Board Feet Tally
Started by chickenchaser, October 05, 2013, 10:39:13 PM
chickenchaser
I haven't given this any thought until today:
    When sawing a customer's logs - do you keep a running tally as it comes off the mill or figure it in the stack?
With my limited experience, I have been tallying the stack...checking and re-checking. The job I am finishing up has very random lengths and multiple thicknesses in each stack. Learning experience.  ;D
I see where a running tally would have been more precise...
CC
WoodMizer LT35HD
JD 3720 w/loader. 1983 Chevrolet C30 dump. 1973 Ford F600 w/stickloader. 35,000 chickens.
I tally at the end of the sawing day, but sometimes with various lengths, widths, & thicknesses, hourly rate works best.
sawmillhand
I have a tally sheet i use and put little dots on it and tally it all up at the end of the day. Ill try and scan it so you can see it.
1990 woodmizer LT40 Hyd  2004 Ford F350 Flatbed. Plenty of tractors.
YellowHammer
I do a running tally because I always want to know my yield from the log as I'm sawing it, especially if its a high grade and I've had to pay for it.  To make it easy and quick, I have marked my bed rail with a big ruler so I can easily see the width of any board or cant as I'm sawing it.  With Accuset, most times I know the width exactly, anyway.  As the first board comes back on the the board return, I measure its length,and write it at the top of the column on the notepad and then add the width of every subsequent board under it as they come by me.  It only takes a few seconds to do the addition and notation while sawing the next board so I'm not loosing any time.
When done, I give the tally sheet to the customer along with the bill ;D
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
YH
You must have length on that sheet as well, or are your logs all the same length?
bandmiller2
I find running tallies just slow me down. I stack 4' wide its easy at the end of the day to figure BF, legnth times width times the tiers. Frank C.
Peter Drouin
I do it at the end of the job. Unless the guy wants to move the wood. Then I tell him to have it all gone by the time I get back the next day. I keep all the sizes together
Chuck White
I stack each size board in a separate pile.
That is 1x6x8 in a pile 1x6x10 in a separate pile, etc.
Then at the end of the day, I count the boards in each of the piles and document each on my tally sheet!
I tried keeping a tally as they came off the mill and it was a lost cause, because after a while I was thinking to myself...... Did I count that or not?
red oaks lumber
if the job is saw and go i blockscale at the end. if we are drying and machining it i'll tally the job at the very end.
woodmills1
I keep a running tally on 90% of my jobs, with others like one or two types of boards, or to a cut list I will tally different
customsawyer
I tally the packs of lumber.
www.thecustomsawyer.com
Nomad
     I prefer to tally the packs of lumber.  But I have to admit on a couple of Joe Homeowner jobs that ended up like Chinese fire drills, I had to make my best estimate.  I've promised myself to never let that happen again!
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Bigbo1234
I just did a job today and it was all smaller logs, 14" max by 10'. The owner wanted all 5/4x whatever I could get. I got mostly 8" and some 10's and 6's. I kept a notepad on my command post and tallied up each log. If it was a 10' log I wrote 10'x whatever width I got and how many boards from that log, then on to the next line for the next log. I worked we'll. I cut 1085 bd ft of red pine flooring, counting the 5/4 as 1" and didn't count any side lumber as he was takin it and ripping stickers on his tablesaw as I dropped them. I cut 23 logs. Prolly could have yielded more but I'm still learning.
Bowen
YellowHammer
Quote from: beenthere on October 06, 2013, 12:31:02 AM
YH
That's correct, I get lots of odd length logs and take that into account, but I don't usually measure the length of the log, just the first board as it comes off and assume all the boards off that log are the same length if its a decently trimmed log.  I've probably made this more confusing than it is, so let me give an example.  This technique easy and and fast and can be done in your head if sawing to standard widths and even numbers.
The first clean, edged board come back past on the dragback and gets measured for length and width either by the Accuset or bed rail or tape measure.  The length is written at the top of a column on my notepad.
After that all boards from that particular log just get noted for width and summed in a running total on the pad or my head until I'm done with the entire log including edgings. Only then is the final sum of all the widths multiplied by the log length at the end to get surface measure or again by thickness if different that 1 inch to get bdft.
The reason this technique is fast, easy and can be done in my head is that it doesn't matter how many boards come off the mill per log, the only thing I have to remember is the running total board width for that log.
So for example if the log was 8 feet long and it only gave up a few boards the tally sheet column for this log would look like this:
8 (first board length or log in feet)
10 (first board width in inches)
20 (The 2nd 10 inch wide board added to the width of 1st 10 inch wide board)
28 (The 3rd board was 8 inches wide added to running total)
36 (The 4rth board was 8 inches wide and added to running total)
40 (The 5th and last board was 4 inches wide and added to running total which now equal 40 inches total width
____
26.7 bdft
(While the next log is being loaded I multiply the total width x log length x thickness/12   or 40x8x1/12=26.7 bdft
If everything is coming off 1 inch thick, just multiply the total width x log length /12 which only takes a few seconds. 40x8/12=26.7
The next log gets loaded and I start a new column and do it again.
