Author Topic: Whats Your Big 3 of Firewood?  (Read 16362 times)
Offline John Mc
Re: Whats Your Big 3 of Firewood?
« Reply #40 on: January 29, 2014, 05:05:10 PM »
There are lots of BTU/species lists out there, but that ChimneySweeponline is one of the better ones.  Some lists are compiled form a bunch of different sources. The problem is, most don't even bother to check the conditions under which the sources were rated (moisture content, for example). ChimneySweep did some extensive checking and adjusting to compensate for different sources using different testing conditions.
Online SwampDonkey
  • Large Tooth
« Reply #41 on: January 29, 2014, 06:36:18 PM »
That's an awesome chart beenthere. ;D I see my ironwood (O. virginiana) is right up near the top.  8)
No amount of belief makes something a fact. James Randi
Offline Ernie
  • I woke up without a toe tag, I'm in for a great da
« Reply #42 on: January 29, 2014, 08:02:08 PM »
Amongst the New Zealand natives, Puriri is super hot and very long lasting but hard to find a good supply.  Rata is the same sort of thing, most common good firewood is Manuka or Kanuka.
In the non native category, I like Tasmanian Blackwood and some of the eucalypts
Offline barbender
« Reply #43 on: January 29, 2014, 09:24:30 PM »
1. Dry 2. Wet 3. Punky- My OWB is not at all picky, neither am I as long as it burns all night and still has some coals when I load it up in the morning. I usually just grab firewood every night when I get done with work. Right now I am burning green Red Maple, Paper Birch and a little Green Ash. Dead standing Jack Pine and Black Spruce are a couple I like to burn, they make way less ash than the hardwoods. Tamarack is good too, but it needs to dry a year. This is all for an OWB, things would change for a woodstove or fireplace.
Offline David-L
  • present and accounted for.
« Reply #44 on: January 30, 2014, 09:00:18 PM »
Along with anything dry, Black birch has become one of my favorites. burns long in my OWB and burns hot.
                                               David l
Offline ryguy777
« Reply #45 on: January 30, 2014, 11:00:44 PM »
beech, hickory and maple. most anything that's a hardwood and already dead on the ground will do for me. I even like a little bit of popple for my cook stove... nice fast hot fire
Online SwampDonkey
  • Large Tooth
« Reply #46 on: January 31, 2014, 05:30:50 AM »
Mom's uncle would burn popple (aspen) in his kitchen stove. Had a woodshed stuffed with it and lots of big popple on the farm to fill it with. My uncle would haul it for him in the spring with the horse and sled. Gave both of them something to do for awhile and exercised the horse. :D :)
Offline David-L
« Reply #47 on: January 31, 2014, 06:06:47 AM »
Popple also works well for getting a hot quick fire on the reload after a draw off the the maple evap. Do they use popple veneer for cabinet work?
                                   David l
Offline Ianab
« Reply #48 on: January 31, 2014, 06:08:58 AM »
Most common, Radiata Pine. Not because it's good firewood, just because it's the most common tree.
Better, Monterey cypress. Grows huge, and often pretty ugly. If it's not worth milling a 4 ft dia log has a LOT of firewood in it.
Premium. Eucalyptus or Manuka. Denser hardwoods.  Manuka is a small scrubby sort of tree that a "first coloniser" of neglected pasture. Only grows to ~20ft tall and maybe 6" dia, but it burns HOT. Also makes good smoking wood and the honey from it's flowers gets a premium.
Gold is an old Rata log. This is an interesting tree. It starts as an epiphyte in a larger tree, but eventually sends down it's own roots to the ground. After a few hundred years the original tree dies, and the "vine" is left standing as a tree in it's own right. Again, a very dense hardwood and the "vines" could be a couple of feet across.  The tree isn't really rare, but finding one that you can legally cut down is an issue.
Offline pabst79
  • Oh Boy! Wabbit twacks!
« Reply #49 on: January 31, 2014, 01:35:03 PM »
Oak, soft maple and popple. However I sure wish I could find more cherry, it burns hot and smells nice to boot!
Not sure which came first, but I have chickens and eggs.
Offline gspren
« Reply #50 on: January 31, 2014, 01:48:35 PM »
                                               David l
  I'm glad to hear about the black birch, I've got a bunch and my forester just told me I should get rid of most of it.
Online SwampDonkey
  • Large Tooth
« Reply #51 on: January 31, 2014, 02:20:40 PM »
I consider black birch as valuable for heat as yellow birch. According to the numbers it's a little better for heat numbers. So don't throw away your black birch. :)
Offline John Mc
« Reply #52 on: January 31, 2014, 02:25:26 PM »
Besides, it smells great when you are cutting it.
Offline BradMarks
  • Foresters are TREE-mendous
    • Pacforest Supply
« Reply #53 on: January 31, 2014, 04:17:43 PM »
Pacific Yew when I could get it, burns all night, rekindles easily just knocking the chunks together as long as there is a glimmer of a hot coal. Then Doug-fir, readily available, unseasoned heartwood easy to keep going. Lastly, whatever I bring home from a camping trip!
Offline Engineer
« Reply #54 on: February 01, 2014, 03:47:27 PM »
If it was only three species, I would have to say hop hornbeam, black locust and black birch.  The first two because they burn so hot and the last because it's still a great firewood but smells great when you cut it.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #55 on: February 01, 2014, 04:02:26 PM »
Haven't seen you around in a while, good to see you stopping by. :)
Offline gspren
« Reply #56 on: February 01, 2014, 04:49:02 PM »
  How long to season the black birch compared to red oak?
Offline mad murdock
« Reply #57 on: February 01, 2014, 09:13:35 PM »
Pacific madrone, burns long, good heat and low ash, next Douglas fir, a consistent starter and good heat value pound for pound probably as good as oak, IMO, but splits easier. Lastly, big leaf maple. Good firewood, just need to season well prior to use.
Offline John Mc
« Reply #58 on: February 02, 2014, 06:21:30 PM »
"Pound-for-pound" just about every species in North America has the same heat value (some species with high pitch content are slightly higher).  It's the heat content per unit of volume that varies, due to the density of the wood.
Offline davidlarson
« Reply #59 on: February 02, 2014, 08:56:53 PM »
Glad to see Engineer back.  I always thought his posts were worth reading.
David Larson, LTC, USAR, MC (Ret)
Whats The Problem With Souther Pine As Firewood?
Started by plaindriver on Firewood and Wood Heating
Last post January 06, 2012, 09:33:03 PM
by Al_Smith
Whats an Open Port Cylinder & Whats a Clam Shell?? Video explanation for Newbies
Started by weimedog on Chainsaws
Last post April 07, 2016, 05:28:01 PM
by ladylake
How long is split and stacked firewood viable as firewood.
Started by mart on Firewood and Wood Heating
Last post August 28, 2014, 06:05:10 PM
by mart
Firewood bags and a firewood bagger?
Started by jayinwww on Firewood and Wood Heating
Last post June 30, 2015, 08:54:23 AM
by CTL logger
