Mortise Location
Started by brendonv, May 24, 2009, 12:06:51 PM
brendonv
Looking through various pictures, and my new Sobon book...
I've noticed the mortise never seems to be in the center of the timber.  It looks to be offset to the outside of the timber, about the same width as the tenon size (1/4 of timber).
Is there a rule of how far from the side it should be that I missed somewhere in my new readings and understandings of timber framing?  It looks to be off the edge 1/4 of the timber size.
Thanks,
the newb
Brendon
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
moonhill
You could make up your own rule, reinventing the wheel.  As you are using Sobon's book stick to that system, square rule suggest 1-1/2" from the shoulder for a 1-1/2" mortice and 2" from the edge for 2" mortices.  Sometimes this can vary due to girts coming into a post form each side and forcing the tenon on the dropped tie to the center.   There are ways around the conflicting joinery, that is where the fun begins.
Tim
Jim_Rogers
Read this post:
https://forestryforum.com/board/index.php/topic,13965.0.html
It has the basic joint layout information in it, and the reasons why.
Then keep asking questions......
