Average size of trees your looking at moving? Any physical limitations on your part?
but I've read a lot of scare posts about popping wheelies if the log gets held up.
Steering with the wheel brakes often is needed as the front is light.
"One man" phrase raises concern if you are new.
I like to leave some sacrificial length on the log on long skids, it will get worn away/embedded with dirt and rock. <snip>Keep a saw on the tractor with you.
main 3PH implement is a bush hog and hearing TroyC bent "a couple" using his bushhog, on top of all the other "nothing fits this thing" posts, isn't exactly instilling a lot of confidence.
Started by poorfarm on Sawmills and Milling
Started by Gary_C on Forestry and Logging
Started by reubenT on Health and Safety
Started by Roxie on General Board
