General Forestry => Forestry and Logging => Topic started by: coxy on April 28, 2017, 05:59:14 AM
20 ag dozer with rubber tracks do the steering clutches run in oil a buddy has one and one clutch is stuck how hard are they to fix any info would be great
I assume that the dozer is a D20-something. I have a D21-A6 which is a power shift model. I recently put new clutches and seal in mine and it took me two decent days. The clutches in mine do ride in oil. Do yourself a favor and call Kent Baugh Equipment in Huges Springs Texas. They are super helpful with advice and parts. By far the most knowledgeable Komatsu guys I know.
(903) 639-2765 That's their office number.
Coxy,
you sure its a 20ag and not a D20a-6? if its a D20a-6 they are dry running jack up and block so you can turn tracks remove the floor plate, seat, rear plate, batteries, a few tubes and disconnect all the linkages. if using oem parts big money 2012 prices about $2,000 per side + about 40 hrs labor.
Bill
it has a number or letter in front of the 20 but it is not a d ill look tomarrow the shifter is long and on the left side sitting on it it has power assist for the steering has a little 4banger diesel motor I put it in the size of a 350jd dozer do the clutch packs come out the side or through the top like a Allis
If its a d20 man shift trans / D21 shuttle shift out the top
bill
