Mystery log
Started by Bibbyman, November 09, 2007, 09:26:43 PM
Might be Gary_C, bark looks close. But isn't it a swamp tree where flooding occurs frequently?
woodbeard
That's really looking like ailanthus, but it seems odd that there would be a single leaf sprouting from the trunk.
Bibbyman
Quote from: SwampDonkey on November 11, 2007, 11:00:28 AM
I think he said it come from the edge of a stream.   He got the log from a rolling prairie kind of an area.  Maybe you'd call it a savana?
Quote from: woodbeard on November 11, 2007, 11:55:27 AM
There was a small twig on the second cut that the guy pulled the leaf from.  Even the butt cut has a few limbs and has a twig or to - now sans leaves.
P.S.  maybe another clue.  I just remembered that the guy said the blown over tree had no tap root like other hardwoods.  Said the rootball was flat.
I looked up water tupelo and it may be a match.  Not native to our area but not that far away or could be a yard tree, etc.
Sawing since '94
Geoff Kegerreis
Could you take a better picture of the bark?  In order for a picture of the cross-section (e.g. end of the log) to be worthwhile, we'd like to see a macro (as close as you can get it, but large enough to see the heart and a good bit of the sapwood (we need to see the rings if possible).
How heavy is it compared to Red oak (equivalent/lighter/heavier)?
It looks like Ailanthus to me - and that tree could be growing in the spot you suggested.  I've seen it growing "wild" before and it certainly could do well in central MO (or just about anywhere for that matter).  Have that friend who dropped it by take a look at the area he got it from again and see if there are heavy stump sprouts in the area.  Once summer comes around, if it's Ailanthus, you'll have lots of stump sprouts there, and the foliage is unmistakable.
So far, the bark looks right and the wood looks right, but it's difficult to say via the pics you have posted so far.
As for Ironwood, it grows up to 16 inches or more, but the bark gets a bit shaggy (like the cedars) at those sizes + it's extremely dense (very heavy).
I have an active lifestyle that keeps me away from internet forums these days - If I don't reply, it's not personal - feel free to shoot me an e-mail via my website (on profile) if there is something I can help you with!  :-)
Ron Wenrich
Ailanthus will have a definite odor to it.  Pungent would be accurate.  I've heard it called sumac, since it looks a lot like that.
The wood looks more like a maple.  Ailanthus has a greenish brown cast in the heart.  It has more pronounced rings.
Pawlonia and maple has a wood stucture like that on the ends.
Geoff Kegerreis
Quote from: Ron Wenrich on November 11, 2007, 12:36:33 PM
Yes, it looks a lot like sumac, but can grow much taller and I do not recall whether the wood has an odor.  They call it "Stinktree from Heaven" due to the foliage and flowers, but not sure about the wood.
QuoteThe wood looks more like a maple.
Maybe, and Norway maple is a distinct possibility too- it has diamond shaped bark and wood similar to that - it could also escape in that environment (or even might have been planted there)
QuoteAilanthus has a greenish brown cast in the heart.  It has more pronounced rings.
You probably have better eyes than I do, but I can't see the rings in that pic, which is why I requested another.
QuotePawlonia and maple has a wood stucture like that on the ends.
There is no way it's Pawlonia, as the average man could grab a log that size right off the ground and place it on the deck with his own two hands - Royal Pawlonia is extremely lightweight - almost to the extent of Balsa - and it's wood is similar in color too - but not in strength - that's for sure!
Corley5
Post some pics of it sawn into lumber  ;D :)
Bibbyman
Quote from: Geoff Kegerreis on November 11, 2007, 12:31:32 PM
I looked up Ailanthus and the single leaf I examined was not 1/4 the length shown for the Ailanthus.  I don't have a complete leaf group to know how it is assembled.
The bark is defiantly not like any ERC.
The growth rings are very hard to see.  They look to be about 1/10"/year so it would indicate it wasn't a real fast growth tree.
I've got the logs on the skid blocks right now.  I may saw them tomorrow and get some more pictures.
