A day of walnut cutting
Started by sawwood, June 23, 2003, 08:32:22 PM
woodmills1
most of the time I use the woodmizers quarter scale if I am just sawing 4/4.  But right on with the 1 plus 2 lines.  I use the same kind of thinking when I have a target size for a cant or if the center of a log is to be cut into 2 inch material. say when I cut the 4x4 pine dunnage out of smaller logs it is quite simple to add an inch plus 2 sixteenth lines and i find myself talking in my head 5 and 2 6 and 4 etc.
for awhile I was cutting pine pallet stock at 1 1/2 by 4.  nirvana was a log that squared to 12 x 12 since both finish dimentions divided evenly.  when the cant was 7 1/2 by 8 I didn't dare talk to anyone for fear of cuttin the wrong face at the wrong multiple. :o
Bibbyman
We had a couple of WM scales.  We had one that had 4/4 as 1-1/8 and another that had it spaced out at 1-3/16.  They were "back to back" on the same strip of metel.  You could just pull it and turn it over.
We'd sometimes make our own marks with lead pencel for other odd thicknesses.  By the time we were ready to saw some other odd thickness, the pincel marks had worn off or could easaly rubbed off.
On our new Wood-Mizer with Accuset,  there is a manual scale on the sawhead like before but it's hardly looked at and not really used.  I'm not sure how you can run a Super without an Accuset.  I'm sure it's done but the head moves up and down so fast,  it drives you nuts trying to hit the mark.
You can and do use manual mode to say open a face where you're just eyeballing the first cut.  Or can go to manual to move the head up to start on the next face.
Sawing since '94
Will_Johnson
Just a note on how the TK B-20 comes equipped.  It comes standard with our computer SuperSetworks.
The ACME rods mean it is able to stop "on a dime" and give excellent accuracy.  It doesn't have all the features of the WM accuset.  Like all of our engineering we like to "keep it simple." It simply lowers the head the distance you specify with four changeable pre-sets. It allows for kerf.
While the TK SuperSetworks is not as fancy, as I say it comes standard on a mill that sells for under $20K with setworks, complete hydraulics, transport package, full warranties.
Bibbyman
Will,
Will it also raise the head a set amount?
Sometimes I'll set the blade at where I think I can make my first full open face cut - say 6" wide face.  Then I'll raise the head 1" to make the first cut.  Then drop an inch to make my full face cut - thus produce a short board out of the taper.
Another use would be something kin to patterns sawing.  I'll find the center of the log,  raise the sawhead half the thickness of the post or beam I'm wanting to saw and then start from there hitting my up (auto up on the WM) until I get to the point of making my opening face.  Saw and then down for my next cut until I get to where I want to stop so to center the heart in the post or beam.
TimberKing SuperSetworks.
Wood-Mizer Accuset (box on top)
Knowledge Base tip - using the WM Accuset
Sawing since '94
On our big mill we have quite complex setworks. I dont always use them, especially for thicker stuff. 2" plus. The great thing about our setworks is the fact that they will as Will says the T.K. does, stop on a dime.  I have fast or slow forward, (up and down for most of yoiu boys :)). That means I can get to where I need to be fast, and have the last couple bumps with the slow to be exact.
I have had this argument with the kid we have here that saws back up. They had a 5000 dollar setworks on his dads old meadows mill that would set within 1000th of an inch he says, He says we need one here!
I said what the hell for? :D
Bibbyman
Yea, it's kind of like - dimension to 5 decimal places, measure with a micrometer, mark with a piece of chalk, and cut with an ax!
These devices are probably variations of programable controllers they put on milling machines.  The accuracy for this application is overkill.  But the speed and convenience sure is nice.
Sawing since '94
D._Frederick
When WM had there first computor at the show, I watched them sawing fir logs into dimensional lumber. When sawing-up a cant, they took off a slap then sawed the rest with the computor  set-works, then just before the last board they cut what they called a shim board and thru this board on the slap pile. I asked the sawyer why he didn't start the first cut so that he would not need the shim cut, said the computor would not do this.  From this I concluded that the computor was a waste of money. WM must have thought so too, because they put a computor on there mill that now do what a"good sawyer" would do in there heads. A great improvement for the every day sawyer that does not saw 40hrs a week.
Bibbyman
D,  we've been using the Accuset for a year and a half and the procedure you described – we don't do.  Not sure why they did it that way.
