cbn grinder
Started by kev, March 21, 2009, 11:44:54 AM
kev
been thinking about cbn grinder just wondering some suggestions. i have a 2 year old woodmizer grinder now but having problems keeping stone dressed properly .just wondering if the cbn is much easier to use and what kind of job it does on the bands also is it difficult to set up .would a retro kit for mine be the way to go or a new sharpener.they look pretty well the same. thanks.
Mo
The CBN grimder uses the same wheel profile of a woodmizer blade, if you run a 10 degree blade you use a 10 degree wheel. No adjustments other than your indexing or depth of grind. It is vertuly a small version of our MFG and Re-sharp.
No muss, no fuss. The retro kit isn't avalble in the US. No learning curve such as dressing the wheel correctly. If you need more info feel free to call me.
Gary at 1-800-522-5760
