What type of mill did this come off of?
Started by POSTON WIDEHEAD, March 08, 2012, 02:55:33 PM
POSTON WIDEHEAD
I was sawing Cedar all day and just out of the blue, this guy stops by and gives me an old blade. He said he  thought I might like to have it to hang up at the mill.
All the old wheel blades I have seen are BIG ones. What would this 22 1/2 inch diameter blade have been used on? I don't see it milling a very big log. And the teeth are different than a larger blade I have.
Thanks.
Texas Ranger
Tim Lea
What type of mill did this come off of?  Well that is simple, a "sawmill".   :D
Chuck White
My "money" says it came off of an old buzz saw!
shelbycharger400
buzz saw blade !
mount it on ur tractor with an arbor and a belt and let er rip!
sealark37
In the South, this blade was attached by crude bearings on a jack shaft to the rear frame of a T model Ford or A Model.  A wooden wheel on the opposite end of the shaft was driven by one rear wheel of the vehicle, which was jacked up off the ground.  The blade you have was fixed to the other end, where it was used to saw slabs and limbs to fireplace or wood stove length.  It was called a wood saw or buzz saw.  I used one as a child, and I was not very impressed with the safety features it presented.  It would do some work for the cold and the brave.  Regards, Clark
POSTON WIDEHEAD
Quote from: sealark37 on March 08, 2012, 04:22:42 PM
Very interesting Clark, I had no idea. Got some weird looking teeth on it. Now if I can find me a T-MODEL FORD, I'll have her up and running!  :)
Thanks!
POSTON WIDEHEAD
Quote from: Magicman on March 08, 2012, 03:16:46 PM
I guess I did ask a stupid question. stupid_smiley  :D :D :D :D :D
Buck
It does resemble the blades in modern trimmers. I'm with TR on that one.
Respect is earned. Honesty is appreciated. Trust is gained. Loyalty is returned.
Live....like someone left the gate open
tyb525
They were very commonly powered by the belt pulley on an old tractor. They work great for cutting up slabs, so I've heard.
bugdust
Sounds like the makings of a "death trap." I've seen similar saws like this as cutt-off saws, as even today they give me chills.
Since I retired I really like work: It fascinates me. I can sit and look at it for hours.
Jim_Rogers
We would call it a cord wood saw blade. But it's kind of hard to see the blade's teeth.
If you posted closeup maybe we could see it better.
I have an old cord wood saw frame here and I could compare that blade with mine.
Jim Rogers
shelbycharger400
i have 5 blades similar to them here.    one is 17 inch,  2 are 25,   and 2 at 29
pineywoods
It came off one of these. I borrowed the pic from Tom's gallery. The teeth are funny shaped because they have been filed back to a nub. As a teenager, I had a part time business grinding and reshaping the teeth and hammering the blade.
Chuck White
Quote from: POSTONLT40HD on March 08, 2012, 04:41:00 PM
Thanks!
The blade is a cross-cut, and no doubt has been sharpened by hand (no guide) by an unknown number of people, so that all adds to its wierd looking teeth.
millwright
Pineywoods is right on the money, I have several of the blades from a wheel saw and they look the same, I also have a couple of model Ts if you want to try that.
That buzzsaw blade has seen better days.Most had an 1 3/8" arbor hole.They were designed as a cross cut saw.That old blade has misfiled teeth and would have to be forced into wood. Frank C.
thebckhntr
I would also bet on the buzz saw. My grandparents used one up into the 90's to cut wood for the cookstove in their kitchen. If I can get to it in the barn I will try to get a picture of it. It was ear piercing loud. Dangerous.
Peterson 10" WPF        Everyday Is A Good Day!
POSTON WIDEHEAD
Quote from: thebckhntr on March 08, 2012, 08:32:27 PM
Yes....post a pic Buck Hunter. Thanks. And welcome to the Forum!
markd
I have a buzz saw with the flat belt driven by an old case tractor that I cut up my slabs with, I much prefer it to the chainsaw.
markd
thecol
i vote buzz saw i would make a nice painted sing
steve phillips
hey post
you can put a pulley on the 140 . see no flower pot lol
if its not broke dont fix it !!!!
johnjbc
LT40HDG24, Case VAC, Kubota L48, Case 580B, Cat 977H, Bobcat 773
Taylortractornut
Tractor cutoff saw.     Theres some now that are being made for modern tractors with a v belt pulley and gear box.   I saved a cut off saw from a scrapper a few years back and want to used it for firewooding  the smaller stuff.
http://www.newhavenpower.com/Woodsman250.html
My overload permit starts after sunset