Would it happen to have been their earlier setworks called SimpleSetworks?  Could have been if it was more than 3 or 4  years ago. As I understand it,  SimpleSetworks only went up or down from where you started.  SimpleSetworks is still available.
Wood-Mizer SimpleSetworks
The Accuset references the saw bed and you can program right down to the last board and make 6 different thicknesses on the way down – if you want.
Wood-Mizer Accuset
Sawing since '94
D._Frederick
Bibby,
Yes, it was the early model. Was at the show, 98 or 99 time frame. There new computor has all the nut and bolts a sawyer should need, a great improvement! Other than a little more speed the first model was a waste of a $K.
Bibbyman
They've even made the latest version of Accuset even better by adding 4 programmable "go to" sets.  When you done with a log,  you can hit a button and then the up lever and the head will rise to whatever "go to" location you have programmed and set.  We've got one programmed to 12" another at 24" and so on.  If you are running mostly small logs,  on your last cut,  hit the "go to", hit the up lever and the head will rise up to 12".  Meanwhile, you can pay attainting to returning the head, unclamping, pulling the last board and loading the next log.
They've also made the programming of the drops much faster and easier.  You adjust the first one of 6 drops to the dimension you want and then when you shift to the next dimension,  it copies the dimension from above as that is normally what you want.  Before,  you had to adjust each one. Poke, poke, poke. Poke, poke poke.
Sawing since '94
sawwood
 Thanks guys for all the threws on this scale boards. See tom
 if we had a chat night, and by the way you would will still post
 lots of stuff all week long, a lot of us newbe would learn a
 lot. I have learned a lot about all the diff ways to use a scale
 and some of the new coumper setworks.  It just took a week
 to read and reread them all. Jeff what about it a chat night ?
 Ron called me last night about when we will cut up the rest
 of my logs and we talked about his scale on his mill and
 when i go out we will do some more looking at it. Bibby do
 you still have the WM scale board? I would like to see one
 so i can git see what you guys are talking about 1 plus 2
 marks. Have a good week end.
 Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Bibbyman
All the ones I had went down the road attached to the mills when they sold.  Oh yea,  got one on the new LT40HDE25 but it's just there like the turn signal lenses. (We have a stationary mill wired for traffic lights.)
I'll look around and see if I can find a picture.
Here is the best shot I can find.  Didn't know I had it.  The rule on the right is a regular 1" scale marked down to the nearest 1/16".  The scale on the left has marks that are spaced for 4/4, 5/4, 6/4 and 8/4 cuts.
How it works is - Lest us say you want to make 4/4 lumber - your opening face cut (cut off the slab.) The left scale can be adjusted up and down (has a simple thumb screw to loosen and slide the scale then retighten) so you adjust the left scale until it's on the nearest mark.  Then you just lower the head to the next mark and saw off the next board and so on. (There is a lexan strip with a line scribed on it to use as a sight for making the adjustments.)
You don't have to read or count the "big" or "little" marks on the regular 1" scale on the right side.
Now,  there are a couple of versions of these grade scales.  One saws 4/4 on 1-1/8" drop,  another on 1-3/16.  There may be one that is spaced to 1-1/4".  We had one on one side of the steel strip and another on the other.  Just loosen the adjustment thumbnut and pull it out and turn it over.
One thing nice about "walking with the head" on a Wood-Mizer mill is that the scale is always right there in front of you within arms reach and easy reading distance.
Sawing since '94
sawwood
 Thanks Bibby for the photo. I see in the scale it would be
 simple to use. Ron has a scale that he made and he just
 tapes it to the post. His has the platice lens with the line.
 He just bumpes the switch up or down till it lines with the
 mark he is reading. Will take a picture of it next time i
 cut with him.
 Sawwood
18" planer/molder
AtLast
Still not sold on that gravity verses weight thingy....sorta like when u wer bad in school and the teacher made ya hold erasers out to your sides...eventually the weight beat the strength and gravity won...but hey..Im no rocket sciencetist.. ;D
sawwood
 Wow after reading all the post here and the one Bibby has
 on how do you approch sawing i see i need to to go back
 to the start line. Is there any books on log cutting that would
 be good for a newbe ? I sure see that there is a lot to learn.
 I guess i will have to see if Ron will just take a couple of
 hours and show me how to cut with the scale board.and set
 the log. I have cut with him but it seem that i am working
 so fas that i miss some of what he is doing. The class that
 the NHLA has on sawing is it a good place to start to learn ?
 I am also learning a lot and will read all the post every day.
