Author Topic: Anyone know where to get 5/16" stock T&G bits.  (Read 2222 times)
Offline 21incher
« on: March 10, 2016, 02:59:20 PM »
I am making about 120 sq ft of walnut, and 150 sq ft of ash T&G wainscoting from some stock that
I milled to about 7/16 thick x 12" to 18" wide. They will all be ripped to 2" , 3", & 4" wide slats after jointing and planing to 5/16".
I want to keep it the same thickness as some that I had purchased from HD in the past that is shown in the next picture which is 5/16".
I do not care about the beads and am trying to find a cutter set that will go down to stock that thin with a "V" groove. I see some at MLCS that go down to 3/8 thick with a 1/8" tongue, but have not found any that match the commercially available pattern that has a much thinner tongue. Thanks for any suggestions. :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Offline Bruno of NH
Re: Anyone know where to get 5/16" stock T&G bits.
« Reply #1 on: March 10, 2016, 06:56:35 PM »
Did you try LeeValley tools ?
Bruno
Offline 21incher
« Reply #2 on: March 10, 2016, 07:16:31 PM »
Bruno
Just looked. They only go down to 7/16 stock. Thanks for the suggestion.
Offline Larry
    • Copas Sawmill
« Reply #3 on: March 11, 2016, 11:55:10 AM »
Having a custom router bit made is always an option, but may be too expensive.  If a one time project I might cut the T & G on a table saw.  Use a dado blade with washer sized for the tongue and find an appropriate size blade for the groove.  Actually with that thin of material, a standard full kerf blade could make the tongue in two passes.  A 7 1/4 blade runs fine on a table saw for the groove.  Cut the V either with a router bit or on the table saw.
A shaper expands your capability.  With an insert head you could grind the cutters out of a HSS blanks in a short time.
Offline Dodgy Loner
  • It's an anagram for "dendrology" and in no way a reflection of my personality
    • My Blog: A Riving Home
« Reply #4 on: March 11, 2016, 03:46:14 PM »
What's the thickness of the tongue on the paneling from HD?
Offline 21incher
« Reply #5 on: March 11, 2016, 04:53:21 PM »
The tongue is .085" and the groove is about .095".  It seems like what Larry said a bit would have to be custom ground.  The project I am working on is not that critical so I will probably go with 3/8" stock and try the MLCS set for now,  and keep looking. I just thought it may be a industry standard joint because that paneling is available everywhere. I wanted to be able to insert strips of walnut into the purchased oak in a future project, but may have to rethink my idea now and make a cutter set from slot cutters and spacers. Thanks for the suggestions. :)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #6 on: March 11, 2016, 06:39:08 PM »
Try this place... They have a BIG selection. They have Adjustable  ones.
http://www.hermance.com/
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline 21incher
« Reply #7 on: March 11, 2016, 07:34:56 PM »
Thanks Kbeitz. I only see 1/2" stock & up bits on their site.  If the adjustable one was a little narrower it would work.
Offline Kbeitz
    • My Hobbies
« Reply #8 on: March 13, 2016, 06:59:53 PM »
When I worked at Grizzlys Tools they had tons of cutters.
You might want to check the out.
http://www.grizzly.com/search/?q=(router%20bits)
Offline hackberry jake
« Reply #9 on: March 20, 2016, 09:58:41 PM »
I would send a sample of the panelling to freeborn and have them make a stacked shaper cutter that had the tongue and groove  on the same cutter.Might be more than you're looking at spending, but it doesn't hurt to ask.
Offline 21incher
« Reply #10 on: March 21, 2016, 07:09:46 PM »
If I had a shaper that would be a good option. I have a 1" wide molding head for my table saw that might work. If I can find someone with a wire EDM  I may try and get some hardened inserts cut, but I think I may just change my plans for now. Thanks for the suggestion.  :)
Offline Kbeitz
    • My Hobbies
« Reply #11 on: March 22, 2016, 08:41:33 PM »
I made my own blades. I bought blanks and put them all in my vise in a stack.
I took a thin 6" cutoff wheel in my Dewalt grinder and cut the shape real slow.
Worked better than I thought it would. Being that they was all stack together
all cuts came out the same. 3 blades.
Offline Larry
    • Copas Sawmill
« Reply #12 on: March 23, 2016, 08:57:08 PM »
I use a shop made work plate on a standard 8" grinder to make and modify cutters for molding heads.  I normally use a chainsaw sharpening wheel as they are thin and cut cleanly.  Also don't cost much.  Made a pattern for the cutter than trace it on your knife steel by using layout die.  It really goes pretty fast.
I thought about using this method earlier, but grinding a cutter to your specs will be a chore.  The reason is your groove is only .095.  When the groove cutter is ground it will have to have draft on each side to cut cleanly or it will burn.  It might be possible, just I have never done one that narrow.
Offline tule peak timber
  • The Wizard of Crap
    • tule peak timber
« Reply #13 on: March 23, 2016, 09:27:52 PM »
Garniga offers a solution to your profile need - but don't ask the price! Stacking stock cutters and or creating the profile in multiple passes is the way to go on the equipment you have. Got a buddy with a woodshop?-Trade work ?  Rob
Offline 21incher
« Reply #14 on: March 23, 2016, 10:19:30 PM »
Thanks everyone. I ordered some slot cutters and a arbor from MLCS to try and stack something up. They had a 3/32" slot cutter that should be good for the groove and a couple of 3/16" to try and stack with some shaft shims for the tongue. I have a 8" diamond rim grinding wheel I will try and grind the chamfer for the tongue in the 3 wings of the top carbide cutter, and for the the groove side chamfer I will just make another cut with a std chamfer cutter. Looks like this is the only option for the equipment I have available and my budget.  :)
Contrasting 1.5" vs 2": chiesels and drill bits
Started by Rougespear on Timber Framing/Log construction
Last post June 07, 2016, 11:04:00 PM
by jimdad07
"forester" chainsaw sharpening bits
Started by logger444 on Forestry and Logging
Last post September 03, 2009, 12:26:44 AM
by logger444
smiley
Help a student Play the stock market " VIRTUALY "
Started by isawlogs on General Board
Last post February 11, 2009, 06:58:19 PM
by SPIKER
recommendation for 1 1/2" auger bits
Started by Max sawdust on Timber Framing/Log construction
Last post November 14, 2006, 02:19:54 PM
by MSU_Keith
