Author Topic: moisture for cedar to be stacked?  (Read 319 times)
Offline Rebeldad1
« on: August 14, 2021, 01:13:58 PM »
Would like to know what the moisture reading should
be to stack cedar boards without stickers?
Thanks!!!
Offline Andries
  • Making buildings out of big curvy logs
Re: moisture for cedar to be stacked?
« Reply #1 on: August 14, 2021, 03:14:30 PM »
With Western Red Cedar, less than 15% mc has worked for me.
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
Offline forrestM
« Reply #2 on: August 14, 2021, 08:54:52 PM »
I'd like to piggy back on here - I had the same question about white pine. Do you think any wood would pretty much be dead stackable at 15%
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #3 on: August 14, 2021, 10:20:41 PM »
Yes, at that point, it would be fine.  Remember that many kiln dried studs are only dried to 15%, and many areas of the country only air dry to about that anyway, generally 13% to 15%.
YellowHammerisms:
Take steps to save steps.
If it won’t roll, its not a log; it’s still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, they’re burned, and you can’t fix them.  Don’t burn the cookies.
Offline Ianab
« Reply #4 on: August 14, 2021, 10:33:13 PM »
Under about 19% mould and fungus can't grow on the wood, so 15% will be safe. The closer you get to equilibrium the better, but locally that's about 14% anyway.
If you are dead stacking, make 100% sure water can't get at it. If water drips into a dead stack it can't get out quickly, and then bad things happen.
Will Dead Stacked White/Yellow Cedar Stain?
Started by pnyberg on Drying and Processing
Last post May 01, 2011, 09:28:57 PM
by pnyberg
Moisture - shrink ratios fir and cedar
Started by carver45 on Sawmills and Milling
Last post December 17, 2005, 01:47:11 PM
by Don P
Western Red Cedar Seedlings Moisture Tolerance
Started by Furu on Ask The Forester
Last post December 23, 2010, 02:04:11 AM
by Furu
Stacked cant
Started by bandmiller2 on Sawmills and Milling
Last post December 12, 2007, 05:42:27 AM
by bandmiller2
