Today's junkyard find.
Started by Kbeitz, January 09, 2017, 03:03:34 PM
florida
When I was about 8 we lived near a local dumping spot on the river. Just full of good stuff a kid needed. Everyday I'd drag stuff home and everyday my mom would make me drag it back. You're what I would have been if it hadn't been for a woman holding me back!
General contractor and carpenter for 50 years.
Retired now!
Kbeitz
Well it rained today so I got time to check out the chain saw. I put some gas in it
but it was almost full of what smelled like good gas. I should of dumped it out
because after about 5-10min of run time it locked up tight. I dumped out the gas and
put in a heavy mix and I backed out the H. screw one turn. I removed the spark plug
and squirted in some WD-40 and pulled the rope. It pulled hard but it came free.
So I fired it back up and ran it hard. I cut wood for about 30 min with no problems.
I had to put a chain on it . I have 100's of junkyard chains but I had a hard time finding
one the fit the narrow blade. I find lots of good bars and chains at the yard but not many
chainsaws. This looks to be a keeper. Like I said before this looks almost unused.
When was the last year homelite made a super XL ?
Love machine shop work
and Wood work shop work
And now a saw mill work
grouch
One of those "Kohler engine parts" appears to be an ice cream mixer, to me.
Kbeitz
Quote from: grouch on August 22, 2017, 02:31:47 AM
Yep. White mountain . highly sought after in this area.
Thanks for looking...
btulloh
That ice cream mixer would look good attached to one of your gear motors.  Then you can cut some staves and make a tub for it to fit in.  I guess you'll need the the container and lid and paddles too.  Maybe it's a bigger project than I thought.  Anyway, that mixer brings back memories.
HM126
paul case
Is that a thumb pump oiler on that chainsaw? I thought all the newer ones had auto oiler on them.
PC
pc
Kbeitz
Quote from: paul case on August 22, 2017, 07:53:15 AM
PC
I'm thinking that this saw is old.... It's heavy...
Kbeitz
I just looked it up... It's 27 years old.
Yes, that is a thumb pump oiler.  I have one that is plastic/nylon like the one pictured and another that has a brass pump knob.  Better put your ear muffs on because those saws are LOUD, and slow.
gww
Those little (and big) homelites are all I used my whole life untill about 3 years ago when my last two gave out and are probly in the junk yard.  I remember my cousens using the Mcculloch.  We were all pretty loyal to our brand and more then willing to look down on the other brand.  I grew up thinking that Mcculloch were hard to start :).
Cheers
gww
Ox
I cut ALOT of wood with an old Homelite Super XL with the thumb oiler.  I mean a lot.  It's got enough torque that you can really undercut when sharpening and take the rakers right down to crazy depths and it'll still pull a 20" chain loop on a hard nose bar.  I could keep up with the Husqvarnas the other loggers and woodcutters were using.  It was funny to see their faces when I pulled it out and in some cases outperformed their expensive modern saws with an old "clunker".
Yes, they're loud, heavy and vibrate horrible.  But they always start easy and run flawlessly.  At least mine did.  I'll always have a fondness for the old Homelites.
I have no idea what I will ever do with mine except keep them for whatever reason.  They both still crank and run.  I quit using them because of the lack of a chain brake.
Yup, a piece of hidden fence wire caused a kickback.  Eighteen stitches.   :-\
gww
Magic
I wish I had them cause my huskavarna 350 is falling apart and I have stolen dads stihl 390 cause I am too cheep to buy more saws and too lazy to fix the two that dad still has laying around.  I find that the one with the gas leak runs good but I find gas leaks hard to fix.  I think the closest to hurting my self that I remember is I cut into my tennis shoe and the greatest avoidince of real dangerous stuff that happended more then once was turning around with the saw in my hand and somebody standing or working there.  Sooo lucky.  I like working by myself when cutting up stuff. I am sure there are tons of other times that I got lucky that I can't remember or did not even notice. My smallest homelite newer modle had a chain break (plus auto oiler) on it but it was a total piece of junk.
Cheers
gww
Maybe someday we can make a rendezvous.   ;D
paul case
A local logger named Junior and his brother Max worked together all the time. Max relayed a story to me about his brother Junior's homelite xl super. If there was a bigger one it was probably that one. Junior left it at a saw shop and when he went back to pick it up a couple novice woodcutters were admiring Junior's saw and going on and on about how heavy it was. One said that he thought you would need a wheelbarrel to carry it in the woods. Junior shut them up when he said''If I couldnt take at least that big of a saw to the woods, I would just stay at home and play with mommie.
PC
pc
Kbeitz
I worked it hard today for about an hour. I kinda like the pump oiler.
I also have an old super xl weed eater hanging in the shop.
My dad ran it for years. Talk about heavy.
You all might like to see this. It's also an xl
I never even tried to start it.
coxy
we use to use them saws for cutting blue stone :o  what a pain it would be to use them again  the new cut off saws are wonderful
grouch
That's the first gasoline powered portable circular saw I've seen.
Kbeitz
Quote from: grouch on August 23, 2017, 05:42:22 AM
This is the third one that I bought. They are a big collectors item.
Kbeitz
I found this with some logging chains. Anyone have any idea what they are used for ?
coxy
they go on a chain to hook in a car/truck frame for holding them on a trailer   can you find me a good clutch fan for a 671 Detroit please
Crusarius
Those hooks are very useful. The fat end goes into the slots on a car frame so you actually have someplace to hook chains to. The are usually connected directly to the chains along with J hook and whatever else the towing companies use.
What coxy said :)
Kbeitz
Quote from: coxy on August 31, 2017, 05:44:12 PM
That's funny.. Today i looked at a 671 Detroit in the junkyard that's for sale.
It's hooked up to a 540amp 3 phase generator all for sale for $1000.00
Kbeitz,can you found me a millon dollars please   :D
Kbeitz
Thanks... With that information I googled it and found it to be called a R-hook.
Made for  Chevrolet.
