Author Topic: Kasco Canada  (Read 1456 times)
Offline firefighter ontheside
  • I like trees.
Re: Kasco Canada
« Reply #20 on: November 26, 2021, 10:07:40 AM »
They do list 158" blades on the site, which is what I need.  It makes sense though that blade length has to be somewhat dependent on tooth spacing.  I will be checking into this when I get home this week.  I have had great experience using WM blades, but with the way things are right now, I'm not sure I can get them.  Also since Kasco is based in Stl I would supporting a local business.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline Brian_Rhoad
Re: Kasco Canada
« Reply #21 on: November 26, 2021, 10:09:25 AM »
151 1/4" is 174 teeth at 7/8" tooth pitch. That gives you equal spacing at the weld. That makes it nice to sharpen them. You don't have to worry about the spacing at the weld.
Offline KenMac
  • I'm not as new as I was. but often feel very old!
    • ItGrowsOnTreesWoodworks.com
Re: Kasco Canada
« Reply #22 on: November 26, 2021, 09:49:14 PM »
I'm pretty sure my Cook's blades are sized to the tooth spacing but not to the group of 3 teeth. It shows up when setting the teeth. At the weld the sequence will inevitably be different, but makes no difference in sharpening on the Cat's Claw sharpener.
Cook's AC3667t, Cat Claw sharpener, Dual tooth setter, and Band Roller, Kubota B26 TLB
Offline RAYAR
  • Retired May 2/19 more time to play with my mill
Re: Kasco Canada
« Reply #23 on: November 27, 2021, 11:26:49 PM »
That would be 152-1/4"
mobile manual mill (local build) (mods & additions on-going)
Shop built auto band sharpener
Husqvarna 50, 61, 254XP (and others)
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: Kasco Canada
« Reply #24 on: November 28, 2021, 11:23:51 AM »
Maybe they only make them to the nearest group of three teeth times the pitch. Maybe something to ask about when you place an order.
I use 195" blades, 223 teeth, on my LT70 Wide.  Mostly Woodmizer, though because of supply i needed to get some from Kasco twice, via Richard Cutting Edge here. The Kascos were also 195", 223 teeth, not divisible by 3.  Woodmizer once sent me a  222 teeth , 194 " blade to try on my mill, I couldnt get it on, too small.
Ordered bands from FF sponsor Kasco Canada
Started by RAYAR on Sawmills and Milling
Last post June 07, 2019, 01:47:37 AM
by RAYAR
question
Kasco 2b
Started by Jmjacobs on Sawmills and Milling
Last post September 22, 2021, 07:18:27 PM
by judeholler
Kasco
Started by goose63 on Sawmills and Milling
Last post August 31, 2015, 06:23:00 AM
by xlogger
KASCO 11A
Started by Kchev on Sawmills and Milling
Last post July 23, 2020, 08:54:36 AM
by Dana Stanley
