2024 Garden Seeds and Starts
Started by SwampDonkey, December 27, 2023, 04:55:19 PM
21incher
Finally got outside and started cleaning up. Best compost ever
newoodguy78
Great looking compost 21.
We've been busy here trying to get veggies started earlier this year. Had some hiccups but we're getting through them.
Started pumping water and moving sprinklers before 3 this morning to try and save the first planting of sweet corn from freezing.Tried planting it through plastic then covering it with remay. Got decent germination considering this year's weather so far. Long term forecast seems to look warmer which will be nice. Hope everyone has a good season.
NewYankeeSawmill
Quote from: thecfarm on December 27, 2023, 07:54:33 PMI built my own tomatoe cages.
I used 1 inch cedar. Should of went with 1½ inches. ...
I got maters in the ground, and 2 cedars stacked up next to the mill!
I was going to save those logs until I know What I'm doing with the mill... but I could gain a lot of practice making 1.5x's...
And there's easily a half-dozen of them just waiting for me to cut them down!
Beans and pea's started sprouting, corn went in the ground last weekend.
I'm trying a small batch of Barley this year. I have a pair of Crystal hops plants producing... I just need to find a special kind of friend, LOL!
I've tried the wine-making thing, I'm trying to avoid becoming a brewer, but it's like there's a pull of gravity or something?. If they legalize it down here I'll never get any work done!  ffcheesy
 -K
Norwood LUMBERPRO HD36V2
Sturon onion sets arrived today. I need to transplant my pepper seedlings to bigger pots this weekend. Every seed germinated. The older peppers seem to be having another flush of blooms. I have not eaten all of the first bunch yet, probably 6 or 8 left.
Happy gardening. ffwave
I did get a second fertile cucumber off the vine recently.
Here are my peppers coming along. They won't go outside for another month.
Hand for scale.
Otis1
I'm pretty new to gardening, last year I had one 4x8 raised bed and this year I added another one. Everything that I planted from seed did pretty good and a couple store bought tomato plants. Last year I tried indoor starting a couple kinds of tomatoes, couple of peppers, and eggplant. Only had a little success with the tomatoes. That was coupled with experimenting with straw bales.
This year I am doing a little better with my indoor starts. They still don't look like they're as big as they should be by now. I have been starting seeds in small "greenhouse" type things. Should I be starting them in larger nursery pots? My setup is a wire rack shelf with grow lights and heat mats. I can easily turn that into a tent if I need to. A full grow room is not in the budget right now. Most of what I am trying to grow is seeds from Baker Creek.
Just looking for suggestions, thanks.
newoodguy78
Are your plants root bound? Meaning if you pull one out it would look like a solid mass of roots. If they are that could definitely be holding them back.
Depending on your location and when they can be planted I might recommend transplanting them to bigger cells if that's the case.
FWIW when I pull some of our starts that will be transplanted to the field I'm looking for a nice healthy plant that pulls easily from the cell and a root mass that is a 50/50 mix of roots and soil. And everything stays in the shape of the cell.
That's the gauge I use.
Too early and you'll pull the plant with no soil on it too late it's a solid white root mass.
Also before putting them in the ground, setting them outside for a few days to acclimate helps take some of the edge off of transplanting. Good luck would be curious how your garden does this year.
