Solar kiln with dehumidifier
Started by Classic1, September 12, 2018, 11:03:45 PM
Classic1
I've got two 40' shipping containers I'm going build into solar kilns, I was wondering if anyone had just added a commercial dehumidifier into one of them and just run on a timer to kick on and off at varying times during drying cycle to speed things up?  I'm in central FL.  Heat is not an issue.  Any thoughts on controlling this setup?
Lucas dsm23
Norwood hd36
pineywoods
I have done just that using a framed-up enclosure. I air dry first, then stack in the kiln, turn on the fans and de-humidifier and go away for a few days. MY kiln has NO vents. The de-humidifier will add a good bit of heat. Another local sawyer has a similar setup. He successfully dries oak lumber for cabinet shops. Drawback. The dehumidifiers don't last very long in a kiln environment. just trash them when they quit. buy them at flea markets for $15 /$20
GeneWengert-WoodDoc
A dehumidifier improves the kiln's performance as vents are kept closed with air dried lumber, but it does cost electricity to run the DH.
A special note about worn out dehumidifiers.  Like refrigerators, freezers and window air-conditioning units, dehumidifiers contain an environmentally hazardous refrigerant material that damages the ozone layer, although not as badly as Freon from old units.  It is illegal to dispose of such items without first removing and capturing the refrigerant, which is a dangerous procedure that requires a certified technician. Local recycling or bounty programs ensure your appliance is disposed of legally, but they may have a small charge.  The captured gas is then treated to avoid environmental damage.
OutlawB52
Are you going to set the 40 ft container under direct sun and just put a dehumidifier in it ?  I am sure there is more to it .
Classic1
I'm a general contractor by trade, the lumber business has been a secondary business I'm developing.  The dehumidifier I was thinking of purchasing are the ones used in mold abatement and restoration in the construction industry. They are commercial duty units made to run in nasty environments.  I can get on that removes 130 pints of water a day, draws 8 amps, and has 325 cfm of air movement for just under 2k new.  Used market has them well under a thousand.
Seems like I could calculate load and moisture removal based on tables and just time how often the dh unit runs.  Would have to be a lot faster than just air drying.
Any issues on that?
Lucas dsm23
Norwood hd36
GeneWengert-WoodDoc
As many species of wood are quite acidic, the commercial DH units for wood drying use coils that are coated to protect them from corrosion.
A wood like oak or maple will lose around 30 pints per 1000 bf for each 1% MC loss.
I assume your 8 amps is at 220 volts.  So, that means 1.8 kWh or around a $2 per day for DH power.  Then there is fan power and heat power too.
Why not just go with a unit like the Nyle L53 and be able to control the drying without guessing?
Classic1
Well,  the L53 runs almost $4k but says its rated for 1000bdft.   I've got two 40' shipping containers, the L200 would be more appropriate I'm sure but runs $7700 each.
The dehumidifiers I'm talking about are commercial units, made to run non stop, in harsh environments.  They are easily serviced and maintenance on them is straight forward.  They have 1 year parts/labor warranty and 5-6yr compressor warranty dependent on brand.
The equivalent dehumidifier to the L53 specs would be under $1k brand new.   For the larger unit that I described in the previous post, it pulls 15+ gallons of water a day (those are at lower RH and temps)  Roughly double the L53 and can be had for $2000 new.  Going up from there I can get a unit that pulls 40+ gallons of water a day for $2600 that is a high temp model, all stainless construction, epoxy coated coils, etc.  That unit is ductable on intake and exhaust also so I could run the unit outside of the container if I wanted.  Not sure if its necessary as the controls on this are not electronic and are al solid state.
I'll probably pickup one of these and start logging results.
Gene,  would you advise to run this during the day when temps are up?  Has an operating range to 125F.  Or would it be better to run the unit at night?  Or cycle it on and off via a timer or other control?   I don't think I'm at risk of drying my slabs to fast with the amount of board footage in the kilns, but... I'd rather go at this in a manner that makes sense.
Lucas dsm23
Norwood hd36
GeneWengert-WoodDoc
Consider this option:  One L200 can potentially run two containers (with insulated, adjustable ducting) with separate heaters better than two L53.  You will have to work harder when different species or different MCs are in the two units.
GeneWengert-WoodDoc
One really essential consideration is that the solar kiln based on VT design  is very energy inefficient when the sun has set or even a few hours after sunrise and before sunset.  The poor performance is from the collector.  So, instead of the clear roof, have an insulated roof on the kiln and then build a separate solar collector.  Maybe this could be done easiest by making the kiln with an insulated flat roof and then put a sloped chamber on top of this.  The kiln and the collector would be isolated from each other at night (vents closed).  DH can run most effectively at night.  Make sense?
farmfromkansas
 What is the brand name of the dehumidifiers you are considering?
Southside
What do you have for a solution to the controllers? The Nyle units will cycle the compressor on and off depending on wet bulb settings, important with some species. Also, what about sterilization / heat treatment / pitch set. Air temp of 125 is a bit low per the USDA standard.
I can appreciate the desire to save money, but often you are money ahead by using the right tools and focusing on what it is about your business that makes money. I doubt you make money checking on readings every hour, rather it is made sawing and selling slabs.
Classic1
I've done nothing special on the construction of the kiln. Basically just have two 40' HC shipping containers painted a dark navy blue sitting in full sun exposure. Doesn't take long for them to heat up in the morning as by 9am they've had quite a bit of sun on them. They'll be 110f or so by then.  Heat of the day it's up over 120 easy.  If we painted them black I'd think we'd pickup 10f.
I don't want to insulate them, I don't want to use electric heaters.  Pointless where I am in Florida. 8 months of the year here our average highs are over 80f.   I don't need to turn over a kiln load every 2 months.  Right now we're air drying, if I could get a full load done in 4-5 months that would be awesome. That would be 6-8k bdft conservatively  2-3 Times a year.  I'm ok with that.
Everyone says I need to insulate but I can't imagine that being a huge issue, if I have 4K bdft of lumber that's a lot of mass inside that sealed container.  My schedule from my thinking at that point would be to shutdown the circulation fans at maybe 8pm.  Then cycle on the dehumidifier through the night.  As the lumber cools the retained moisture in the air should condense and the dehumidifier will do its job.  I wouldn't think it possible to dry something to quickly with this method.  And anything at this point is an improvement over air drying.   Thoughts?
Really trying to make this as simple as possible.
Lucas dsm23
Norwood hd36
Classic1
Lucas dsm23
Norwood hd36
Mfrost459
Insulating the container will help it hold the heat longer. I live in Georgia and it gets really warm during the day here too. My container will hold the heat well past sunset. Really doesn't start to get around 100 degrees till around 10 pm.
Wood-Mizer LT50 Wide 2021 - LT-40 - 1992
EG-200 board Edger - New Holland Skilsteer - Kubota SVL95-2 skidsteer
Nyle L53 Kiln -  Nyle L200S Container Kiln
Have a great day milling!
Classic1
Insulation will keep the heat out too.  Unless I run a separate solar heat collector and blow in hot air from that. The insulation will hurt me more.  Also, Georgia gets snow. Your winters are much different than central fl on the coast.  We stay much warmer.
Lucas dsm23
Norwood hd36
