Author Topic: Outdoor wood boiler/thermostat  (Read 469 times)
Offline martensc
  • Member*
« on: April 04, 2020, 01:59:25 PM »
Hello, we are new to the whole wood source heating deal. We've had natural gas and recently moved to a home with an NCB-250. All winter it ran well, we have a spin thermostat set to 72 and a digital in the off position with the fan set to auto. Recently my wife was painting and took the spin off to touch some spots up. I put the spin dial back on and now the two aren't syncing. I checked the wires on the inside and they have voltage and are tightened down. Do you guys have any tips on how you re-sync these or how you set yours? I have attached some pictures for reference.
Thank you
Offline gspren
Re: Outdoor wood boiler/thermostat
« Reply #1 on: April 04, 2020, 07:24:50 PM »
Welcome to the forum. You may need to post this question in the firewood/woodheat section.
Online PoginyHill
  • Gentleman logger
« Reply #2 on: April 06, 2020, 11:09:12 AM »
If you took the entire thermostat off, it is likely it was put back on slightly off-level. Since it operates on a mercury switch, the orientation (level) is important to the on/off set-points. If it's not level, it won't keep the set temperature, but a little above it or a little below it.
Kubota M7060, Cat E70B, Case 310, 750 Grizzly ATV, Wallenstein FX110, 84" Landpride rotary hog, Classic Edge 750, Stihl 170, 261, 391
Offline E Yoder
  • Heating with a HeatMaster G7000
« Reply #3 on: April 09, 2020, 06:46:28 AM »
I'm trying to see what they did there. It looks like maybe they jumpered the 24v hot to the round stat, with another jumper back to G to start the fan.  Is that correct? Is that round one a mercury model? A lot of them have stopped using mercury and being level isn't so critical. Just a suggestion, a cheap digital thermostat isn't that expensive if this one gives you trouble.  May have to run batteries in it tho, I don't see a common wire.
HeatMaster dealer in VA.
G7000
Offline E Yoder
« Reply #4 on: April 09, 2020, 06:49:12 AM »
As was mentioned it might be out of level or if there are pins that insert to connect the front to the back they may not have been lined up correctly.
G7000
moved
MOVED: Outdoor wood boiler/thermostat
Started by chet on Alternative methods and solutions
Last post April 08, 2020, 10:05:35 PM
by chet
Empyre Outdoor wood stove /Any outdoor boiler
Started by KamHillbilly on Firewood and Wood Heating
Last post March 30, 2018, 07:01:53 AM
by ButchC
outdoor wood boiler?
Started by stumper on Firewood and Wood Heating
Last post October 21, 2008, 12:20:40 PM
by rowerwet
does anyone have a Woodmaster Outdoor Wood Boiler
Started by just_sawing on Firewood and Wood Heating
Last post October 24, 2014, 08:33:13 PM
by spyder68