Nice thing about this is that when I'm done sawing, I'm done calculating too and can head to the house ;D
If I'm sawing for a customer, they get the tally sheet.
If I'm sawing for myself, I just compare this  yield to the scaled number marked on the end of the log.
YH
YellowHammerisms:
red oaks lumber
PC-Urban-Sawyer
Quote from: Bigbo1234 on October 06, 2013, 09:19:49 PM
... I cut 1085 bd ft of red pine flooring, counting the 5/4 as 1" ...
Bowen,
You cheated yourself out of 25% of your fee if you were charging by the BF. Softwood grading associations and general custom are that 1" and thinner is charged as 1" X width X length and that anything over 1" thick is charged as actual thickness X width X length
Herb
Tom the Sawyer
Most of my clients are woodworkers and have never had a log milled before.  They usually want a variety of thicknesses and log lengths are inconsistent.  Many times the logs are cut and then they think about getting them milled.  They also may try to balance the load in their pickup or trailer so figuring board footage after we were done was very inefficient for me.
I now keep a tally sheet on a clipboard.  I track a lot of information like overrun, blade life, etc. and the sheet helps greatly with that.  When I put a log on the mill I measure the small end diameter, length and my opening face height.  I enter the log #, diameter, length and start time on the sheet.  I have a small tally counter mounted next to my up/down button and once I start making boards I tap the tally counter at the end of each board, before I raise the blade up.  I have a ruler on the first bunk under the cant so I can read the width.  When I change widths I enter the tally counter number on the sheet, zero the counter and keep on milling.
I figure up board footage during a break (to give them an idea if they are curious or milling to a budget) and finalize at the end of the day.  I enter the info from the sheet into a program on my Android phone and it figures the board footage and the milling fee for each entry.  It may take me an additional 15 minutes at the end of a long day but it eliminates math errors and gives me the detailed information I use to make long term business decisions.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
Peter Drouin
Quote from: Tom the Sawyer on October 07, 2013, 10:21:51 AM
You sure do think a lot Tom. no way I could use a pencil
drobertson
Lots of great ideas and practices shown here,  whether it is a by the stack technique or individual tally both work fine, I like to keep track for custom orders as I go, just cause I'm lazy, and I really don't enjoy counting them over and over, and most have appreciated having a list of what they have, I suppose it aids when planning and building, for this reason I use this technique if you will, it is similar to the dot method allot of mills use,  I just threw this together,  sorry for the sloppy illustration,    david
red oaks lumber
if you guys are sawing to full capacity how do you have time to grab a pencil let alone write with it? i know i can't, i dont even have time to drink anything.
Dave Shepard
When I'm sawing for other people, it is by the hour, so my interest in the volume sawn is to get an idea of the cost per foot, so that I feel that my hourly rate is justifiable. So far, the customer is making out much better than if I charged by the foot.
One tool that I really like whenever I'm tallying is one of those little clicker counters from Bailey's. I hold the clicker in one hand and one of those big chisel bit permanent markers in the other and put a dot on the end of every board. It's also really handy when counting tomato stakes 500 at a time.
woodmills1
using my 70 with accuset on regular jobs all flitches go to the edger
so I end up with a cant that I already know the lenth and width of because I trimmed the log and sawed the cant
I keep a regular sheet of paper folded into eights in my back pocket, the one with out the crayon.  example the cant cuts 6 1x8x10, so i write 6 1x8x10 on the paper while the saw is moving forward.  I start the head, take off my gloves and remove the paper.  saw is out of log, so lift return hit down and forward, run speed down and up the write numbers.  saw is out of log, so repeat and put paper back in pocket and gloves back on
no saw time lost
on the edger I tally all boards of the same length as a width in inches in my head and will end up with like 56 inches of 8 foot one by, etc and that is what I write on my sheet
If you have ever run a woodmizer edger by yourself you will know why I welcome the chance to stop and write some numbers
all of the math is done later in the house and all of my customers get a copy of the exact lumber cut
NH requires me to provide a yearly tally for my mill permit
YellowHammer
Quote from: red oaks lumber on October 07, 2013, 06:33:54 PM
That's certainly something my off-bearers sometimes complain about. They
tell me to put the pencil down and grab the log hook :D   For some reason, writing down the numbers seems to always take just about the exact amount of time it takes for them to get a fresh log on the loader arms.  Amazing coincidence  :D
Actually, when I'm sawing alone, the reason I try to do as much in my head and minimal writing is to keep me from burning time
YH
YellowHammerisms:
terrifictimbersllc
Tailgate of my truck is my office, right behind me with my drink.  Sizes like  1x4, 5, 6, 7, 10, 12 and 2x4, 6, 8 go across the top of a fresh paper on my clipboard with a lumber pencil, and lengths 8, 9, 10, 11, 13 whatever down the left side, make a grid with the pencil, and spit out the count  in your head in appropriate box once or several times per log onto this paper as the boards leave the mill. Take a drink at the same time. Turn around and hope the next log is on the mill arms.   Put count in excel spreadsheet later to get the bf and email to customer or if I have time figure it in the cab and print it out along with the invoice.   That's how I do it.  My wife does crossword puzzles I figure this is just as good mental exercise for me.
