Author Topic: Bandwheel size and broken blades. What is the relationship?  (Read 533 times)
Offline esarratt
« on: November 26, 2021, 05:17:04 AM »
I have heard that smaller sized bandwheels can cause broken blades.  Anyone have experience with this?
By smaller sized I mean 16" vs 19" wheels.
Offline longtime lurker
Re: Bandwheel size and broken blades. What is the relationship?
« Reply #1 on: November 26, 2021, 05:49:57 AM »
The smaller the wheels the tighter the bend radius the band has to travel around which results in increased metal fatigue.
Also the smaller the wheels generally the smaller the horsepower driving it, which forces you to use thinner gauge bands that are yet more vulnerable to metal fatigue.
Fundamentally bigger is better.
Offline barbender
« Reply #2 on: November 26, 2021, 08:32:54 AM »
I'm going to differ with longtime in the thin blades being more subject to fatigue, at least on the 19" wheels on my Woodmizer LT40, bands up to .045" seem to last nearly forever, whereas the heavier .050" and .055" blades will only make 2 or 3 sharpenings before they break.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #3 on: November 26, 2021, 09:29:10 AM »
.045" last until they can't be sharpened anymore, .055" I get 4 sharpenings on LT40 with 19" bandwheels.
Offline firefighter ontheside
  • I like trees.
« Reply #4 on: November 26, 2021, 10:15:46 AM »
It's all about how much a given thickness of metal wants to flex before it starts to break.  Thinner metal will flex more, so it can go on a smaller diameter wheel.  Therefore it makes sense that thinner bands will last longer on a given wheel size than thicker bands.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline Will_Johnson
  • Sponsor
  • TimberKing Factory Rep
    • www.timberking.com
« Reply #5 on: November 26, 2021, 12:38:32 PM »
Bigger wheels and thinner blades unquestionably increase blade life.
But I assume your interest in longer blade life is, at least in part, related to getting more value from your blade dollar.
If so, it's worth considering that while bigger wheels offer longer life, they also require a longer blade. So while you will save money by getting longer blade life, you will spend more on the blades themselves.
So it's about finding a balance that works for you.
There are similar trade-offs with blade thickness. Thinner blades are less likely to break due to the bending stress of going around the blade wheel. But they also have less beam strength, which means they're more likely to deflect in the cut.
Again it's about finding balance between various positives and negatives.
To a great degree the industry consensus seems to have settled around ~ 19" band wheels and ~ -0.04-0.045 thickness.
That doesn't mean there isn't room for dissenting ideas, or that a given situation might swing these balances out of balance.
Offline tacks Y
« Reply #6 on: November 26, 2021, 08:00:14 PM »
I know Timber King makes a tough mill but to run 7/16" blades? Maybe .040-.045"?
Offline Southside
    • White Oak Meadows
« Reply #7 on: November 26, 2021, 09:53:27 PM »
One additional factor is how the band is heat treated or otherwise finished when new.  I used to run WM double hards, but now only run their Silver Tip band as I get longer total BF out of a band and a lot fewer broken bands.  For whatever reason the Silver Tip has better flex life.
Although I run a lot of WoodMaster tooling in my planer and moulder, and I am very happy with it so they are my source for all of my knives, I have never run a TimberKing band so I can't comment on how they compare.  No Will - that's not a hint of any kind.   :D  :D  :D
White Oak Meadows
« Reply #8 on: November 28, 2021, 04:59:56 PM »
Just to clarify about the thinner band= lower band life comment I made, I agree with y'all that a  thicker band will flex less going around the wheels which reduces band life. And I also agree that a thinner band that flexes more will theoretically last longer, but it won't cut so straight as a thicker band. That's theoretically.
In the real world we all get paid for straight evenly sized lumber (and if it doesn't pay more then it definitely sells faster). So when you run the thinner band (or at least when I run the thinner band) I find it necessary to up the strain to keep it tracking well. And thinner (19 gauge) bands + high strain + fast feed equates to lower band life, at least in my limited bandsaw experience.
With these big old bangers like mine there are really only 3 band thicknesses readily available (here, other places may vary but I suspect not cuz these things are like crocodiles, basically dinosaurs but still incredibly proficient and quite able to eat ya)... 17,18 & 19 gauge, which is 0.045, 0.040, and 0.036 respectively, though I'm sure you can go thicker or thinner by the coil. Which makes the point that beam strength in a band has little to do with band thickness and a whole lot to do with band width. What I'm yet to learn is the long term economics, but what I do know is that big wheels + band depth makes for fast feeding and lotsa wood. ;D
broken blades
Started by woodweasel on Sawmills and Milling
Last post January 17, 2013, 10:00:29 PM
by Slab Slicer
3 broken blades
Started by davidn3 on Sawmills and Milling
Last post January 20, 2017, 09:41:56 PM
by Kbeitz
Broken blades
Started by Dbergum on Sawmills and Milling
Last post December 25, 2018, 11:54:47 AM
by Bandmill Bandit
Broken WM Blades new in box? Anyone else?
Started by Piston on Sawmills and Milling
Last post December 20, 2011, 11:35:29 AM
by Piston
