Author Topic: 2.2 kw spindle and VFD With A Masso Controller CNC router Build  (Read 1975 times)
Offline 21incher
I am starting to rebuild my CNC router. It was made from scrap I had at the time and worked good for about 500 hours but now the light duty bearing system is wearing and I am upgrading to a water cooled spindle that is quite heavy so time to rebuild it. I decided to go with a water cooled spindle to reduce noise with vfd speed control and also allow it to run at lower speeds for aluminum and plastic. Purchased the lowest cost one I could find on amazon and made a video about starting it up. It is a 3 bearing 80mm with ER-20 collet for 1/2" or smaller bits with a matching 220 volt VFD. I know many have interests in CNC routers and thought it may be good to start a thread so others can share info about what they use for spindles on their machines and any pros or cons about different types of VFDs and spindles.
This is the setup I bought on Amazon for under $250 including the mount and I just can't believe how quiet it is with basically zero run out on the bit shank.
This is a link to the video about them
Hopefully others will kick in about theirs and we can help each other with integration and questions others have.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Offline sawguy21
Re: Low Cost Chinese 2.2 kw spindle and VFD for a CNC router
« Reply #1 on: August 29, 2020, 09:09:23 PM »
Sorry my friend. I lost interest when I saw the title, I am fed up with that ****.
Offline 21incher
« Reply #2 on: August 29, 2020, 09:55:17 PM »
I would rather buy affordable items like this then do without. I don't have 4k to waste on toys that I can buy for $200.00 to use as a learning tool. I bet all the electronics in your car and home are assembled with Chinese parts along with the appliances right down to the light bulbs. Don't like it but these are the norm for low end CNC routers and mills that most use in an affordable price range.
Offline low_48
« Reply #3 on: August 29, 2020, 11:38:02 PM »
A friend of mine had to remotely mount a cheap VFD as the electrical noise made his controller loose some steps. One axis would creep as he cut, until he mounted the VFD over on the wall instead of on the chassis of the machine. Just a heads up for you.
Offline 21incher
« Reply #4 on: August 30, 2020, 04:20:13 PM »
Thanks I will do that. I am a little worried about placing the 400hz spindle cable in the cable chains and plan on using a braided shield over it grounded back to the VFD. I read you should not use the ground on the spindle because it will create a ground loop.
Offline 21incher
Re: 2.2 kw spindle and VFD CNC router Build
« Reply #5 on: September 17, 2020, 10:09:34 PM »
No one seems to be interested in the low cost spindles so I decided to turn this into a thread about building the CNC router it will be used on with some parts from my old one that was built from junk I had laying around and many new items. This one will be 30" x 50" cutting area that is the largest machine that I have room for. This is a video about getting started and finding a frame.
Offline rastis
« Reply #6 on: September 18, 2020, 12:29:22 PM »
I just started looking into building a CNC router table for flattening slabs. Havenít done much searching yet, but looking to do a 4x8 table. What do you have for parts sources?
Offline 21incher
« Reply #7 on: September 19, 2020, 08:13:20 AM »
I have been trying to use parts from Amazon for this rebuild.  It's a good test to see how they last and work for my subscribers and is easy for them to buy the same parts for builds if they pass my testing.  I built  a larger plasma  table  and found  many of the parts on Ebay for that. Gecko has good motor  drives and 8020 has really  nice straight extrusions.  It all really depends on your budget and the accuracy you want from it plus the tools you have available for the build.
Offline 21incher
« Reply #8 on: September 30, 2020, 08:11:51 PM »
Just another update video. Worked out the spindle cooling using the 35 pound aluminum extrusion for my gantry. That spindle is amazingly quiet.
Machining the main parts now.
Offline JRWoodchuck
« Reply #9 on: September 30, 2020, 11:21:18 PM »
Wholly moly your skill set is impressive! Where your from hillbilly redneck must mean something completely different than where Iím from!
Home built bandsaw mill still trying find the owners manual!
Offline 21incher
« Reply #10 on: October 01, 2020, 08:29:54 PM »
It's the values you live by. There's a story  behind  my YouTube channel name. About  15 years  ago I  was laid off from my last job after  being  replaced  by H1B Visa workers.  I got mad and dropped out of the workforce.  After  being  Unemployed for a while  my wife started  calling things that I  made Unemployed Redneck Hillbilly Creations and when I  started  a YouTube channel years later I used that for the channel name. Looking  back now it gave me lots of time to learn new things.
Offline 21incher
Re: 2.2 kw spindle and VFD With A Masso Controller CNC router Build
« Reply #11 on: October 18, 2020, 09:43:21 PM »
Well made a little more progress. Started to machine parts and a little assembly. Decided to go with a Masso controller and it's on the way from Australia. Looks like my cooling scheme is going to work.
Offline 21incher
« Reply #12 on: October 26, 2020, 06:48:36 PM »
Got a mini Ortur 3018 CNC router to play with until the build of this one is finished. My wife wants this one for making buttons when the big one is finished. Not making much progress on the build right now. Reading the 400 page Masso manual to figure out how to hook it up.
Offline 21incher
« Reply #13 on: October 29, 2020, 11:38:06 AM »
It has finally started coming to life. The Masso is so easy to set up.
This is the latest video
Offline 21incher
« Reply #14 on: November 14, 2020, 11:02:49 PM »
A little more progress. Electrical box done. Have the Masso fully controlling the VFD and X & Z axis's. Have the rotary axis working along with homing. That Masso controller is awesome. Found a T10 belt on Ebay to sink the Y leadscrews so that is what is left along with finishing up the tables.
Offline Walnut Beast
« Reply #15 on: November 15, 2020, 01:25:36 AM »
Looking pretty good 👍
Offline 21incher
« Reply #16 on: November 15, 2020, 08:11:54 PM »
Thanks.  Hopefully it will be finished  this week and I can get going  on Christmas presents.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #17 on: November 15, 2020, 09:28:55 PM »
How did I miss this thread? Definitely looking forward to watching the videos when I have more time.
Anybody want to borrow a couple of rodents? They sure do impede getting work done.
Offline 21incher
« Reply #18 on: January 28, 2021, 07:01:33 PM »
I haven't updated this in a while but it's working good now. Here is a final video about finishing it up.
You definitely learn a lot taking on something like this.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #19 on: January 29, 2021, 07:11:46 AM »
you find you like having the sides? I have been toying with open vs closed sides for a while.
New CNC router build
Started by hackberry jake on General Woodworking
Last post August 27, 2020, 11:07:58 AM
by Crusarius
CNC Router build video clip added
Started by GAmillworker on General Woodworking
Last post July 23, 2013, 04:00:31 PM
by drobertson
spindle sander
Started by Doug_D on General Woodworking
Last post November 19, 2012, 06:09:34 PM
by jueston
Shaper Spindle
Started by Fla._Deadheader on Wanted
Last post June 10, 2008, 08:02:56 PM
by Fla._Deadheader
