Author Topic: wood wall  (Read 1023 times)
Offline doc henderson
Re: wood wall
« Reply #20 on: March 04, 2021, 10:13:29 AM »
first step is fixing the hydrant and sheetrock. It leaked with back pressure like a spray nozzle or sprinkler.  I ruined the trim and rock.  so this area will get wood treatment.
@Jeff is that real wood on the floor.?
Offline DonW
Re: wood wall
« Reply #21 on: March 04, 2021, 10:39:28 AM »
Something on different lines
The Oak
Hjartum yxa, nothing less than breitbeil/bandhacke combo.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
Re: wood wall
« Reply #22 on: March 04, 2021, 11:06:28 AM »
Nope, waterproof laminate. Jeremy and another guy installed it in a day, that included moving furniture around.
Offline BradMarks
  • Foresters are TREE-mendous
    • Pacforest Supply
Re: wood wall
« Reply #23 on: March 04, 2021, 11:10:55 AM »
Jeff:  "Your family tree is full of".... what? ;D
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: wood wall
« Reply #24 on: March 04, 2021, 11:12:05 AM »
Nuts. I was missing a b and a t and had an extra n....
Re: wood wall
« Reply #25 on: March 04, 2021, 11:26:14 AM »
@DonW I love the panel wall, and one I may consider.  see what the wife thinks.  A big thing in places is a quilt block pattern, on old barns made from wood.  usually painted and somehow represents the family.  anyone have these or understand the pattern.  like a coat of arms, especially in old farm county, Amish ect.  It would be differing wood species as a focal point, not the whole wall.  we are doing the snap together planks for the same reason.  5 door thresholds, and trying to work through them, and not put a cross piece.  we have in floor radiant heat, so not a fan of nails into the floor.
Offline DonW
Re: wood wall
« Reply #26 on: March 04, 2021, 11:45:01 AM »
@DonW I love the panel wall, and one I may consider.  .  we have in floor radiant heat, so not a fan of nails into the floor.
Thanks, very enjoyable work. When I ran short on sawn stock for panels I remembered a leftover oak out back which I rived  into quarter stock to finish out gluing up the remainder
Your floor idea sounds like a parquet. Simplify by grooves at parimeter with splines. No nails required.
Re: wood wall
« Reply #27 on: March 04, 2021, 12:16:40 PM »
getting though a door jam into another room is the issue.  snap together requires a left to right placement, with some backwards stuff on a small scale.  trimming and getting under the jams when the plank is parallel to the door is tough.  I think the door stops are glued and cannot be removed.  I want to lay though the door into the next room without a transition piece.  I also have a flooring to carpet transition, and can buy a piece for that.
wood interior wall options?
Started by shad on Timber Framing/Log construction
Last post February 01, 2010, 01:36:25 PM
by Jim_Rogers
Single wall stovepipe and unseasoned wood
Started by Papa on Firewood and Wood Heating
Last post May 20, 2012, 11:23:35 AM
by SwampDonkey
Solar Kiln tarp /over the wood or just on back wall?
Started by julesfl on Drying and Processing
Last post April 05, 2015, 04:03:35 PM
by julesfl
Started by julesfl on Ask The Forester
Last post April 05, 2015, 03:28:18 PM
by julesfl
