experts say ya HAFTA have pressure. I just don't believe it. ::)
  Never had anything go bad doin it. Mostly, the pressure is so the water won't boil at 205°. Save money on thinner Radiators, don'tcha know.  ::) ;D ;D ;D
Thanks H.  I hadn't thought about silver solder. DUH! ???
I never bothered about ripping the rubber outta tha cap, just leave it at "half-latch". ;D :D :D :D
Fla._Deadheader
  Sometimes the system will still build pressure at "half-latch".
  My Dad was a Mechanic for the town we grew up in. One day, a driver said the truck was makin a funny sound,(Ford) ::)
  He went out and it was "whistling". It was makin steam, so, he gets a rag and turns the cap to ½ way. BAM, the top of the Radiator collapses tight on top of the core. :o :o  Never heard of it before or since. ::) ::)
Sounds like he let out the last little bit of steam there was. :D :D  It has been my experience, and I have(and still do)driven a LOT of junk, that a fella that loosen's the cap to get by for a little while tends to watch the temp guage pretty closely. If he don't, he deserves a nice long hike on a balmy day. ;D :D :D  A coupla milk jugs of water will save some shoe leather, too.
