Another lesson learned $$$$
Started by WV Sawmiller, September 10, 2016, 01:43:36 PM
WV Sawmiller
   Well, learned another $$$ lesson. I pulled the cable out of the UTV winch on my logging arch. Simple fix right? Yeah, so I thought too. I put the end back in the slot and tightened the set screw to hold it but wound it over the top when I ran it back through my Fairlead rollers. Bad move. When I pulled on my next heavy log I pulled the winch free from the mountings and destroyed it. Should have rolled it under so when I pulled it would pull tighter against mountings. I checked the new ones in the stores and that is how they are wound also.
   Oh well, I may keep it for parts as the motor and pins and such are still useable.
    I had never thought about it mattering which direction the cable winds. Well, it does so a word to the wise. Make sure your cable is rolling out the bottom of the winch and not over the top.
AlaskaLes
I'll second that one!!
All of my winches are very specific about being wound out from the mount side/bottom of the drum.
You can see Mt McKinley from our backyard...Up Close!!
Mighty Mite MK 4B, full-hyd, diesel bandmill
Kubota 4wd 3650GST w/FEL; Forks;
3pt Log Arm& Log trailer
Husky 394XP
Husky 371XP
Husky 353
Echo 330T
Nyle 200M
Robar RC-50 50BMG-just in case the trees get out of line
Percy
Ill have a look at mine....Leverage???
BTW AlaskaLes...is that a Shelby AC Cobra in your avatar pic???
AlaskaLes
Percy, it's a Factory Five racing MK 2.
Pretty faithful replica of the 427 body style.  Made in Wareham, Mass.
Full double-H tube frame, about 300% stiffer than the original.
Racing 302; Holley 650 double-pumper pro race carb.
2550lbs with me and a full tank of gas.
4 sec to 60mph; 11.73sec 1/4 mile @ 108mph; top speed so far...about 145.
It is Pure Fun and my go to toy when I need to forget about a bad day.
License says "SLYTHR"
Husky 394XP
Husky 371XP
Husky 353
Echo 330T
Nyle 200M
tnaz
AlaskaLes
Husky 394XP
Husky 371XP
Husky 353
Echo 330T
Nyle 200M
WV Sawmiller
Quote from: AlaskaLes on September 13, 2016, 12:18:45 PM
Thanks TNAZ...it keeps me sane!
If you are sane what are you doing on this site? This site is for sawmillers, not sane folks. :D :D :D
AlaskaLes
Fair Enough!!
If I was sane, I wouldn't have the habit of taking on about 30 times the amount of projects that a reasonable person would.
I see that most here share the same affliction...It feels like home!
Husky 394XP
Husky 371XP
Husky 353
Echo 330T
Nyle 200M
sumday
Quote from: AlaskaLes on September 17, 2016, 03:19:47 AM
Fair Enough!!
The more projects I take on, the greater my chances of actually completing one right?
samandothers
Quote from: sumday on September 17, 2016, 08:26:32 AM
Fair Enough!!
I like this thought and approach!  I have got to remember this one as I can use it!