Sawing since '94
Well I gotta put more faith in Bibbyman than to think he doesn't know what maple looks like. Surely Bib.  ::)
I give up further guesses without knowing if it's ring porous and/or seeing a focused end grain picture.  ;D
Let the speculation continue.  :D :D
Trouble about that leaf he found on a little sprig is whether or not it was a typical leaf, a suppressed leaf, deformed leaf, or stipule, or stipel. However, the last two possibilities are unlikely.
Brian Beauchamp
The way the butt log looks and the slight bumps at the base of it make me think that it could just be a hackberry or sugarberry that isn't showing the typical characteristics of the bark.
woodbeard
The slow growth probably rules out ailanthus, that stuff will grow over an inch per year in those conditions.
thedeeredude
I know the answer, its tree wood! ;D  Hadda put that in there.
Bibbyman
Has anyone thought about Buckeye?  I've been looking at buckeye information and the leaf I seen could have been one leaf off a compound Ohio Buckeye leaf.  There was part of another leaf attached to the same sprig.
None of the tree guides show a cross section of the inside of a tree.  I guess they figure nobody's going to cut one into a log and then try to identify it.
We have had buckeye invade our farm in the last 20 years.  I've cut a number of sprouts but never any larger trees and don't remember what the wood looked like except it was light in color.
Sawing since '94
Buckeye is similar to basswood when fresh cut, it is tolerant of shade and fast growing. Found as a bottom land tree in the north and more upland to the south, often part of the climax forest. Wood light in weight 49 green, 25 lb/cu ft ovendry. Bark with unpleasant odour. May form thickets along streams.
Sapwood white to grayish-white, heartwood creamy white to pale yellowish white, often with gray streaks of oxidative sap stain. Growth rings barely distinct, delineated by a narrow light colored line. [Source:Text of Wood Tech]
You might just have solved it Bib  ;D 8)
woodbeard
The wood looks right, but the bark is wrong. Buckeye bark is pale light grey ( brownish sometimes ) and composed of wide flat plates.
I'm back to thinking boxelder. It's bark is usually much lighter colored, but maple bark tends to get blackened, maybe by a fungus or mold?
Over the years I've been convinced that bark doesn't mean much some times.
We have rock maple (sugar) that grows with platey bark, peals off in small plates in one region. That region it is heavy to sand and in my area the bark looks more like what you guys are used to. Our soil is richer here in potato country than the sandy soil where the other maple grows. According to the dendro text the bark of sugar maple is very variable. Even our black cherry is a bit different than that down your way, even reminds me of maple bark in southern NB. Enough to drive anyone trying to learn this stuff, into hysterics.  ::)
woodbeard
QuoteOver the years I've been convinced that bark doesn't mean much some times.
I agree, that's why I'm thinking it could still be boxelder, even though the bark looks so dark.
Buckeye on the other hand, has bark that is so much different than that in many ways. Also, a streambank is boxelders favorite place to grow, whereas buckeye favors higher ground. The twig/leaf sprouting from the trunk is also much more typical of boxelder.
Agreed, but both are rather light woods aren't they?
Bibbyman
Here is a close up of the end and bark on the mystery log.  Japanese beetle for size comparison.  It is very difficult to make out the growth rings.  Where you can, they are very close together – no more than 1/10 inch.  There is no distinct smell to the wood.
I took more pictures but none came out clear.  I have a close in feature on my camera but I often the pictures come out out of focus.   I don't think this one picture will tell you much other than the bark is real thin – about the same width as a beetle.
I brought my dad down to see the logs this afternoon. He logged most all his life.  He looked at them pretty close and decided they were nothing he'd seen before and not anything I thought they may be.  This leads me to think they are some kind of exotic yard tree.
I'll saw them up and call the owner.  Maybe he can bring a limb with a complete leaf structure.  I think that will be the only way we can narrow this tree's family tree down.
Sawing since '94
If that ain't buckeye, then maybe it's horse-chestnut, which is related, but not native.
woodbeard
What about river birch? It would be rather heavy, have dark flaky bark like that, and grow by a stream.
Gary_C
After seeing that bark close up, I think it could be hard Maple.
Well, we've been all around the woodlot on this one. :D
solodan
Yeah, based on the pictures I would say lodgepole. ???  But you said it had leaves. ??? and definately not native. ??? :D  But If you showed that pic to anyone in my neck of the woods they would almost all say lodgepole. :)
