spare tire mount question
Started by Jim_Rogers, September 26, 2020, 09:10:46 AM
OlJarhead
 finally got the poc you needed :)  hope its not too late
Jim_Rogers
Jim_Rogers
I just hauled my sawmill some 900 miles south and the spare tire rode nicely and never moved along the rail.
I did double nut the "U" bolt:
Jim Rogers
DanMc
On the subject of spare tires, I was pleasantly surprised that WM only wanted $115 for a spare tire on a rim.  The last time I picked up a similar wheel at Tractor Supply, it cost me over $200.  Today I called WM to confirm my LT35 order, so I added a second spare, mostly as a better spare for my landscaping trailer.  They said that the spare tire would be $176 on a fresh order today, but they'd maintain my price of $115 from my original order.  Nice.
LT35HDG25
JD 4600, JD2210, JD332 tractors.
28 acres of trees, Still have all 10 fingers.
Jesus is Lord.
Ben Cut-wright
That tire is OEM 175/75-13. I use it for a spare.  I have 205/75-15" tires on the road axles and have stored one of them on that same device when I had a flat tire just the other rainy, cold, dark, late night on the interstate. The spare tire lives there all the time and does not interfere with anything.  I use the tire as a shelf to tote securely strapped extra fuel tanks.
<b
Stephen1
Ben that looks pretty good. Can you give us some better pics of the holding device?
I would like mine mounted permanently also. I used to carry a spare and load and unload it each time. Some where along the way it did not get loaded back on for the return trip.
DanMc
I find it a bit puzzling why WM hasn't figured this out.  If you get a flat on a long drive, what do you do?  Leave a $40,000+++ piece of equipment alone on the road while you hunt for a replacement tire?  Trash the rim, driving to a safe place where now you need more than just a tire?  I would expect the mill to at least have some mounting brackets and perhaps the spare tire mount would be an option for them to offer.
LT35HDG25
Jesus is Lord.
NaySawyer
Yes .. more pics please .. can not make out what l am looking at.
To mount above the trailer l like jar heads.  For under the trailer l like the old tried and true pick up spare hanging from a crank up cable under the bed.
Btw .. the 93 LT40 recommended tire is an st215/75R14 (not 15", mine had 13s on it!).  PA, Canada's HF, has them  now for 129 cdn.
terrifictimbersllc
Quote from: NaySawyer on May 23, 2023, 09:55:18 AMFor under the trailer l like the old tried and true pick up spare hanging from a crank up cable under the bed.
This is a great idea, these tire hoists are only about $50 or so.
fluidpowerpro
Or if you know anyone that scraps old pickup trucks, ask them to keep an eye out for one for you.
Change is hard....
OlJarhead
Mines simple, just square tubing with a tire mount welded to it and a few studs to hold the spare on it.  Slides into an outrigger and away you go.
Nice thing is that once on the jobsite I just yank it off and set it asside until it's time to hit the road again, like the fenders :D
NaySawyer
In all fairness someone gave a more technical description of a tire hanger earlier .. lol
Ben Cut-wright
What you are looking at is all there is.
Your tire specs aren't relevant to my post.  The original OEM tires for my sawmill were B78-13" which converts to current metric 175/75-13". No idea why those particulars are in question.
I added the sizes to indicate the spare mounting would accommodate the different sizes. The reason I upgraded to 15" tires was because I added hydraulics to the mill.  The smaller diameter OEM tires did not permit the the loader arms to land anywhere near flush and level.  14" tires are better but 15" tires permit the loader arms to land with a few inches upward tilt.  The small tires put the hydraulic fuses very close to contacting grade before using the landing jacks.  Instead of risking the fuses, or having to spend extra time jacking the deck up to level the log loader, I selected 15" tires.  That size tire puts the loader perfectly flush after leveling the deck with much less jacking required and has a much higher load rating.
I would NOT use a harbor fraught tire even for parking duty.
I would not want a spare mounted in any way that it would collect sawdust/debris while sawing.
Ben Cut-wright
No significant amount of sawdust accumulates for any length of time on the spare tire.  Probably less sawdust on the spare than on the road tires during sawing.  That little bit of sawdust on the wheel in the photo got there because the spare went on the ground and stayed there until I got the flat fixed.  This photo was immediately after hanging the spare back on its carrier.  Much of the dust vibrates or blows off most of the mill when transporting between jobs.  I can verify that tire and wheel have been mounted there for at least a decade by the date code on the tire.
Even the most minimum maintenance would dictate dusting the mill long before any damage from rotted sawdust would occur.  If a neglectful operator fails to preform proper maintenance, a spare tire cover could be easily fabricated.
Stephen1
I put new tires on my mill yesterday. I kept 1 tire and bought a new rim so I now have a spare for my mill. I thought where I am going to put this spare? No rim left in the truck, so I remember Terrifictimberllc saying he just put the spare on the upright back stop and it  fits pretty good. Thanks Dennis!
Old Greenhorn
It's amazing what you can learn just riding in a rental car between Atlanta and the sawing project, ain't it? (I know I dozed off a bit during that conversation, but I remember the 'tire discussion'.) :D ;D
