Need to add Wood Master !
I like the Garn a lot 10 years we've had it. Saved us 6 cord of wood the first year over the Heatmor we had. A couple of draw backs though, any repair parts are very expensive and we can't get enough air to burn hot while using lesser grade of wood. I have to crack the door open about a 1/4" to burn real hot ( 500* ) stack temp.
CB 750 Edge, old stylePros, it worksCons, Cleaning the heat exchanger. have to crawl into the firebox, remove 2 metal plates, then scrape the heat exchanger.removing air channels, without breaking the bolts.I only need to remove those plates and channels once a year, do you do it every time u clean it?
Started by Thmf on Firewood and Wood Heating
Started by clif on Alternative methods and solutions
Started by Handy Andy on Firewood and Wood Heating
Started by just_sawing on Firewood and Wood Heating