 Sawwood
18" planer/molder
Larry
Sawwood,
I think that 1 plus 2 stuff came from carpenters.  For framers 1 plus 2 would be 1" plus 2 eight's.  For finish guys it might mean 1" plus 2 sixteenths.  If there good you could hear a call like 1 plus 2 heavy or 1 plus 2 light.
For reading material the knowledge base right here is pretty good.  Another source is the Forest Products laboratory at http://www.fpl.fs.fed.us/pubs.htm  It would take forever to get through every thing they have on their site.
I print out some of these threads and put them in a plastic sleeve and then they go into a notebook.  I have always had problems with dealing with log stress.  I think it was Tom that put something together on that and I refer to it quite often.  Bibby and a bunch of the others add something new about every day.
I got a few pamphlets and books that I could drop in the mail to you if you want to go that route.
In the end I like to watch a good sawyer that will answer questions.  Next time you're with Ron watch him squint at the scale and ask him what he is doing.
Bibbyman
Here is Tom's tip on the Knowledge Base on Removing Stress in a cant (Thick middle Thin end).
We've hid all this stuff in the Knowledge Base so only we can find it. :D  Think of the Knowledge Base as everyone's plastic bag.
Sawing since '94
AtLast
Bibby and Tom...thanks for that knowledge base post..EXCELLANT information....it always seems to PRETTY much go " back to basics"..I havent had alot of stress encounters as of yet..been WAY lucky...but now Ill know exactally how to deal with them...thanks fellers!!!!
AtLast
My Baker has about the same scale as the WM...standard measurments without kerf..that 4/4, 6/4..8/4 WITH kerf...the carriage movement is so smooth that aligning it is very simple and accurate...Ive recently gotten blades from Timber Wolf that are the 1 1/2 X 7/8...89ss .047 with .021 set per side...I had to accomodate that difference myself...but it was pretty much " cut and dry"   ;)...( couldnt resist the pun) ;D...set works are all fine and dandy BUT as a licensed helicoptor pilot I KNOW that the more moving parts...the more likelyness of some kind of failure...I dont care who makes it....electrical componants as well as moving parts WILL fail...Ive flowen $2 million doller helis and had failure...it aint pretty at 2000' and the whistles start goin off... :)
AtLast,
 Your a heli pilot, huh? Do you have your own? How offten do you fly?
lamar
You guys have some good ideas. I feel better now that some problems I have others found ways around. I had a hard time at first trying to hold size on each cut. I like the KISS principle (keep it simple stupid) it works for me,not that IM stupid  :-/ I made a sliding vernere type scale so I can quickly line up a scale(magnetic strips) and make as many cuts then switch over. It works working from inside out too.
AtLast
Furby:
Yes I am...no I dont own my own machine..I WISH!!!!...did some flying in New Zealand, used to do the tour thing in Calif and conjunction work with the LA county sheriff....I have been on a waiting list for the Sierra Neveada Search and Rescue team now for a number of years...VERY difficult to get in. I trained in a bell 47G and have flowen a number of differant types...absolutely LOVE it...but I got married..and ..well..you all know how that goes  ;D..so now when Im running the mill I pretend the levers are the cyclic and collective on a heli.. :)..just waiting for the day it actually lifts off  :D  :D  :D
 :D :D :D :D :D :D :D :D :D :D :D
 Make sure you get pictures of that!
 I have always wanted to fly, but can't even afford lessons for a small plane, let alone a heli. Maybe when I get rich sawing wood! ;D
Bibbyman
QuoteBibby, if you'd wear it I'll put a TK hat in the mail today.  Only question is, do you want Camo or Black.  And oh yeah, do you want a new one or one that's already broke in?   :D
QuoteSure,  make it a new camo.   ;)
Just don't tell Ron and the next time I see him coming at one of the Forsety shows,  I'll put it on.  He won't know what to think. :D
I'll probably give the break in duty to my youngest son.  For some reason,  he glums onto every new hat that come in the house and wears it until another the next one comes in. >:(
Will,  my hat must have got lost in the mail. :-[
Sawing since '94
Bibbyman
Real nice TK hat Will.  Thanks.  ;)
I wore it to the Wood-Mizer Field Days in Mt. Vernon and got a free ride to the Mt. Vernon Police Department where they gave me a free photo shoot and stuck my fingers in some ink.   :-[
Good thing Arky came by to bust me out.  I's about to miss all the fun. ::)
Sawing since '94