Dewey
I don't know how to copy scan ect ... But my tally system was in Julys issue of Sawmill Woodlot it works great for me...
tazz
When I am sawing I keep a tally of the total dimensions of the cant after squared up. width x height x length and add up the bdft that way. I know you loose the kerf of the blade but any extra boards that come off in the process of squaring the log I throw in for free. This seems to be the easiest and quickest way for me to calculate the output and the customers have not had a problem with it.
SawyerBrown
How do y'all count boards that aren't even numbers?  Like if it was 7 1/2" by 10 1/2' long?  Do you round down to 7" x 10', round up to 8" x 11', or kind of shoot in the middle?  I've always rounded down, I figure going the other way isn't really fair to the customer, and if I'm going to get into fractions, then how precise are we going to get?  1/2"?  1/4"?  1/8"??  At some point, putting the decimal points in the calculator isn't worth the time ...
Pete Brown, Saw It There LLC.  Wood-mizer LT35HDG25, Farmall 'M', 16' trailer.  Custom sawing only (at this time).  Long-time woodworker ... short-time sawyer!
If sawing random width lumber, the conventional for hardwood lumber scaling is to go up if over the half, down if under the half. Right on the half, then throw one up, the next down.
Have to watch if sawing and selling a lot of green lumber based on scale, that after drying the ones just over the half don't shrink and fall below the half as can lose both from total bf tally as well as losing grade.
But likely not a big worry on smaller size operations.
I'd think just scaling the log before sawing it on the Int'l scale and go with that board footage (but use the net scale, not the gross scale). Will come out very close and save time if that is of interest.
SawyerBrown
I'm just a small guy mostly cutting lumber for local woodworkers, etc ... I haven't gotten into grade lumber, since it's all for their own use.  I just want to make sure I'm giving them a fair shake while getting paid fairly for the work.
By the way, I don't feel too bad about making absolutely sure I'm not overcharging.  Probably half of the work I do is cutting walnut, and a lot of the people I work for know what they pay for the stuff at the local lumber yard for their woodworking projects ($9+ / bdft), so they consider my bill a real bargain for what they're getting, and many times they'll throw in a "tip", which is very much appreciated of course.  I find this especially true when they're off-loading plus all the downstream work ... they appreciate how hard we work!
woodmills1
traditional is only even length logs in 2 foot incriments starting at 8 foot  (8'6")
and only even widths from 4 for some species but most at 6"
I only count logs in even lengths at 2 foot intervals  IE 8 10 12 etc, always rounding down  so 9 foot 11 is an 8 foot log needs to be 10 foot 4 at least to be a 10 foot board
but I do measure actual width to the inch 6 inch is 6 inch  6 and 3/4 is 6 inch but I do count 7 inch
drobertson
I feel obligated to answer redoakslumber's question as to tallying as you go.  I will usually go by the log, a few seconds of hash marks and load the next log,  for random widths it usually goes by the stack, give and taking for any gaps that might be present in any given layer, 4x's and any other misc beams will be recorded accordingly.  I don't run a high speed low drag operation, but rather a more precision rough cut operation.
rough is a relative term, most folks are amazed in the finish, as most band mill operators have experienced.
Some folks really don't care, they figure it out as they go, others appreciate an accurate tally.  It makes little difference for me, one is as easy as the other,    david
woodmills1
yes yes yes
my customers love the detail of information I give them
and as I said it fills need to state report
red oaks lumber
 the way i saw there is no way to tally while sawing. i have compared my 2 ways of measure, block scale and board scale  both ways are very close so, i save my measure time for sawing.
log procurement is huge! when sawing its 8' or 12' or 16' not 1 log 8' another maybe 12' to me thats just foolish :(
drobertson
Most definitely, unless it is a small short job, then the long ones go first.  Otherwise logs are sorted by length and stacked by length,  mixing log lengths on the deck is a recipe for headaches for sure, Whatever works for both parties is the best case scenario,  lumber and happy customers is the end product.     david
backwoods sawyer
I agree this
When tallying at the end of the shift a computer print out was just a simple click but that was running 1,400- 1,500 blocks per shift.
average production between 250,000 and 400,000 bft per shift,
I find i have enough to think about, like how is this saw running rather then how much i have produced. tried the clipboard in the rain thing, not for me, I tally at the end of the day or when the load moves, i tally by stacks and write on the stack with a lumber crayon that i keep handy all day long then total, customer can assit in tallying if they like.
Backwoods Custom Milling Inc.
